AirMalta
Can Someone Help Me To Improve The Below Pictures?
Wed Aug 27, 2008 6:11 pm
https://www.airliners.net/procphotos/...62_MALCOLM_BEZZINA_LANDING_LHR.jpg
https://www.airliners.net/procphotos/...CB_LANDING_LHR_MALCOLM_BEZZINA.jpg
https://www.airliners.net/procphotos/...GL_MALCOLM_BEZZINA_LHR_LANDING.jpg
https://www.airliners.net/procphotos/...LS_MALCOLM_BEZZINA_LANDING_LHR.jpg
The above are all low quality besides they are very common.Can someone please help me how can they be improved ?And since the reject reson was also common shall I upload after I try to improve?
MAlcolm
PRM
RE: Can Someone Help Me To Improve The Below Pictures?
Fri Aug 29, 2008 11:24 am
Malcolm,
The CO762 has some oversharp areas, some soft and is generally borderline quality, so unlikely this one can make it I suspect.
RO313 is a bit better, but you went overboard on adding contrast I suspect. You could use layers with progressive sharpening to help get rid of some of the jaggies on the landing gear, engines, flaps etc and then it would be getting close to being worth a re-upload I would think.
The LX135 again has several oversharpened areas, and generally looks dodgy on the quality again - just doesn't look crisp, as if the original capture isn't quite sharp?
The VS744 looks close, again perhaps too much contrast/too dark underbelly, and some jaggies (titles, flaps, cowlings, wheels) that could be smoothed using layers during sharpening and then it might be worth a re-upload.
Anyway, I also get plenty of rejections so get a second opinion  Smile
mjgbtv
Fri Aug 29, 2008 12:56 pm
Malcolm,
I agree with PRM's comments. The darker areas and the sky also look a bit grainy to me.
I also question the crop on the VS744. The left side is cropped to the edge of the nose, whereas the right side is cropped to the engine. That makes the overall appearance look off-balance to me.
Marty
jgr
Screener
Fri Aug 29, 2008 7:07 pm
Hi,
I agree with others
CO762 oversharpen, gainy & dark
RO313 a bit oversharpen (airbus & TAROM titles and under engines) but the best of the 4
LX135 oversharpened
VS744 not centered, crop
Javier
AirMalta
Sat Aug 30, 2008 2:19 pm
thanks guys i try to sort them again
malc
