Page 1 of 1
Photo Acceptance - Pre Screening (G-CIVP)
Posted: Mon May 04, 2009 8:19 am
by G-CIVP
RE: Photo Acceptance - Pre Screening (G-CIVP)
Posted: Mon May 04, 2009 8:24 am
by Spiderguy252
The titles on the fuselage looks a little soft, in my opinion. Other than that, it looks pretty much okay.
Posted: Mon May 04, 2009 10:13 am
by G-CIVP
Thanks Varun - I just don't to over cook the sharpening.
Posted: Mon May 04, 2009 10:25 am
by aussie18
Id say overall it looks soft especially frwd part of the fuselage,titles,windows around nose are quite noticable.
Cheers Mark.
Posted: Mon May 04, 2009 10:47 am
by cpd
I agree with Mark - overall it has a fuzzy look to me.
The forward fuselage area, the nose especially (up near the flightdeck windows) looks quite soft.
What did the original image look like? And what did the processed image look like before a.net JPEG compression got to it?
Maybe try some high-pass filter type sharpening to give it a bit more sharpness without introducing too much jagged edges.
I also suggest that if the original image is sharp enough, that you try uploading a larger size photograph. That can help with planes that have fine-detailed graphics like these Air India planes.
Chris.
[Edited 2009-05-04 03:51:07]
Posted: Mon May 04, 2009 7:38 pm
by G-CIVP
Thanks for everyone's input. It seems the more I ask, the less I know!
I can up the sharpness and see what happens and use selective sharpening around the other areas.
If anyone would care to share any sharpening routines, I would be interested to hear these.
Posted: Thu May 07, 2009 7:50 am
by Spiderguy252
I actually did an edit last night:
Here's the original:
and here's the edit:
I worked on the nose windows, the titles and the windows behind the cockpit. What do you think?
Posted: Thu May 07, 2009 12:13 pm
by cpd
Sorry for the delay.
On a full size image - duplicate the plane to a new layer twice. For one of the layers, use high pass filter in Photoshop. Set it to something like 3px. Change the blending mode of that layer to soft-light. Merge the two duplicates together
Resize the image down to 1024x683px as normal - use smart sharpen at something like 45%, 0.3 (lens blur setting chosen). Now you can play around with these ideas a bit. I think that might yield a bit more sharpness.
Posted: Fri May 08, 2009 5:55 pm
by apgphoto
The new edit is soft in the middle (over wing)
Posted: Sat May 09, 2009 9:41 am
by G-CIVP
Thanks for the all the replies. If I may, can I reply to the most recent contributions a bit later as I'm not too chipper at the moment!
Best wishes, G-CIVP
Posted: Mon May 11, 2009 4:29 pm
by G-CIVP
Spiderguy252 - your 'original' looks worse than my original. Could be my screen. I'm at a loss as to what to conclude but I appreciate your efforts with the re-edit.
Cpd - No need to apologise; I've been out the loop as well. I think my resizing process may be to blame as I tend to use the 'save for web' option to compress the image down rather than resizing in
PS. I will explore your layering method detailed above. As you indicate, playing around with different methods may yield results.
