Spiderguy252
Can I Save This At All?
Wed Jun 24, 2009 10:27 am
Hello,
I recently took this pic at DXB, but I mistakenly set the exposure to -0.7. There also seems to be a green colour cast on it. Is there any way I can correct this? I didn't realize the exposure reduction as shots usually look fine on my camera display. Since I'm pretty much a novice at editing, I decided to post it here first.
http://i39.photobucket.com/albums/e168/Spiderguy252/Tryouts/DSCN0488.jpg
Thank you!
Vahroone
ruudb
RE: Can I Save This At All?
Wed Jun 24, 2009 10:45 am
Depends if it is shot in RAW.
Ruud
viv
Wed Jun 24, 2009 2:42 pm
Looks like the White Balance setting was way off.
Can be fixed in RAW, but not otherwise.
oly720man
Wed Jun 24, 2009 3:32 pm
Using auto levels, setting the white point using a bright area near a window on the left (above the first bush) and using curves I get this.....
http://i4.photobucket.com/albums/y120/oly720man/dxb.jpg
Spiderguy252
Wed Jun 24, 2009 4:52 pm
Unfortunately I can't fix it with RAW. Oly720man, thanks for your effort. I'll see where I can take it from this point.
[Edited 2009-06-24 09:52:46]
Vahroone
klemmi85
Wed Jun 24, 2009 5:24 pm
If you send me the original image, I'll recover it. Msg me if you want to.
quit a.net 07/2016
whales
Wed Jun 24, 2009 6:37 pm
Sorry to HIJACK this post I have similar problem with the photo below is there anything I can do to save it? I have it RAW as well as JPEG.
Thank you.
[img]http://farm4.static.flickr.com/3373/3657878466_1f55e9b8fc_b.jpg[/img]
JeffSFO
Wed Jun 24, 2009 8:59 pm
Quoting Whales (Reply 6):
To improve it? Yes. To save it? No. It's too soft and very grainy. Sorry:  Sad
http://i240.photobucket.com/albums/ff21/JeffSFO/Untitled-2.jpg
alevik
Thu Jun 25, 2009 12:22 am
For your personal collection you can improve about as well as indicated by JeffSFO. For anet, no chance.
Improvise, adapt, overcome.
Spiderguy252
Fri Jun 26, 2009 8:09 am
Just to update this thread, Dennis Klemmer(Klemmi85) helped me out with an edit. I did a bit more and seem to have come up with this......
http://i39.photobucket.com/albums/e168/Spiderguy252/Tryouts/DSCN0488_edit-2.jpg
Is there any way I can make the colours come out stronger without risking a colour cast?
[Edited 2009-06-26 01:26:43]
Vahroone
sdbelgium
Fri Jun 26, 2009 9:48 am
Left side of the image (with the windows) looks a bit awkward to me...
dazbo5
Fri Jun 26, 2009 9:56 am
I think the last edit has been over-processed. It looks too bright and as Sdbelgium says, awkward. I would also question the motive for here too. I like taking photos of terminal buildings and departure lounges and seeing the ones taken by others as it gives you an idea of what to expect if you travel to an airport you've never been to. This one doesn't really show you anything other that some of the local decor and leaves me wondering what's in the background.
Darren
Spiderguy252
Fri Jun 26, 2009 11:44 am
Quoting Dazbo5 (Reply 11):
That was always lingering on my mind. One for the personal collection then.
Thank you all!
Vahroone
