bkprspotters
Tomorrow Planespotting - Dslr Settings Tips
Fri Feb 20, 2015 11:55 pm
Dear anyone who reads this
Me and my team are going tomorrow at our local airport BKPR to do planespotting and I personally need your help instantly!
I am using a Canon 1000D(Rebel XS), which is not the best one, and a Canon Ultrasonic EF 28-135mm f/3.5-5.6 IS USM lens.
The day is perfect, sunny, clear, no clouds at all, so nothing to make problem.
What are your tips for the best camera settings guys?
I mean what shutter speed should I use, ISO, apperture and anything else...
I will be approx. 30m in the grass aside from the runway, so I'll be very near to the aircrafts.
Many thanks and appreciate your help!
Kind regards
dazbo5
RE: Tomorrow Planespotting - Dslr Settings Tips
Sat Feb 21, 2015 9:48 am
Quoting bkprspotters (Thread starter):
There are no best settings as it depends on the light. Always have the sun on your back so the aircraft is illuminated and the scene isn't backlit. ISO should be as low as possible to give you the best shutter speeds that you want, ISO 100 if its sunny, 200 is still fine if the sun isn't too strong. Aperture of f/8 will be about the sweet spot for your lens. Make sure this gives you an acceptable shutter speed for what you're trying to achieve. If the sun is strong, you might need to dial in -1/3 exposure compensation but that is less of a problem in winter.
The main thing, enjoy your time at the runway.
Darren
bkprspotters
Sat Feb 21, 2015 6:48 pm
Quoting dazbo5 (Reply 1):
Thanks a lot mate, tried my best! We'll see if I get anything screened
dazbo5
Sun Feb 22, 2015 5:26 pm
You can always post your photos here so members can give them the once over before they hit the queue.
Darren
epten
Tue Feb 24, 2015 6:02 pm
Your camera might not be the best, but certainly isn't a bad one! There are no bad DSLRs. You can produce airliners.net worthy images with it for sure.
bkprspotters
Fri Feb 27, 2015 6:07 pm
Okay guys, thanks for your responds
here are some links to my photos
https://www.dropbox.com/s/104fuk5v417jskx/edw%20perfect.jpg?dl=0
https://www.dropbox.com/s/bkv6lski6d8aqgh/_MG_0220.JPG?dl=0
https://www.dropbox.com/s/kb5sf73dxjdszrx/_MG_0238.JPG?dl=0
https://www.dropbox.com/s/qg7yxi5qdlz64om/_MG_0143.JPG?dl=0
dazbo5
Sat Feb 28, 2015 2:38 pm
Quoting bkprspotters (Reply 5):
The first two are backlit so won't be accepted here. The others need processing / editing according to the upload criteria for here. As they are, they aren't acceptable for uploading here. Nice shots though for starters.
Darren
ghajdufi
Sat Feb 28, 2015 7:34 pm
If you can get the editing right you might as well just set your camera to Auto everything.
Your photos are like your children, you will always find them perfect.
bkprspotters
Mon Mar 02, 2015 11:54 pm
Quoting dazbo5 (Reply 6):
Thanks for your tips mate
Here I got three more that I need your advice
https://www.dropbox.com/s/208p1p85khxxkau/_MG_1084.JPG?dl=0
https://www.dropbox.com/s/8i37jonsd2gsscn/_MG_1085.JPG?dl=0
https://www.dropbox.com/s/7866lq2h3fxilxw/DSC_0065.JPG?dl=0
Users browsing this forum: No registered users and 9 guests
