ATAIndy
Lens Focus Question
Wed May 27, 2015 11:57 pm
I have a question regarding image focus that I've seen come up in my photos many times.
In the photo linked, you will notice that the "American" titles are pretty blurry yet the registration and tail look to be in focus. What is causing this change in focus across the length of the aircraft?
https://www.flickr.com/photos/ataindy/17554844984/
I've tried changing the aperture and shutter speed, but neither seem to make a difference. For more info, this particular photo was shot at f/8.0 at 1/640 and ISO 200.
Any info or advice is greatly appreciated. Thanks!
Boiler up!
mjgbtv
RE: Lens Focus Question
Thu May 28, 2015 1:10 am
Some sort of distortion in the lens maybe? Everything on the left side of the image looks more blurry. It doesn't seem like you would have DOF issues with a side-on shot at f/8.0.
ATAIndy
Thu May 28, 2015 1:24 am
Quoting mjgbtv (Reply 1):
I wouldn't think so either. I took several shots of the plane departing and had others where the entire aircraft is in focus, so I'm not sure its lens distortion.
Boiler up!
vikkyvik
Thu May 28, 2015 4:26 am
Is this cropped in at all, or is it the full crop?
Definitely looks like a lens issue. I've seen similar with my 70-200, though only sporadically (aka not enough for me to do something about it).
Is yours the 70-200 F4L?
Quoting ATAIndy (Thread starter):
To be nitpicky, the EXIF shows ISO800, not 200. I thought it looked a bit noisy for 200.
ATAIndy
Thu May 28, 2015 10:59 am
Quoting vikkyvik (Reply 3):
Yes, it is cropped in slightly.
I'm using the Sigma f/2.8 70-200. Great lens that auto-focuses quickly, except for this issue.
My mistake! Definitely not sunny enough for 200 that morning.
Boiler up!
dendrobatid
Thu May 28, 2015 12:37 pm
I would suggest uneven panning, even though you are at a reasonable shutter speed, the background is quite blurred as you would expect from a far lower shutter speed. This could explain why some images are ok, others not.
Panning takes practice and it is important to start with your hips parallel to the movement as any even slight inbalance can cause uneveness.
Mick Bajcar
scbriml
Thu May 28, 2015 1:19 pm
Does this lens exhibit the same behaviour when shooting static planes at the same focal length? If not, then as Mick suggested, almost certainly down to panning technique.
angad84
Thu May 28, 2015 3:09 pm
This. I'm not sure it's down to the panning technique, as it looks like a softness/focus issue to one side of the frame, rather than blur.
I have experienced it with my 70-200 (F4L IS version) as well, but like Vik, only now and again, so not frequently enough to really be bothered.
Angad
ATAIndy
Thu May 28, 2015 4:20 pm
Quoting scbriml (Reply 6):
No it doesn't, which suggests improper panning.
However... that usually results in soft/blurry areas that all streak in the motion I'm panning right? This just looks soft without motion blur. I may have to do some more concentrated research to root out the cause.
Thanks for the input everyone!
Boiler up!
vikkyvik
Thu May 28, 2015 6:24 pm
Quoting ATAIndy (Reply 8):
That, and 1/640 is a pretty high shutter speed. You have to be doing something very wrong to get such a drastic difference from one side of the frame to the other.
Quoting angad84 (Reply 7):
Agreed.
Not necessarily. It could be that the act of panning is causing lens elements to shift. Or something. That's just an untested hypothesis.
angad84
Thu May 28, 2015 6:52 pm
Quoting vikkyvik (Reply 9):
Untested but likely - could be a stabilisation vs panning issue if it's an OS lens.
But if I recall correctly, your 70-200 is unstabilised, isn't it? Maybe it's just a combination of the focus motor, the focus element(s) and the motion of panning causing this issue.
A
dendrobatid
Thu May 28, 2015 8:14 pm
I still suspect poor panning and it can be blur in more than one plane, up and down as well as side to side. However I think we also foget the camera as it is so easy to blame the lens. The position of the sensor is highly critical and if it is even very slightly out, a few microns, one side can be sharp, the other not - it could be slightly loose perhaps.
Some checks are needed with the camera on a tripod and a fixed object I think - try a newspaper fixed to a wall far enough away to fill the frame
Mick
vikkyvik
Thu May 28, 2015 9:55 pm
Quoting angad84 (Reply 10):
Indeed, mine is unstabilized.
Quoting dendrobatid (Reply 11):
True, though I would think the lens could be calibrated to address this.
ATAIndy
Fri May 29, 2015 12:07 am
Correct, it is unstabilized.
I will have to try this, I guess there are many possibilities here. For reference, here is another shot at the 200mm focal length that looks just fine. https://www.flickr.com/photos/ataindy/16556053390
Again, I appreciate all the feedback, very helpful.
Boiler up!
