Diamond100
Nikon D7200 V D750
Sat Jan 30, 2016 10:42 pm
I'm after a bit of advice if possible - I currently use a D7100 and am looking to purchase a new body, making the 7100 my second camera. I am trying to decide between the 7200 and 750 and would welcome any suggestions on which to choose.
I have never used a full frame camera before and I have read plenty of pros and cons when it comes to aviation photography which is what it will primarily be used for.
Silver1SWA
RE: Nikon D7200 V D750
Sun Jan 31, 2016 7:29 am
D750
kulverstukas
Sun Jan 31, 2016 9:24 am
There is no replacement for displacement.™ FF.
yerbol
Support
Sun Jan 31, 2016 11:03 am
Hello Andrew,
D750 has an advantage in low light situations with keeping noise in low level at high ISO but how often do you shoot at high ISO? D7100 is a very capable camera with good fast AF and ISO. I would personally suggest to invest in good glass.
Nikon 70-200 f2.8 VR II or Nikon 80-400 AF-S version will be perfect match to your Nikon D7100 and will serve you well for long time.
If you already own a good glass and really need a camera for low light situations then go for D750. It is a fantastic camera!
Brgds, Yerbol
With best regards from Almaty
seahawk
Mon Feb 01, 2016 10:49 am
That depends on how focal length you need and what lenses you have.
So if you for example have a 300mm lens on your D7100 and need the 300mm to fill the frame, the D750 will not be your thing unless you decide to buy a 400mm lens in addition.
If you shoot a lot at high ISO the D750 wins over the D7200.
And here comes the big "BUT". If you are looking at a D750 you might want to look at the new D500. This DX camera will give you the same reach as your D7100 and probably clearly improved high ISO in addition to 10FPS and the new AF module. If the D500 is not totally out of your price range, I would suggest to wait for the review to come out and see what it does. It could easily be the best Nikon for spotting since the D300 back in the days.
iamlucky13
Mon Feb 01, 2016 10:28 pm
What do you feel is the shortcoming of your current camera? If you have a specific need, it would be easier to say if some other existing camera will fulfill that need, or if you should just work on improving your technique with your existing gear.
Beware of upgraditis. It is an expensive condition, but it is preventable.
ACDC8
Tue Feb 02, 2016 2:51 am
I'd go with the 750 if you're keeping your 7100 as a second camera - that way, you have the best of both worlds
A Grumpy German Is A Sauerkraut
Diamond100
Wed Feb 03, 2016 1:27 pm
Thank you all for the advice, there is certainly a lot to think about. I currently use a Sigma 150-600 as my main spotting lens which does give me a lot of reach, although it is a bit soft at max focal length.
AlexC
Wed Feb 03, 2016 3:35 pm
If it were me, I'd be doing nothing until the D500 becomes available!
mbs707
Sat Feb 06, 2016 11:39 am
It may or may not matter to you, but did you consider the crop factor on deciding whether to get the D7200 or D750?
Rtodepart
Sat Feb 06, 2016 4:09 pm
i own a 7100 and wont even touch a 7200 at all. my current plans are to keep saving for a older D3X a D800 or 810 ...
in your case i think depending on what glass you currently own crop of full frame .. makes more sence to wait for a D500 ....
Diamond100
Tue Feb 09, 2016 12:25 pm
Thanks for more replies, I think for me the crop sensor is prefered purely for the extra reach, one thing I have picked up on though is an investment in better glass rather than a new body.
With that in mind I currently have the Sigma 150-600, which is giving me some great results, I was thinking of investing in a 70-200 f2.8 lens. I have been comparing the Nikon and the Sigma versions which obviously have a £1000 difference in price, does anybody have any views/suggestions on the use of these?
Silver1SWA
Tue Feb 09, 2016 6:02 pm
Quoting Diamond100 (Reply 11):
Take a look at the Tamron 70-200 f/2.8. It's a fantastic lens.
brettkp
Tue Feb 09, 2016 11:51 pm
Agreed, the new Tamron 70-200 f2.8 is awesome, especially for the price!
brettkp
yerbol
Support
Fri Feb 12, 2016 8:03 am
Can speak only on Nikon 70-200mm f/2.8 VR II [the latest version] which I had in the past.
Optics: It is super sharp at all focal length at every apperture. Setting it at f4 or 5.6 gives corner-to-corner sharpness with perfect contrast. Mainly I used f5.6 for aviation photography.
Build quality and ergonomics: built as a tank, metal and glass. Rings are very smooth to turn. Heavy but not for me.
This super fast magic lens can serve you well during sports actions and kids playing in the garden. I mean this is almost all-in-one lens. Not a 300mm or 400mm but why bother if 200mm or 200mm x 1.5 is enough for you.
I would suggest to go for Nikon. It is expensive but it is a long term investment and lens which will serve you well for long time.
[Edited 2016-02-12 00:25:47]
adamptp
Fri Feb 12, 2016 1:17 pm
D750 all the way its brilliant.
Silver1SWA
Fri Feb 12, 2016 4:29 pm
Quoting adamptp (Reply 15):
I agree. Seriously if the D750 is under any consideration at all I will recommend it all the way. It successfully lured me from Canon, if that means anything.
iamlucky13
Wed Feb 17, 2016 6:23 pm
I'd suggest considering seriously how much you need that F/2.8 aperture. The Nikon 70-200 F/4 is reputed to be as sharp at equivalent apertures for a pretty decent savings in both cost and size/weight.
The main downsides compared to the F/2.8 are the loss of one stop of aperture to help you out in low light, a bit less potential to use shallow DOF to isolate the subject, and degraded autofocus performance if you use the 1.7X or 2.0X teleconverters.* If you need those features, then definitely one of the F/2.8 lenses, but if not, the F/4 seems really worth considering.
* Nikon officially states that only the center auto-focus point on the D7100 is able to autofocus on lenses with maximum apertures smaller than F/5.6 and equal to or larger than F/8. However, if I understand right, other users have found the other auto-focus points do work as long as the lighting is decent and the subject is high contrast.
wsss
Thu Feb 18, 2016 12:36 pm
Quoting yerbol (Reply 3):
What glass would you recommend for the D750? I assume it can't use the same glass as the D7100 because of the different frame sizes.
Quoting Silver1SWA (Reply 16):
If you don't mind sharing what about the D750 that made you switch?
iamlucky13
Fri Feb 19, 2016 11:27 pm
Quoting wsss (Reply 18):
Most of the Nikon telephoto lenses are designed for full frame cameras, so they work on both full frame and crop frame. The exceptions are the 55-200 and 55-300 budget telephotos, and the 18-XXX superzooms.
Choices of the others depends on how much reach you need, how big of aperture you need, and your budget.
yerbol
Support
Sat Feb 20, 2016 10:47 am
If you are on the budget - try AF-S Nikon 70-300 VR. I saw very good photos in database taken with this combo.
You may also consider AF-S Nikon 28-300 VR which I call "All in One" lens.
If money not an issue - try AF-S Nikon 80-400 VR. Gives you great range and quality.
I had AF-S Nikon 70-200 VR II on my Nikon D700 and I found it short in my home airport - Almaty airport.
I think 70-200mm is short on full frame body.
Good luck in picking your lens!
[Edited 2016-02-20 03:09:00]
Users browsing this forum: kiffy and 40 guests
