airkas1
Re: LotmaniaK photos
Wed Apr 25, 2018 4:21 pm
The 2 photos for vignetting and noise look fine to me.
Cathay looks a bit soft on the fuselage, but doesn't need much sharpening
Cathay Dragon looks a little blurry on the front section.
Dragonair looks blurry/hazed
airkas1
Thu Apr 26, 2018 11:43 am
I did see some vignetting on the left side after all. I accepted them on appeal to not hurt your ratio, but could you please give them a re-edit and reupload? The reupload feature is in your photo corner, on the right side of the photo in the 'accepted' tab.
LotmaniaK
Thu Apr 26, 2018 3:34 pm
LotmaniaK
Sat Apr 28, 2018 6:33 pm
LotmaniaK
Sun Apr 29, 2018 2:03 pm
Another rejection :
Blurry, Oversharpened, Noise
https://imgproc.airliners.net/photos/air ... dd9f07715d
airkas1
Mon Apr 30, 2018 1:11 pm
Cathay looks passable
El Al looks a bit blurred/not great quality
TAP is marginal, 50/50
LOT I can agree to those reason. Marginal quality and a noisyish sky
LotmaniaK
Mon Apr 30, 2018 3:31 pm
HarryLi
Screener
Tue May 01, 2018 12:25 am
Ural : Looks marginal to me. Soft and little bit low contrast i think.
CA 77W : Blurry to me especially the front part and the titles.
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
LotmaniaK
Tue May 01, 2018 5:23 am
Thanks for feedback Harry, maybe this CA photo is better ?
https://imgproc.airliners.net/photos/air ... 605a86275b
HarryLi
Screener
Tue May 01, 2018 2:38 pm
I am sorry that it still looks pretty blurry to me. Titles windows .
LotmaniaK
Tue May 01, 2018 6:35 pm
LotmaniaK
Fri May 04, 2018 2:09 pm
HarryLi
Screener
Sun May 06, 2018 10:57 am
Hi,here are my own opinions :
Ural : Blurry to me. [Especially the front part and the tail.]
LOT E175 : Soft and Blurry to me.Especially nose.
Wizz : Front part looks blurry and soft.[Cockpit glasses are obvious.]
LOT 738MAX : Soft & slight Blurry.
Nordica : Blurry toward the Front part and titles.
LOT 787 :Looks better but still looks slight blurry to me and it looks slightly low in frame too.
LOT E175 : Pretty Blurry toward the front part.
C-295 : Front part [Nose] looks pretty soft which leads to Blurry i think.
LH A320 : Soft but might be blurry i think.
TK A321 : Soft and slight blurry i think.
Belavia B735 : Windows look pretty soft and slight low in Frame to me.
DHL B757F : Whole aircraft looks blurry and bit of underexposed to me although you might shoot it in sunset or before sunrise. Slightly low in frame to my favor. I will tend to adjust the colour too since it's bit of reddish to me.
TF-BBH : Front part looks pretty blurry and it's obvious blurry.
UPS MD11F : Underexposed to me.
UPS MD11F (288UP) : Pretty blurry and underexposed.
Harry
LotmaniaK
Sun May 06, 2018 11:10 am
Thanks for your opinion Harry. What about this photo ?
https://imgproc.airliners.net/photos/air ... 994616cedf
HarryLi
Screener
Sun May 06, 2018 11:28 am
I am sorry. I afraid that this one will not make it in A.net since it's pretty blurry toward the front part especially the nose. As you can see those letters An-26B is not clear at all and cockpit looks blurry too.
From those photos you posted, most of them are blurry to the right side especially the nose and the tail. Did you check your lens settings or your camera settings ? Or maybe is your lens problem ? If so you can change another lens to have a try and see the results. And maybe is your Filter problem [UV],you can try to remove it and spot to see if it will be better. I got the same problem before when i use my old lense.
Harry
Runway28L
Sun May 06, 2018 5:06 pm
For the record, it seems like whenever I use an auto-zoom, or AF-S lens since I have a Nikon, the front part of the aircraft hardly ever focuses despite me being pretty steady and it's why I rarely even use my 55-200mm in auto.
My 70-300mm is just AF only, no autofocus feature. And it's pretty good at getting every part of the aircraft on-point.
Maybe if you are using a lens with autofocus enabled and aren't getting the entire aircraft crisp, perhaps consider trying out manual?
LotmaniaK
Tue May 08, 2018 11:17 am
I will try out manual next time. One more photo :
https://imgproc.airliners.net/photos/air ... c537294571
HarryLi
Screener
Tue May 08, 2018 12:20 pm
UPS MD11F looks underexposed and soft , blurry, poor quality i think. Title, front gear, cockpit pretty blurry and the tail is soft.
airkas1
Wed May 09, 2018 7:36 pm
Underexposed, overexposed (highlights of fuselage blown) and will not make it.
LotmaniaK
Wed May 09, 2018 8:04 pm
LotmaniaK
Thu May 10, 2018 9:39 pm
len90
Fri May 11, 2018 2:00 am
UPS MD11: need to take down those shadows a bit to help with that harsh contrast
Qatar 330: Not nearly as severe as the MD, but contrast is a bit harsh
Blank 737F: Harsh Contrast
TNT: May be a bit OS on the black of the livery
DHL: I'm good with it, some may not like the color but seems to be a low sun angle
Len90
LotmaniaK
Fri May 11, 2018 2:09 pm
Thanks for feedback Len. This photo got rejected for high in frame :
https://imgproc.airliners.net/photos/air ... 10f0f94ff0
HarryLi
Screener
Sat May 12, 2018 3:22 am
Blue Bird Cargo : HIF looks not bad to me although i would tend to move it little bit downward. Besides, it looks soft and underexposed to me.
UPS : Looks better but the cockpit and nose look soft/blurry to me .
QR A330 : Looks not bad to me. But i would like to promote bit of exposure since it looks slightly underexposed. Besides,i think smaller size might be better like 1024px.
EI-STM : Front part (Cockpit, nose, gear) look blurry to me.
Harry
LotmaniaK
Sat May 12, 2018 9:13 am
Thank you for your opinions Harry. One more photo:
https://imgproc.airliners.net/photos/air ... 28ea9ef75c
airkas1
Sat May 12, 2018 9:31 am
The El Al seems blurry, sorry.
LotmaniaK
Sun May 13, 2018 5:20 am
DHL got rejected for Soft & Underexposed :
https://imgproc.airliners.net/photos/air ... 971f8e3cf8
LotmaniaK
Sun May 13, 2018 2:08 pm
airkas1
Sun May 13, 2018 8:54 pm
The DHL can still be brighter.
airkas1
Tue May 15, 2018 3:38 pm
They're all marginal and somewhat underexposed due to the poor angle of light.
LotmaniaK
Thu May 17, 2018 3:01 pm
This picture was rejected on appeal for High in frame :
Now the edited version was rejected for Blurry :
https://imgproc.airliners.net/photos/air ... e4bcd771e9
HarryLi
Screener
Fri May 18, 2018 11:17 am
Title looks blurry to me as well.
LotmaniaK
Sun May 27, 2018 8:46 am
airkas1
Sun May 27, 2018 9:42 am
Blurry, OS, poor quality. Sorry.
LotmaniaK
Mon May 28, 2018 8:57 pm
HarryLi
Screener
Tue May 29, 2018 12:06 pm
I am sorry that it looks quiet Underexposed and Poor quality. Especially the sky looks slightly Grainy/Noise.
Harry
airkas1
Tue May 29, 2018 1:06 pm
I tend to agree with Harry's comments.
LotmaniaK
Sun Jun 10, 2018 7:47 am
I need some feedback on this 767 pic :
https://imgproc.airliners.net/photos/air ... 3ef8932f2b
airkas1
Sun Jun 10, 2018 9:06 am
Looks passable.
LotmaniaK
Sun Jun 10, 2018 10:39 am
Thanks Kas. What about this Sukhoi pic ?
https://imgproc.airliners.net/photos/air ... 75dbc30cd6
HarryLi
Screener
Sun Jun 10, 2018 1:40 pm
I am sorry that the Sukhoi looks pretty blurry and soft to me. :cry:
Harry
LotmaniaK
Sun Jun 10, 2018 7:17 pm
Thanks for feedback Harry. What about this 787 photo ?
https://imgproc.airliners.net/photos/air ... 9858ff4d59
