airphoton
Feedback on photos
Fri Jul 28, 2017 10:44 am
Hi,
Before I start uploading anything I would like some constructive feedback on the following two images to see if they match what this site requires for uploading.
HarryLi
Screener In Training
Re: Feedback on photos
Fri Jul 28, 2017 2:19 pm
Hello,
First of all, the light condition is very good.
And regarding to the CA A330. It seems that over-exposed to me.
The Monarch B738 ....also seems overexposed to me. And i can see obvious Halo around the whole aircraft especially above the wing and you can use Equalize in Photoshop to check it.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
airphoton
Fri Jul 28, 2017 2:50 pm
I'm not quite sure about the halo around the aircraft... doesn't seem to be obvious to me even when I equalize. Here is another edit of the Monarch with more conservative adjustments to the levels, is it too dark now?:
HarryLi
Fri Jul 28, 2017 3:22 pm
No, the exposure seems ok to me now and i do not see halo in this one.
airphoton
Fri Jul 28, 2017 3:23 pm
Ok, thanks. Here is another attempt at the Air China, again with more conservative settings for the levels:
airphoton
Sun Jul 30, 2017 10:26 am
I would like some feedback on this photo... is the edit ok for uploading?:
airkas1
Head Screener
Sun Jul 30, 2017 10:30 am
I would accept all 3 images. Nice work!
airphoton
Sun Jul 30, 2017 10:59 am
Ok, thanks! Good to know.
HarryLi
Sun Jul 30, 2017 12:03 pm
Nice editing ! All of them seems ok now ~!
airphoton
Thu Aug 03, 2017 5:33 am
Hello again!
I would appreciate feedback on these photos if they are okay or if there are any issues that I need to fix:
HarryLi
Thu Aug 03, 2017 2:08 pm
All of them are very nice shots ! But the EK and B757 look a bit of Overexposed to me. And regarding to the B757,when i use equalize to see, there is a little bit Halo very slight i have to say ,but still can see a little bit white dye above the tail. SAS looks ok for me. Did u use lots of High light in 757? Just guess because over using High Light and shadow will produce a little bit halo.
Harry
airphoton
Thu Aug 03, 2017 4:59 pm
Ok, thanks for the input. As for the Emirates the tail seems to be overexposed in the original and I don't think I can do that much more with the image.
I have done a different edit to the 757, this time again being more conservative with the level settings and no shadow/highlight changes:
Let me know what you guys think.
airkas1
Head Screener
Fri Aug 04, 2017 2:10 pm
The EK is OK for me (it's snowy conditions on the ground, right?)
The second version of the B757 is better, but still a bit bright on the whites
SAS seems passable
airphoton
Fri Aug 04, 2017 4:50 pm
Hi, yes the EK was taken during the winter with low sun and snow on the ground. I will have another go at the B757.
airphoton
Sun Aug 06, 2017 7:07 pm
Hi again, I was wondering if there are any issues with these two images that I need to fix:
Thanks for your feedback!
HarryLi
Mon Aug 07, 2017 3:26 pm
Both of them look ok for me.
Harry
airkas1
Head Screener
Tue Aug 08, 2017 9:23 am
They look fine here as well, very nice quality.
airphoton
Fri Aug 11, 2017 8:18 pm
Hello again, thanks for all the feedback so far. I would appreciate some feedback on this image, I have used slightly different sharpening settings and am wondering if it is ok:
HarryLi
Sat Aug 12, 2017 3:24 am
The sharpness of it looks ok to me.
Harry
airkas1
Head Screener
Mon Aug 14, 2017 3:37 pm
Looks alright to me as well.
airphoton
Wed Aug 23, 2017 4:26 pm
Hello again.
I got this image rejected for "soft": https://imgproc.airliners.net/photos/airliners/5/3/5/4529535.jpg?v=v49aa62ada29
Where do I need to apply more sharpening? Any advice would be appreciated.
airkas1
Head Screener
Wed Aug 23, 2017 5:29 pm
I would appeal that image, as it doesn't look soft at all to me.
HarryLi
Thu Aug 24, 2017 2:36 am
It looks alright to me.
airphoton
Thu Aug 24, 2017 4:14 am
Hi,
Unfortunately the appeal was rejected, now for noise and soft. I'm not sure I understand why though... does anyone have any advice?
YQZ380
Thu Aug 24, 2017 12:49 pm
The windows on the fuselage (especially towards the front) look soft to me. However, I do not see much noise.
Yang
Life is like an airliner; if you try to climb too much, you will stall.
airphoton
Sat Sep 09, 2017 1:00 pm
Hello again, I was wondering if this photo looks ok:
HarryLi
Sat Sep 09, 2017 3:24 pm
The Singapore A350 looks nice to me. Very nice quality !
airkas1
Head Screener
Sun Sep 10, 2017 2:29 pm
Looks perfectly fine!
