Degupukas
Pre-Screening
Wed Oct 04, 2017 3:53 pm
hi
could you please pre-screen
thanks
HarryLi
Screener In Training
Re: Pre-Screening
Wed Oct 04, 2017 4:32 pm
Hi,
It seems that i can't see the big version of your photos. Would you please share the link of your photos to us directly ? When i clicked these photos the pages showed me that "Sorry! Photo #4620383 is no longer available. "
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
airkas1
Head Screener
Re: Pre-Screening
Wed Oct 04, 2017 4:37 pm
Yeah, that format of linking photos only works with accepted photos. To link photos that are in your queue, please right-click the image in the photo corner and copy the URL. Then paste it here.
In any case, I just rejected the Copa, as it needs to be brighter. The B767 is obviously high in frame and a little soft at the nose.
https://imgproc.airliners.net/photos/air ... f0ec3654bb
Degupukas
Re: Pre-Screening
Wed Oct 04, 2017 4:54 pm
thanks HARRY LI and AIRKAS1
Degupukas
Re: Pre-Screening
Wed Oct 04, 2017 5:31 pm
airkas1
Head Screener
Re: Pre-Screening
Wed Oct 04, 2017 9:29 pm
"This photo is private.
Oops! You don't have permission to view this photo."
But I rejected that photo, as the fuselage and reg. look blurry. Soft at best. Perhaps you have a better photo from that sequence?
Degupukas
Re: Pre-Screening
Wed Oct 04, 2017 10:23 pm
hi, please prescreen
thanks
airkas1
Head Screener
Re: Pre-Screening
Thu Oct 05, 2017 9:28 am
Overexposed and needs CCW.
HarryLi
Re: Pre-Screening
Thu Oct 05, 2017 11:32 am
I agree with Kas that this one has obvious Overexposed and needs some CCW rotation.
vcruvinel
Support
Re: Pre-Screening
Thu Oct 05, 2017 11:49 am
I agree with Kas and Harry, it's overexposed and needs CWW.
Just a tip: When you do the steps from your workflow to editing the images, do not forget to check the horizon and vertical levels. Lightroom has a tools which correct this in most of the cases. If you want to do manually just put the grid and check this before start editing.
Find below your image with some points you can check horizon em verticial levels (mainly the vertical level)
Degupukas
Re: Pre-Screening
Thu Oct 05, 2017 6:17 pm
hello please prescreen
thank a lot
HarryLi
Re: Pre-Screening
Fri Oct 06, 2017 3:27 am
Hello ,
The cessna seems blurry the whole aircraft seems blurry and the gears seem to suffer from heat haze. Besides, the aircraft is not center as you see the space in the right side is much bigger than the left side.
The second one i think is marginal.
Delta: It looks blurry especially the cockpit windows and the Title of " Delta". And i think this one is also High In Frame too. Besides, some parts of it look Over-sharpened such as Reg , Title of " Skyteam ". I suggest you to use smaller size instead of using such a big size unless the origin one has very good quality.
Harry
Degupukas
Re: Pre-Screening
Sat Oct 07, 2017 5:57 am
hi
ImageGAE_3886-Edit-Edit.jpg by degupukas, en Flickr
thanks
airkas1
Head Screener
Re: Pre-Screening
Sat Oct 07, 2017 11:12 am
It looks a bit blurry.
Degupukas
Re: Pre-Screening
Tue Oct 10, 2017 12:24 am
hi team, please prescreen
thanks
HarryLi
Re: Pre-Screening
Tue Oct 10, 2017 1:51 pm
Hi ,
The Bahamas needs some CW rotation i think.
Costarica : Looks blurry to me.
Latam Cargo : Looks Blurry to me too especially the title and the tail.
TG-BEA : Looks bit of Over-sharpened to me. And maybe needs little bit CW rotation i think.
Harry
Degupukas
Re: Pre-Screening
Tue Oct 10, 2017 6:54 pm
hi team
let me know is ok the rotation
prescreen please
thanks
Degupukas
Re: Pre-Screening
Wed Oct 11, 2017 2:48 pm
hi team
could you pre-screen these photos
thanks
airkas1
Head Screener
Re: Pre-Screening
Wed Oct 11, 2017 3:10 pm
Bahamasair: needs CW and titles are a bit sharp.
Interjet: colors seem washed out (needs more saturation).
American: bit high in frame.
Interjet: overexposed.
Orion: high in frame, bit underexposed.
Degupukas
Re: Pre-Screening
Thu Oct 12, 2017 3:07 pm
HI team
please prescreen
thanks
HarryLi
Re: Pre-Screening
Fri Oct 13, 2017 3:51 pm
TI-AZT : Looks little bit under exposure to me otherwise look ok i think.
Fokker 100 : Looks low contrast and also there is space to increase exposure i think.
TI-GRE : Looks bit of blurry to me (some parts ) and could be brighter i think .
I think all of them could be fixed easily except for the Blurry ( Not quiet sure )
Harry
Degupukas
Re: Pre-Screening
Fri Oct 13, 2017 4:50 pm
HI crew
increase exposure
increase contrast
Degupukas
Re: Pre-Screening
Fri Oct 13, 2017 5:01 pm
hi crew
please prescreen
thanks Airkas1 and HarryLi for yours time
airkas1
Head Screener
Re: Pre-Screening
Fri Oct 13, 2017 5:39 pm
The C206 and CL30 are oversharpened (there are jaggies showing).
The C56X looks ok as is. The DHC6 is high in frame, but otherwise ok. Love that paintjob!
Degupukas
Re: Pre-Screening
Mon Oct 16, 2017 2:34 pm
hi team please prescreen
thanks for your time
airkas1
Head Screener
Re: Pre-Screening
Wed Oct 18, 2017 8:54 am
TI-AFO: oversharpened
TI-AEI: noisy, blurry tail. Will not make it
TI-AZT: looks ok
UA B737: looks ok
Volaris: looks ok
Caravan: bit underexposed and soft/blurry. Marginal at best
UA B737: nice, but needs a lot more contrast
Degupukas
Re: Pre-Screening
Wed Oct 18, 2017 11:35 am
TI-AZT: looks ok
UA B737: looks ok
Volaris: looks ok
Thanks Airkas1
Degupukas
Re: Pre-Screening
Fri Oct 20, 2017 1:46 am
first add more contrast let me know is ok?
Imagecwfi.jpg by degupukas, en Flickr
Imagecwfi-10.jpg by degupukas, en Flickr
Imagecwfi-9.jpg by degupukas, en Flickr
Imagecwfi-8.jpg by degupukas, en Flickr
Imagecwfi-7.jpg by degupukas, en Flickr
Imagecwfi-6.jpg by degupukas, en Flickr
Imagecwfi-5.jpg by degupukas, en Flickr
Imagecwfi-4.jpg by degupukas, en Flickr
Imagecwfi-3.jpg by degupukas, en Flickr
Imagecwfi-2.jpg by degupukas, en Flickr
thanks
airkas1
Head Screener
Re: Pre-Screening
Fri Oct 20, 2017 9:05 pm
UA: bit more contrast and less highlights
PA34: oversharpened
-ANI: bit sharp, but maybe passable
-BEJ: OS titles, overexposed outside
Cessna frontal: passable
-BBO: oversharpened, quite jaggy
-AWA: passable
Cockpit: was accepted earlier today
-BFJ: soft, oversharpened, blurry, quality, low in frame
-102P: CCW
Learjet: oversharpened, jaggy fuselage & engine inlets.
Degupukas
Re: Pre-Screening
Sun Oct 22, 2017 3:28 pm
Hi team please prescreen
thanks
airkas1
Head Screener
Re: Pre-Screening
Sun Oct 22, 2017 3:42 pm
That's a really nice shot and it look fine to me.
Degupukas
Re: Pre-Screening
Sun Oct 22, 2017 5:10 pm
thanks Airkas1
please prescreen
thanks
Degupukas
Re: Pre-Screening
Tue Oct 24, 2017 1:45 am
hi please prescreen
thanks
Degupukas
Re: Pre-Screening
Thu Oct 26, 2017 3:49 am
thanks
airkas1
Head Screener
Re: Pre-Screening
Thu Oct 26, 2017 9:37 am
P46T: very low contrast
NASA: quite oversharpened
B777: oversharpened, otherwise nice
Degupukas
Re: Pre-Screening
Fri Oct 27, 2017 11:06 pm
hi team could help me please
reject : Oversharpened Low Contrast Noise
thats new one let me know is ok
HarryLi
Re: Pre-Screening
Sat Oct 28, 2017 3:51 pm
Hi,
I did a quick editing to your photos in Contrast issue.
To be honest i don't have too much experience in editing night shots but i think it still could have more contrast as i showed above.
Regarding to the Sharpness problem. It still looks Oversharpened i think. Obvious Jaggys at the top side of the aircraft and title. Otherwise looks ok to me. Noise seems not bad to me. And it is a impressive night shot!
Harry
Degupukas
Re: Pre-Screening
Sun Oct 29, 2017 1:21 am
thanks Harry Li for your time
Miguel1982
Head Screener
Re: Pre-Screening
Sun Oct 29, 2017 8:41 pm
Harry's version shows that a kick of contrast has actually helped the shot. Regarding the sharpening issue, the titles and especially the tail show some jaggies. If you can reduce those, should be good to go.
BTW, same as with the SkyTeam shots, they are both very nice.
airkas1
Head Screener
Re: Pre-Screening
Sun Oct 29, 2017 9:09 pm
I agree with Harry & Miguel.
Degupukas
Re: Pre-Screening
Mon Nov 06, 2017 11:47 pm
HI Team please check those please
1,Image
2.Image
3.Image
4.Image
5.Image
6.Image
7.Image
thank a lot for your time
spompert
Re: Pre-Screening
Tue Nov 07, 2017 6:04 pm
Hi, all photos look oversharpened to me. Lot of jaggies around wings, lines and logos. The first Condor looks a bit too yellow while the American is low on contrast I think. The white B747 has a really strange look on the fuselage. Looks like some kind of editing? Too wide crop as well. Some of them are also a bit too bright I would say.
airkas1
Head Screener
Re: Pre-Screening
Wed Nov 08, 2017 9:25 am
Condor: blurry/soft front section
TAM: heathaze bottomside aircraft
B747: blurry/oversharpened
Condor: passable
Rouge: passable
AA: not a great crop on the tail, but could be passable
LAN: oversharpened titles & nosegear
Degupukas
Re: Pre-Screening
Mon Nov 20, 2017 11:13 pm
hello team please prescreen
1.Image
2.Image
3.Image
4.Image
5.Image
6.Image
HarryLi
Re: Pre-Screening
Tue Nov 21, 2017 1:57 pm
Hi,
The photos that you posted here seem to be compressed a lot by the website that you use. So i can't judge too much to it. The BA 777 seems soft to me especially the Windows , title, tail and the engin and it also seems bit of Blurry to me Iffy. Others is hard to judge as they were compressed.Some photos that you posted only have 200-30Kb. :?
Harry
Psych
Re: Pre-Screening
Tue Nov 21, 2017 4:00 pm
Hello.
All these look pretty decent to me (I don't have the compression problem to which Harry refers).
Copa 737: I see slight oversharpening in a few areas (such as the top of the fuselage behind the flightdeck area) and wing leading edge, but this is a bit picky. If it were my shot I would have been tempted to crop very slightly closer on either side.
F27: looks alright to me. Slightly soft in the forward fuselage area (see flightdeck windows).
Delta 757: Not too much to complain about there. Again, I would crop very slightly closer in on the right edge to lose that white area above the runway/taxiway.
American 737: I see jaggies again on the edge between fuselage and tail plane which I am guessing could be erased.
Cessna: Slight jaggies on the window of the door, but I am being very picky here. Is there something strange going on in the trees just above and to the right of the tail? I would expect it to look green but it looks misty. Could just be my ignorance.
BA 777: Very nicely exposed. I would have liked to see the complete tail in the crop - is that possible? I have a thing about cropped tail fins :D The front half of the fuselage definitely looks sharper than the rear half - it's those cabin windows. I love the blue lights.
Cheers.
Paul
airkas1
Head Screener
Re: Pre-Screening
Tue Nov 21, 2017 10:48 pm
Copa: looks alright
Air Panama: looks alright
Delta: looks alright
American: looks alright
C206: needs more contrast.
BA: poor tail crop (tail also looks soft/blurryish)
Degupukas
Re: Pre-Screening
Wed Nov 22, 2017 1:19 am
thanks a lot HarryLI , Psych and airkas1
Degupukas
Re: Pre-Screening
Wed Nov 22, 2017 1:30 am
1.Image
2.Image
3.Image
thanks
HarryLi
Re: Pre-Screening
Wed Nov 22, 2017 2:21 pm
AA looks ok to me.
King Air looks bit of Overexposed to me and it deserves more contrast i think.
Heli : Looks not bad but i will tend to reduce a little bit exposure.
Harry
