yousaf465
Re: Pre-screening
Sat May 09, 2020 6:40 am
Is it good enough, it was already past the golden hour. Image
yousaf465
yousaf465
Re: Pre-screening
Wed May 13, 2020 1:45 pm
Any issue with distance? or any other issues?
yousaf465
JakTrax
Re: Pre-screening
Wed May 13, 2020 10:52 pm
Would be much better if you cropped on the right by the same margin as the left (the gap between the aircraft nose and right frame-edge equal to the gap between the sun and left frame-edge). Looks unbalanced as is. Everything else looks good, save for perhaps a contrast boost.
Karl
jelpee
Head Screener
Re: Pre-screening
Thu May 14, 2020 1:02 am
I agree with Karl’s recommendation. You may also want to see how a 16:9 crop looks to avoid some of the dead space above and below. Otherwise looks nice.
Jehan.
yousaf465
Re: Pre-screening
Thu May 14, 2020 3:32 am
Jehan.
Thanks, edited as advised by both. Is is good enough crop? Contrast also increased enough?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Thu May 14, 2020 11:13 am
I'd go with a tighter crop on the sides.Still looks like empty space on either side. As Karl suggested, perhaps a little more contrast would enhance the appearance as well.
Jehan
yousaf465
Re: Pre-screening
Thu May 14, 2020 4:01 pm
Jehan
does this improve things?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Thu May 14, 2020 5:12 pm
The aircraft looks a bit High in the Frame. However, for me it is acceptable. When you're uploading it, I would add a comment to the screeners that you have centered the based on top of the aircraft and the bottom of the sun just so they are aware of your motive for the slight HIF.
Looks good and acceptable if it was in the queue for me to screen. Hope to see it on the site.
Jehan
yousaf465
Re: Pre-screening
Thu May 14, 2020 5:20 pm
Jehan
tail will not cause any problem?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Thu May 14, 2020 7:02 pm
What's your concern with the tail?
yousaf465
Re: Pre-screening
Thu May 14, 2020 10:59 pm
Hot iron effect due to the closeness to the sun in the picture.
yousaf465
yousaf465
Re: Pre-screening
Fri May 15, 2020 1:42 pm
If that wasn't enough, this was shot today.
yousaf465
jelpee
Head Screener
Re: Pre-screening
Fri May 15, 2020 3:09 pm
I like that second shot...prefer it to the first. I'd tighten the crop more so as to avoid dead space on either side and also center the airplane in the frame.
Good stuff!
Jehan
yousaf465
Re: Pre-screening
Fri May 15, 2020 3:26 pm
Good stuff!
Jehan
Thanks, man, different lens, different A/c and different day.
yousaf465
yousaf465
Re: Pre-screening
Tue May 19, 2020 10:43 am
HarryLi wrote:
Hi Yousaf,
Flynas A320 looks not bad to me overall.Color looks fine from my side as well, but the quality at the sky seems kind of iffy as it looks noisy / compression at my side. I probably would second opinion this one by mentioning CW slightly and marginal sky quality since the I am iffy about the level. Sharpness, contrast and others look not bad for me.
Hope that helps.
Rgrds,
Rejected for
SCREENER DECISION:
Rejected
High in FrameLow Contrast
How is it High in the frame?
I think some times screener start popping pills before screening. Should I appeal?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Tue May 19, 2020 12:46 pm
Centering seems acceptable to me. I would appeal, if I were you.
Jehan
yousaf465
Re: Pre-screening
Tue May 19, 2020 3:18 pm
Jehan
contrast is fine?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Tue May 19, 2020 3:46 pm
yousaf465 wrote:
Jehan
contrast is fine?
If you're planning on just appealing and HIF was the only issue identified, then the contrast is passable. Wouldn't hurt to boost the contrast a bit, but for me it is not a show stopping issue.
yousaf465
Re: Pre-screening
Tue May 19, 2020 4:00 pm
jelpee wrote:
yousaf465 wrote:
Jehan
contrast is fine?
Here are screeners comments
SCREENER DECISION:
HQ1
Rejected
High in Frame
Low Contrast
Should I appeal or upload again?
Also please comment on this image too, what category I should select and whether it should be marked for creative team?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Tue May 19, 2020 4:41 pm
Re the A320, since it was marked as low contrast, I would fix that and reupload as opposed to appealing. In the future, please list all reasons for rejection otherwise it is hard to make recommendations on weather to appeal or edit and resubmit.
For the silhouette, you can check Creative Screening.
yousaf465
Re: Pre-screening
Tue May 19, 2020 5:17 pm
I quoted the whole screener's comments for A320.
This is the histogram for the aircraft only, how can I improve on the contrast?
For DHL 767 the category will be Cargo?
yousaf465
yousaf465
Re: Pre-screening
Thu May 21, 2020 3:46 pm
Any chance of this being added to Database?
yousaf465
JakTrax
Re: Pre-screening
Thu May 21, 2020 4:11 pm
Low contrast and affected by heat-haze.
yousaf465
Re: Pre-screening
Mon May 25, 2020 12:33 pm
This registration is not in database.
yousaf465
jelpee
Head Screener
Re: Pre-screening
Mon May 25, 2020 7:31 pm
I see your silhouette image got accepted. Nice!
Salam Air is over sharpened, underexposed and low contrast. I'd say it is a non starter.
Jehan
yousaf465
Re: Pre-screening
Tue May 26, 2020 3:31 am
Jehan
Thanks, and it is in PC too.
yousaf465
yousaf465
Re: Pre-screening
Fri Jun 05, 2020 2:20 am
Please pre-screen. Early morning.
yousaf465
HarryLi
Screener
Re: Pre-screening
Sat Jun 06, 2020 12:28 am
Hey Yousaf,
Beautiful morning light. It looks low contrast for me mainly, and the rear parts seems blurry / soft feeling for me. Not sure whether it's the effect from the engines of something else. Would be better for you to add some exposure / brightness after increasing some contrast in this case.
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
yousaf465
Re: Pre-screening
Sun Jun 07, 2020 5:51 am
HarryLi wrote:
Hey Yousaf,
Thanks.
My only concern is how do you add exposure/brightness after increasing contrast in PS with curves tools?
yousaf465
HarryLi
Screener
Re: Pre-screening
Sun Jun 07, 2020 3:30 pm
Hi Yousaf,
If you want to use Curve to adjust them, would be better to do both at the same time by using Curve since contrast and brightness / exposure are related to each other to some extent.Here's what I will do, you can try it to see the effect on your images.
BTW, Curve is not the only way you can adopt for this kind of issues, but it's your choice ; )
yousaf465
Re: Pre-screening
Sun Jun 07, 2020 6:01 pm
HarryLi wrote:
Hi Yousaf,
I can use any method recommended. I will definitely try it like this on my image. Which other method I should use to fix this?
yousaf465
yousaf465
Re: Pre-screening
Sun Jun 07, 2020 6:02 pm
yousaf465 wrote:
HarryLi wrote:
Hi Yousaf,
Regards.
yousaf465
yousaf465
Re: Pre-screening
Tue Jun 09, 2020 12:51 pm
Second visit of the same aircraft. this seems better to me. hopefully, it passes the test
yousaf465
tiziostanco
Head Screener
Re: Pre-screening
Tue Jun 09, 2020 2:40 pm
Hi, sorry, this one will be 100% rejeted.
Flat (low contrast), poor sky quality/noisy sky, heat haze, soft and over sharpened to compensate. Dirty: speck visible, lower-left sector.
Regards.
Fabrizio
yousaf465
Re: Pre-screening
Mon Jun 22, 2020 1:42 pm
yousaf465
JakTrax
Re: Pre-screening
Mon Jun 22, 2020 2:42 pm
Quality's just not there for me — soft, slightly magenta, low contrast...
yousaf465
Re: Pre-screening
Thu Jun 25, 2020 5:04 pm
Is this any better?
yousaf465
yousaf465
Re: Pre-screening
Mon Jun 29, 2020 4:55 pm
No reply?
yousaf465
JakTrax
Re: Pre-screening
Mon Jun 29, 2020 7:48 pm
Looks better to me. Not keen on the colour but that's just the hazy nature of the skies where you are.
Karl
yousaf465
Re: Pre-screening
Tue Jun 30, 2020 2:41 am
Karl
Worth uploading?
yousaf465
yousaf465
Re: Pre-screening
Sun Jul 12, 2020 6:20 am
Is this worth occupying an upload slot?
yousaf465
yousaf465
Re: Pre-screening
Thu Jul 23, 2020 5:04 am
Anything which requires fixing?
yousaf465
HarryLi
Screener
Re: Pre-screening
Thu Jul 30, 2020 1:11 am
The quality for this one is veyr marginal I think. There's a obvious flares from light in the background above the nose of the aircraft.Looks some cw rotation might be needed as well. A little bit right in frame since the space in the left side is larger than the right one.
HarryLi
Screener
Re: Pre-screening
Thu Jul 30, 2020 1:13 am
This one is very low contrast obviously I think. I can see slight heat haze along with the top edge of the aircraft in this case, and the size is too large to satisfy this standard in this case as well. Sorry.
Rgrds,
yousaf465
Re: Pre-screening
Thu Aug 06, 2020 5:11 am
Any issues?
yousaf465
HarryLi
Screener
Re: Pre-screening
Thu Aug 06, 2020 5:32 pm
Looks not bad at this size for me ; )
dutchspotter1
Re: Pre-screening
Sat Aug 08, 2020 12:18 pm
HIF, CCW rotation.
NO URLS in signature
yousaf465
Re: Pre-screening
Mon Aug 10, 2020 3:16 pm
dutchspotter1 wrote:
HIF, CCW rotation.
Where is the horizon. As for HIF...
yousaf465
yousaf465
Re: Pre-screening
Mon Aug 10, 2020 3:29 pm
Pre-screen please.
yousaf465
