jelpee
Head Screener
Re: Pre-screening
Sat Apr 18, 2020 10:49 pm
I recommend a crop such as shown below:
The bird: best to remove it.
Blurry: seems all over.
Overall lighting is not the best. Top of cockpit area is over exposed. Image looks quite washed out, i.e. lacking contrast.
Hope this helps!
Jehan
yousaf465
Re: Pre-screening
Sun Apr 19, 2020 10:10 am
Is this fixed enough for upload.
yousaf465
jelpee
Head Screener
Re: Pre-screening
Sun Apr 19, 2020 1:00 pm
Looks quite oversharpened for me. Jaggies are bad on the main titles. Looks overexposed towards the front as well.
Jehan
yousaf465
Re: Pre-screening
Sun Apr 19, 2020 3:33 pm
Does this imporve anything. Screenshot of Histogram is attached. Image
yousaf465
jelpee
Head Screener
Re: Pre-screening
Sun Apr 19, 2020 4:31 pm
Looks passable actually.
Jehan
yousaf465
Re: Pre-screening
Sun Apr 19, 2020 4:59 pm
Jehan
No need to work on it? Should work another frame? Or should I upload ?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Sun Apr 19, 2020 5:44 pm
I think it has a fair chance of acceptance (screener discretion); you may have better frames that may increases the chances of acceptance. Please post so we can comment on it.
Jehan
JakTrax
Re: Pre-screening
Sun Apr 19, 2020 6:12 pm
This is being a bit picky but it still looks a touch flat to me — perhaps a little saturation would improve its chances?
yousaf465
Re: Pre-screening
Tue Apr 21, 2020 3:09 pm
Taken while the sun was going down. Is it any better than previous?
yousaf465
JakTrax
Re: Pre-screening
Tue Apr 21, 2020 4:39 pm
One of the biggest issues with this kind of shot is that a lot of the area of the aircraft you're shooting is dark (i.e. in shadow). If this aircraft were level with you your camera would be metering a pretty uniform scene, however at this angle it's struggling to balance the highlights and shadows.
yousaf465
Re: Pre-screening
Tue Apr 21, 2020 5:26 pm
Thanks, I was using centre weight metering. Anyway, it helps with practice, what I am concerned about is skies are unpolluted these days so light is much better.
yousaf465
yousaf465
Re: Pre-screening
Fri Apr 24, 2020 8:25 am
Please comment on any issues with this image.
yousaf465
JakTrax
Re: Pre-screening
Fri Apr 24, 2020 6:02 pm
Blurry with a very heavy yellow/red colour cast.
jelpee
Head Screener
Re: Pre-screening
Fri Apr 24, 2020 9:12 pm
I agree. Quality is just not there on this one.
Jehan
yousaf465
Re: Pre-screening
Wed Apr 29, 2020 11:12 am
Jehan
Location as off airport is correct for this type of shot?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Wed Apr 29, 2020 12:15 pm
This from the information link on the photo upload page re. location:
Your image looks like it is part of the traffic at an airport? If so, please use the airport as location.
Jehan
yousaf465
Re: Pre-screening
Thu Apr 30, 2020 12:12 pm
Image rejected for being soft, does this improve anything or should I add more sharpening.
yousaf465
JakTrax
Re: Pre-screening
Thu Apr 30, 2020 4:54 pm
Sharpness looks acceptable on my screen but the image still looks flat to me. If it's taking this much work to get it accepted it's probably one to abandon.
yousaf465
Re: Pre-screening
Thu Apr 30, 2020 6:03 pm
In both images or the second one? By flat means lacks contrast or saturation?
This was a rare spotting location, and add in the lockdown factor it was a rare image.
yousaf465
yousaf465
Re: Pre-screening
Thu Apr 30, 2020 6:31 pm
Is this image shilouette or backlit?
yousaf465
JakTrax
Re: Pre-screening
Thu Apr 30, 2020 7:10 pm
Your sunset shot would be much better in portrait (which would crop out some of the distracting lens flares — the remaining ones you could deal with). There's banding in the sky too but that's now acceptable.
jelpee
Head Screener
Re: Pre-screening
Thu Apr 30, 2020 9:26 pm
While I'm sure that JakTrax can point to specific cased of accepted images that show banding, those instances have been addressed with the respective photographers. The level of banding in your image would not be acceptable.
Jehan
johnr
Re: Pre-screening
Thu Apr 30, 2020 10:19 pm
It could be accepted with “screener discretion” I suppose.
yousaf465
Re: Pre-screening
Fri May 01, 2020 5:24 pm
Is it edited good enough or any particular issues.
yousaf465
kann123air
Re: Pre-screening
Sun May 03, 2020 4:41 am
Looks okay to me. Picky, but I think its a tad soft, and a brightness boost wouldn't hurt. With that said, I'm not used to shooting/editing darker paint schemes, so take my advice with a grain of salt.
Going for great
yousaf465
Re: Pre-screening
Sun May 03, 2020 6:55 am
I had photo rejected, even after Head screener @jelpee thought those were passable. :( This is version, I edited for a little bit more contrast.
yousaf465
kann123air
Re: Pre-screening
Sun May 03, 2020 7:03 am
It happens, buddy. Screeners are humans too. They won't agree with each other 100% of the time. It's just the way it is.
Going for great
yousaf465
Re: Pre-screening
Sun May 03, 2020 4:57 pm
Please pre-screen this image.
yousaf465
JakTrax
Re: Pre-screening
Sun May 03, 2020 6:49 pm
Generally looks okay to me but a touch yellow.
kann123air
Re: Pre-screening
Sun May 03, 2020 8:50 pm
I second Karl's comments. Nice shot, man!
Going for great
yousaf465
Re: Pre-screening
Mon May 04, 2020 9:38 am
Bright sunny day? No issues beside it?
yousaf465
HarryLi
Screener
Re: Pre-screening
Mon May 04, 2020 11:06 pm
Hi Yousaf,
Flynas A320 looks not bad to me overall.Color looks fine from my side as well, but the quality at the sky seems kind of iffy as it looks noisy / compression at my side. I probably would second opinion this one by mentioning CW slightly and marginal sky quality since the I am iffy about the level. Sharpness, contrast and others look not bad for me.
Hope that helps.
Rgrds,
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
kann123air
Re: Pre-screening
Mon May 04, 2020 11:45 pm
Yeah, I'm not the biggest fan on the sun angle as Harry said, but it is likely passable nonetheless.
Going for great
yousaf465
Re: Pre-screening
Tue May 05, 2020 12:57 pm
HarryLi wrote:
Hi Yousaf,
Hope that helps.
Rgrds,
Thanks, HarryLi.
How do measure/see compression in a photo? I levelled it by the horizon and vertical part of the conveyer.
yousaf465
JakTrax
Re: Pre-screening
Tue May 05, 2020 7:40 pm
It would likely look better with 0.1 or 0.2 degrees of rotation but since there are no reliable verticals it would be a bit picky to reject for 'level'. I still think the colour is more of an issue.
yousaf465
Re: Pre-screening
Wed May 06, 2020 4:14 pm
I edited it on a calibrated monitor. In your view, there is a yellowish cast?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Wed May 06, 2020 10:59 pm
Color balance appears OK for me.
Jehan
yousaf465
Re: Pre-screening
Thu May 07, 2020 8:12 am
Jehan
any other issues? Should I upload or not?
yousaf465
jelpee
Head Screener
Re: Pre-screening
Thu May 07, 2020 11:53 am
yousaf465 wrote:
Jehan
Go ahead and upload it. I don't see any show stopping flaws.
Jehan
yousaf465
Re: Pre-screening
Thu May 07, 2020 3:45 pm
jelpee wrote:
yousaf465 wrote:
Jehan
Jehan
Actually I don't want the repeat of this https://www.airliners.net/user/photo-co ... to/5983257. First, it was dismissed as soft and then as blurry?
I try to upload only those photos for which I am absolutely sure, it will make the mark.
Hopefully, this does.
yousaf465
jelpee
Head Screener
Re: Pre-screening
Thu May 07, 2020 5:24 pm
yousaf465 wrote:
Jehan
Don't be so hard on yourself. When I have my images rejected, if the feedback is valid, I edit the image and resubmit. If I disagree with the rejection, I appeal. If the image is denied on appeal, I just keep it for my personal collection and move on. Nothing to lose by submitting (except for perhaps a temporary loss one's pride in the case of a rejection) and everything to gain. No guarantees in life except Death and Taxes, as they say.
Jehan
p.s. And yes, even my images are rejected by my fellow screeners.
yousaf465
Re: Pre-screening
Thu May 07, 2020 5:40 pm
jelpee wrote:
yousaf465 wrote:
Jehan
Jehan
Hmm.
I am concerned about the ratio, already sitting at 50%. Does it affect future uploads?
I have learnt a lot in my 14 years of A.net membership, but only have 3 static upload of heli's only. :)
yousaf465
kann123air
Re: Pre-screening
Thu May 07, 2020 9:11 pm
Doubt it. I have 488 images on the site and I'm sitting at 56% right now. Don't beat yourself up.
Amrit
Going for great
jelpee
Head Screener
Re: Pre-screening
Thu May 07, 2020 9:49 pm
Amrit
Amrit is spot on. No impact to future uploads. The only issue limiting uploads is the number of accepted images which determines how many you can have in the upload queue at any one time.
And agree with that "Don't beat yourself up" comment as well :)
Jehan
yousaf465
Re: Pre-screening
Fri May 08, 2020 2:26 pm
Are these kind of enivormental shots allowed.
yousaf465
jelpee
Head Screener
Re: Pre-screening
Fri May 08, 2020 2:36 pm
Silhouette shots such as these are accepted subject to meeting the other guidelines such as distance, sharpening noise, centering, etc. Non-centered aircraft may be accepted if there is sufficient motive. e.g. to accommodate an aerial/celestial, or land feature. Here's a non centered shot of mine with motive that is in the DB.
https://www.airliners.net/photo/United- ... /5779591/L
Jehan
JakTrax
Re: Pre-screening
Fri May 08, 2020 3:12 pm
Yousaf,
Nice enough shot but I don't see anything in the frame to justify the wide crop
yousaf465
Re: Pre-screening
Fri May 08, 2020 3:19 pm
JakTrax wrote:
Yousaf,
Thanks, JakTrax.
I cropped to keep the sun in the frame. Secondly, the aircraft is not large enough.
yousaf465
yousaf465
Re: Pre-screening
Fri May 08, 2020 3:37 pm
Is this worth working on? any particular issues?
yousaf465
JakTrax
Re: Pre-screening
Fri May 08, 2020 5:01 pm
Better to do a portrait or square crop I think (if the latter are allowed).
