  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Runway28L
Re: Improvements and Opinions
Sun Jan 21, 2018 4:42 am
jelpee wrote:
I cannot access the RAW files for which you have shown the links. It takes me to my own Dropbox account. As Stefan as offered as well, if you can send an original as a PM I'd be happy to look at it as well and try an edit for you.
Jehan
My apologies, I'll PM them to you as soon as I regain access to my computer.
Runway28L
Sun Jan 21, 2018 7:08 am
Jehan, I sent you a PM. What is your email address in case the PM still didn't work?
airkas1
Sun Jan 21, 2018 9:56 am
Those links lead me to my own Dropbox, so I'm unable to view them.
jelpee
Head Screener
Sun Jan 21, 2018 3:13 pm
I PM'd you back with my email address so you can attach the original file.
Jehan
Runway28L
Wed Jan 24, 2018 6:18 am
Hello everyone,
Jehan and I were able to find a fix for the image quality issue. I went back and re-edited some images while also starting on some new ones.
Re-edits
N744P: http://imgur.com/93OV8sb
N838AW: http://imgur.com/7gQxmiT
N304FR: http://imgur.com/aiWJIxs
70-461: http://imgur.com/mCkzzN5
New batch of images
N835AW: http://imgur.com/MdAIAHm
N717FR: http://imgur.com/tpwsIKm
TF-NEO: http://imgur.com/oZnnIzB (I'm a bit worried that this one is OS)
N9629H: http://imgur.com/4sAAVN9
N946WN: http://imgur.com/d3KIsWk
N566WN: http://imgur.com/cMK9ECq
Runway28L
Wed Jan 24, 2018 5:21 pm
And here is one more :)
http://imgur.com/uHrXg2y
airkas1
Wed Jan 24, 2018 10:52 pm
Re-edits:
AA: not bad, but still a little iffy for some reason
AA: overexposed, flat
F9: overexposed, oversharpened
Tail: bit soft (except for red banner & flag)
New:
AA: overexposed
WW: flat
AA: oversharpened windowline but otherwise nice
SW: blurry, quality
SW: blurry, quality
AF1: flat, oversharpened
Some of them do still look a bit iffy for some reason, but I can't really pinpoint it. Also, am I correct in assuming that there is snow on the ground where you took those photos?
Runway28L
Thu Jan 25, 2018 12:53 am
Hi Kas,
OS at the engines and front of fuselage maybe???
Will go back and adjust the exposure and boost the contrast up.
I agree with OS, will fix that and fix the exposure
Alright, will try to boost the sharpening up a bit
airkas1 wrote:
AA: overexposed
Will fix the exposure on both and OS on F9
airkas1 wrote:
WW: flat
Ok, will give it more contrast
Darn, so close! :D I won't hit the windows with the sharpening tool this time
airkas1 wrote:
SW: blurry, quality
SW: blurry, quality
Tried to address that on both, but they ended up being OS quickly. Oh well...
Will boost the contrast and try to sharpen it less.
To answer your question: yes, we did have snow on the ground for all of those images. Most likely why some of them are overexposed.
Runway28L
Thu Jan 25, 2018 3:45 am
And three more I just completed
N427UA: http://imgur.com/KxGk5Md
N601AW: http://imgur.com/Q41rKMr
N836NN: http://imgur.com/ZmMjUuP
len90
Thu Jan 25, 2018 5:19 am
The only three I found issue with were TF-NEO for the color looking off, AF1 but that could just be the chrome belly causing that really washed out color, and N304FR looking dark especially when viewed right after N717FR.
Len90
Runway28L
Thu Jan 25, 2018 5:34 am
Hi Len... were you looking at the original link for TF-NEO or the most recent link I just posted of it?
Regarding N304FR it was a bit of a challenge trying to find a balance between contrast and the exposure since raising both even at the slightest made the image overexposed. I'm probably going to go back and try that one again anyways.
airkas1
Fri Jan 26, 2018 2:40 pm
N835AW has a blotchy top of sky now.
N304FR is indeed underexposed now and needs more brightness.
AF1 actually looks a little blurry upon looking at it just now. Also needs deeper black as it looks a bit washed out in general. Also noise/poor sky.
The rest looks alright I think.
Runway28L
Fri Jan 26, 2018 3:18 pm
Kas, thank you as always for your helpful input. :D I'll go back and fix the first two.
Re AF1 I was already iffy about that one since it seemed like the front part of that image where the nose is had more noise and blur than the rest of image. Was just curious due to the obvious importance of that bird.
Two more I completed :smile:
N304JB: http://imgur.com/wkGMtyE
N280WN: http://imgur.com/c6bjAx6
^^ I know there's haze in the background but I didn't see any touching parts of the aircraft so I just decided to go ahead and proceed, but would that still warrant an immediate rejection?
Runway28L
Fri Jan 26, 2018 3:19 pm
Also, N838AW and 70-0461 are currently in the queue awaiting to be screened.
airkas1
Fri Jan 26, 2018 3:29 pm
Unfortunately the JB looks blurry :(
Heat haze in an image is no issue, as long as the main subject is not affected. But it looks like it did affect the aircraft, as it looks quite marginal. It also needs a much tighter crop than is currently the case. I would advise cropping the left side just near the tail, roughly equal space as between the engine and right side of the frame.
Runway28L
Fri Jan 26, 2018 4:19 pm
Ok, any opinions on these two of 280?
http://imgur.com/F0jQ0Bx
http://imgur.com/EsBtBfK
Runway28L
Sat Jan 27, 2018 3:03 am
HarryLi
Screener
Sat Jan 27, 2018 2:29 pm
The first 280 : The quality of it looks very poor. It seems to be suffered from Heat Haze i think. Blurry ,Soft to me. And i also can see obvious purple edge at the stabilizers.
The second 280 : Looks better than the first one but still has problem. Underexposed/Dark to me. Bit of low contrast. Slight blurry to me.
I did a quick edit of the exposure of the second 280 (I only edited the exposure and contrast and didn't do anything else):
Sharpness of it looks iffy to me.
N304FR : As i can't open the link about it that you posted here before so i can't compare it. But it looks Oversharpened to me and I'll reduce bit of exposure of it to make it more comfortable.
N835AW : Looks fine to me although i prefer to reduce bit of exposure.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
Runway28L
Sat Jan 27, 2018 6:03 pm
Harry, would you mind sharing what presets you used to get that level of exposure and contrast?
On Lightroom I had Exposure set to +0.30 and Contrast at +30 for that image.
Ok, thank you :smile: I'll also go back and do my own version of that one again and try to find an acceptable level and reduce the sharpening. Sorry about the link not working.
New version: http://imgur.com/ovClFfC
I barely reduced the exposure as adding more made the image too dark I thought, so I also reduced the "whites".
HarryLi
Screener
Sat Jan 27, 2018 11:35 pm
I don't use Lightroom to adjust it. I usually use Photoshop to adjust most of processes of spotting photos. I can PM you the settings later as I am not using my Computer yet.
HarryLi
Screener
Sun Jan 28, 2018 1:27 am
The new version of N835NW now looks underexposed. You can see it through the Histogram and the photo does look underexposed.
Besides, it seems that i can't open those links now. Once i open those new links the Old links can't open to me.
Runway28L
Sun Jan 28, 2018 2:49 am
It's probably because when I insert the newest file I delete the old one, so that's likely why you can't see them. I'll leave up the old images up this time.
Btw I received your PM, Harry. Thank you for the info you sent me :)
A few more I'll add:
http://imgur.com/2gJqx2r
http://imgur.com/xmgsVZZ
Runway28L
Sun Jan 28, 2018 3:05 am
New version of N835AW. Let's hope I got it right this time :white:
http://imgur.com/oNvk5pi
HarryLi
Screener
Sun Jan 28, 2018 5:12 am
The latest Version of N835AW looks ok to me now although i will use Black Straw to touch the gears because i've tried in my PS base on this latest version and it looks more comfortable you can have a try.
I am not sure about the KC-135 especially the Composition.
JetBlue: Oversharpened, underexposed, Low Contrast i think.
Harry
Runway28L
Sun Jan 28, 2018 5:27 am
Would it be the end of the world if I didn't? I hit the gears with the sharpening tool at 50% strength and thought that was good enough to my liking.
I wasn't sure about it either, that's why I posted it in here ;) If it isn't then no biggie. I have several other files of it.
:frown: So it's pretty much a goner? Lighting for that pic wasn't very good to start with as the terminal was blocking almost all of the sun.
HarryLi
Screener
Sun Jan 28, 2018 5:32 am
The current one looks ok to me actually. So it depends on you !
For the JB ... I will let it go as the quality seems not so great to me to be honest.
Runway28L
Sun Jan 28, 2018 5:39 am
Alright, I'm comfortable with how it currently is so I'll go through with that version.
As far as JetBlue goes, I agree with you and will bin it sadly.
airkas1
Sun Jan 28, 2018 11:03 am
N835AW does look passable to me as well.
The JB is poor quality unfortunately and the KC135 looks a bit blurry
Runway28L
Sun Jan 28, 2018 4:36 pm
Guys, N838AW and 70-0461 were both rejected :(
70-0461:
Blurry
N838AW:
Editing
Noise
Oversharpened
Quality
Personal message "oversaturated"
Here are the links to the two again:
http://imgur.com/lgYIjqa
http://imgur.com/xekSXiM
airkas1
Sun Jan 28, 2018 8:42 pm
70-0461: https://imgproc.airliners.net/photos/air ... 1fbdcb33e3
N838AW: https://imgproc.airliners.net/photos/air ... b47b5639f0
I'd let the tail shot go, but the AA should be fixable. Maybe a little bit more noise reduction and a little less sharpening perhaps and it should be alright. I disagree with blurry, editing and quality.
UA: blurry at the back and front (especially nosegear).
SW: blurry/soft.
AA: blurry/soft.
AA: blurry at the back and front (especially nosegear).
UA: passable for me.
Runway28L
Sun Jan 28, 2018 9:12 pm
Thanks, Kas! What do you suggest in reducing the noise for AA? I sometimes use the Reduce Noise filter on PS but I'm not sure how effective it is.
I don't know how there was an "over saturation" since I didn't even touch the saturation tool at all. Maybe it was from adding contrast...?
Would it not hurt if I barely took some color out to try and avoid an over saturation rejection again? It seems to me the color on that one is a bit similar to the AA.
airkas1
Sun Jan 28, 2018 9:35 pm
I use the RAW converter or dfine2 ( the latter comes with the free Google NiK software that is widely available for Photoshop. If you Google it, you should be able to easily find it I think). As for the color on the Ua, it's ok for me as is. The AA didn't look oversaturated to me either.
Runway28L
Sun Jan 28, 2018 10:36 pm
Thanks, Kas. I'll download the NiK software to my computer.
http://imgur.com/HaGaimo
Reduced the background noise by a lot and slightly reduced some showing on the underside of the fuselage. Also reduced the sharpening filter from 80% down to 65%.
Runway28L
Wed Jan 31, 2018 5:23 pm
Hello everyone. I have a few Deltas I'd like to add to the database:
http://imgur.com/MRnjmNa
http://imgur.com/9NekveQ (Previously showed this one but it has better quality this time)
Here is N838AW revised:
Runway28L
Thu Feb 01, 2018 7:40 pm
Oops, forgot to add this Delta too
http://imgur.com/Uj9LuO4
HarryLi
Screener
Fri Feb 02, 2018 2:54 am
N838AW : Looks better than last one.
N965DL : Looks bit of underexposed to me.
N906DE : Slight overexposed to me, i would tend to redce little bit Highlight. Also looks little bit oversharpened and blurry toward the windows.
Delta B738 : "Underexposed" is for sure to me. Obvious vignettings at the upper left and right corner. Looks bit of blurry (not quiet sure).And the aircraft looks bit of too green to me .
Harry
Runway28L
Fri Feb 02, 2018 3:42 pm
Thanks, Harry! I might just bin the last two Deltas then and work on the first one.
The AA MD-80 successfully passed screening, but N835AW was rejected for Noise and OS. Noise I could agree with as there is some in the background that I probably should've fixed but I don't see any indication of OS.
Runway28L
Sat Feb 03, 2018 9:41 pm
Here are some I took today.
These two are of the same aircraft. Which one should I go with for uploading?
http://imgur.com/MXXqeMZ
http://imgur.com/vAGrSBg
Same scenario for this one:
http://imgur.com/sNyvfVZ
http://imgur.com/qoYKZqc
HarryLi
Screener
Sun Feb 04, 2018 3:58 am
N310NV 2: Some parts look oversharpened to me.
N310NV 1: Looks iffy to me and some look slight Oversharpened.
N8711Q 1: Blurry and Oversharpened to me.
N8711Q 2: Looks better but it seems bit of Low in Frame to my taste.
Harry
Runway28L
Sun Feb 04, 2018 6:28 pm
New version: http://imgur.com/3bHspQ0
Hit every jaggy area I could find with the eraser tool and was more conservative with the sharpening tool this time.
New version: http://imgur.com/SjAbgSG
The prior image I wanted it to have a "straighter" angle while landing but that was the highest I could get it in the frame. So this time I gave it some CCW to try and raise it in the frame.
Runway28L
Mon Feb 05, 2018 12:11 am
I also have this photo:
http://imgur.com/NDi9wqY
It's a relatively new delivery that is not in the database yet.
airkas1
Mon Feb 05, 2018 2:53 pm
The Allegiant and Southwest are marginal, with the SW also being oversharpened.
The United is noisy and oversharpened as-is, but not seems fixable.
Runway28L
Mon Feb 05, 2018 7:45 pm
By marginal, are you referring to the levels shown on the histogram? I am wondering because the exposure looks fine but that's only when the level is heavily skewed to the right side of the graph. I understand that the goal is to get a balance of the right amount of exposure and at the same time get the levels at or close to the middle of the graph.
airkas1
Mon Feb 05, 2018 7:55 pm
The exposure looks ok. But when I say marginal, I mean that the quality is marginal in general. I usually use that when it's hard to point out the issues, but the general quality just doesn't look right and I wouldn't attempt to upload that photo.
Runway28L
Tue Feb 06, 2018 1:14 am
Ok thank you for clarifying that, Kas.
Runway28L
Thu Feb 08, 2018 5:50 pm
Three photos I entered into the database that another site previously accepted were rejected by Anet.
-Grainy, Halos, Low Contrast
N653RW: http://imgur.com/xtAm2T4
-Blurry, Grainy, Halos
-Blurry, Grainy, Halos, Low Contrast
N838AW was accepted on its second try and so was TF-NEO.
The color on both don't seem right at full size. Is there a way to fix that through a reupload?
airkas1
Thu Feb 08, 2018 6:59 pm
I just added the reuploads, so the color issue should be fixed shortly.
427UA: seems passable
653RW: seems passable
836NN: perhaps a little blurry towards the back
Runway28L
Thu Feb 08, 2018 8:55 pm
I went back and changed the color settings to sRBG this time and the color looks normal again. I wonder why PS will sometimes randomly not save my images as sRBG.
I get that different sites may have different standards, but it just seems odd that JetPhotos accepted those three but Anet rejected them with similar reasons given. Would it be worth appealing all three or could I just go back and modify them and place them through the queue again?
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Users browsing this forum: No registered users and 4 guests
