• 1
  • 3
  • 4
  • 5
  • 6
  • 7
Wordpress
Re: Improvements and Opinions
Wed Nov 21, 2018 2:28 pm
Runway28L wrote:
More rejection help.
https://imgproc.airliners.net/photos/ai ... a331da742c
Rejected for Blurry, OS, Overexposed
Again, not seeing any blur in the original file. I even had someone suggest that this image was underexposed before I added it to the queue.
Seems like there’s been a ton of blurry rejections recently. :?
I'd wait for Kas, but me personally, I don't see blur or OS. I do agree with it being overexposed though, turn it down a couple notches.
airkas1
Head Screener
Wed Nov 21, 2018 2:46 pm
It's a bit too sharp and the whites of the fuselage look overexposed. Not seeing an unpassable amount of blur though.
Runway28L
Wed Nov 21, 2018 4:50 pm
Thanks guys. I’ll go ahead and make changes. I’ll note the blur in a comment.
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
Runway28L
Wed Nov 28, 2018 9:33 pm
The Alaska B738 got rejected yet again for Blurry.
https://imgproc.airliners.net/photos/ai ... f1be7d97a7
Still having a very hard time seeing any, if it's even there, in the full size photo.
FWIW this is the EXIF data of the image above:
Nikon D3300
70-300mm f/4.0-5.6
6000 x 4000 * 5.90 MB JPEG
ISO 200 105mm f/8.0 1/1000 sec
airkas1
Head Screener
Wed Nov 28, 2018 10:35 pm
It's on the sharp side, but not really blurry.
Runway28L
Thu Nov 29, 2018 12:20 pm
Thanks Kas for confirming. Just had it accepted on appeal.
Runway28L
Fri Nov 30, 2018 9:05 pm
The American ERJ that originally got rejected for OE got rejected again. I'm really dumbfounded with this one. :ouch:
https://imgproc.airliners.net/photos/ai ... be1a58af6c
-Blurry
-Heat haze
-Underexposed
-PM "Nose"
How come the reasons completely changed from the initial rejection? Also, how is heat haze an issue when it was 40 degrees Fahrenheit the day I took this? Issue with resizing?
airkas1
Head Screener
Sat Dec 01, 2018 11:55 am
It's not too bad. Let me know when you appeal, so I can try to catch it.
Heat haze can occur at any time and is coupled with the difference between the air and surface temperature. So a cold day (temperature-wise) is not necessarily a gaurantee for no heathaze.
Heat haze, also called heat shimmer, refers to the inferior mirage experienced when viewing objects through a layer of heated air; for example, viewing objects across hot asphalt or through the exhaust gases produced by jet engines. When appearing on roads due to the hot asphalt, it is often referred to as a highway mirage.
Convection causes the temperature of the air to vary, and the variation between the hot air at the surface of the road and the denser cool air above it creates a gradient in the refractive index of the air. This produces a blurred shimmering effect, which affects the ability to resolve objects, the effect being increased when the image is magnified through a telescope or telephoto lens.
A hot-road mirage, "fake water" on the road, the most common example of an inferior mirage
Light from the sky at a shallow angle to the road is refracted by the index gradient, making it appear as if the sky is reflected by the road's surface. The mind interprets this as a pool of water on the road, since water also reflects the sky. The illusion fades as one gets closer.
On tarmac roads it may look as if water, or even oil, has been spilled. These kinds of inferior mirages are often called "desert mirages" or "highway mirages". Both sand and tarmac can become very hot when exposed to the sun, easily being more than 10 °C hotter than the air one meter above, enough to create conditions suitable for the formation of the mirage.
Source: https://en.wikipedia.org/wiki/Mirage
Runway28L
Sat Dec 01, 2018 5:21 pm
Hi Kas. I just appealed the image and sent you a PM letting you know.
Thank you for providing that explanation. Interesting to read. Although I just find it strange how I still don't see any haze in the full size file and no other images taken on that day had any either (many of which were accepted without issue).
Runway28L
Sun Dec 09, 2018 7:28 pm
Hello guys. Just had this priority upload rejected for blurry and quality.
https://imgproc.airliners.net/photos/ai ... 19eb7e4f45
Is this even salvageable or should I bin it?
fsx98
Mon Dec 10, 2018 12:26 am
The upper part of the fuselage and tail are blurry; best to either downsize it (my personal preference, depending on size of rejected photo) or bin the photo.
Aviation junkie + computer expert!
airkas1
Head Screener
Tue Dec 11, 2018 8:49 pm
Doesn't look super blurry, but the sky and fuselage are overexposed. Light definitely not doing you any favors, not sure if can be salvaged.
Runway28L
Wed Dec 12, 2018 2:21 am
Thank you Victor and Kas for your feedback. I'll probably just throw it out then. No big deal.
Runway28L
Mon Dec 31, 2018 6:32 am
Nothing related to screening but since 2018 is coming to a close, I'm likely going to making a new thread for 2019 since this one is getting a bit cluttered. So I just want to say THANK YOU to everyone who has contributed to this thread as it's been slightly over a year since I started it up. I'm shocked at how far I've come since then, even though I think there is always room for improvement. I never thought I would have over 200 uploads and over 75k views on here within a year, and it's largely thanks in part to the feedback and advice you all have kindly given me.
Happy New Year's and cheers to 2019! :santahat:
airkas1
Head Screener
Mon Dec 31, 2018 11:57 am
Well done Evan, glad we were able to help! There is always room for inprovements, even for people who have been at it for years. All the best for 2019 and I’m looking forward to seeing more of your work!
Runway28L
Tue Jan 01, 2019 6:35 am
Thank you Kas! ;)
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
