• 1
  • 3
  • 4
  • 5
  • 6
  • 7
ChrisLait
Re: Pre Screen Feedback Please
Thu Nov 29, 2018 1:52 pm
Thanks Kas. They are the ones. Thanks for your time too as i know this site can be extremely busy at times.
Much appreciated !! :)
ChrisLait
Fri Nov 30, 2018 9:32 am
Hi Community
Had this photo rejected today for Blurry and Heat Haze. Happy to accept the screener decision, just curious where it is so that I know what to look for in the future. I'm generally OK at picking blurry images but looks like I have missed this one.
Thanks as always
Chris
airkas1
Head Screener
Fri Nov 30, 2018 11:26 am
Probably the tail, but I don't find either that bad.
ChrisLait
Fri Nov 30, 2018 8:34 pm
Thanks Kas. Do you think I should appeal and would it be successful?
Runway28L
Fri Nov 30, 2018 9:16 pm
Looks a little flat personally but still ok.
It may help if you added a small amount of selective sharpening to the tail.
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
ChrisLait
Sat Dec 01, 2018 1:56 am
I have run some sharpening over the tail, hopefully its enough to fix issues??
Chris
airkas1
Head Screener
Sat Dec 01, 2018 11:44 am
I like the second version better.
ChrisLait
Sat Dec 01, 2018 2:00 pm
Thanks Kas
ChrisLait
Thu Dec 06, 2018 1:59 pm
Hi. Just after some feedback on this image ..
https://imgproc.airliners.net/photos/ai ... 245f129087
It has been rejected today for Dark, Halos, Low Contrast, Noise, Quality and Underexposed which is the most amount of rejection reasons I have had in a while.
Is the image really that bad? Would appreciate your feedback.
Chris
airkas1
Head Screener
Tue Dec 11, 2018 9:13 pm
Not that it really helps you, but dark and underexposed are the same. Could use a bit more contrast (maybe +10, or +15 max) and the titles look somewhat soft, but otherwise it looks nice.
ChrisLait
Fri Dec 14, 2018 8:55 am
Thanks Kas .. I didn't think it was as bad as it sounded. I should be able to re-edit these areas into a new version.
ChrisLait
Sun Dec 16, 2018 2:52 am
Hi Community
Have had another photo rejected that i'm confused by and would love some feedback.
This photo was originally rejected for being over exposed, specifically the white areas of the fuselage. I submitted an appeal as the histogram looks ok to me however now the appeal decision says it's been rejected fo: Blurry, Overexposed, Over-sharpened, Quality, High in Frame.
https://i.ibb.co/bFWVB5R/Qantas-737-800 ... 118-V3.jpg
I can fix the over-exposed but I would like some feedback on the other new rejection reasons as now I am just confused as to what is actually wrong with it (if anything actually at all)
Thanks for your help
Chris
ChrisLait
Sun Dec 16, 2018 3:09 am
New Question .. is there too much fence in this shot to be acceptable to the site? It is only just touching the main wheels so not really blocking the aircraft but I know the site has rules about fences.
Chris
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
