• 1
  • 5
  • 6
  • 7
  • 8
  • 9
ChrisLait
Re: Pre Screen Feedback Please
Thu Nov 29, 2018 1:52 pm
Thanks Kas. They are the ones. Thanks for your time too as i know this site can be extremely busy at times.
Much appreciated !! :)
ChrisLait
Fri Nov 30, 2018 9:32 am
Hi Community
Had this photo rejected today for Blurry and Heat Haze. Happy to accept the screener decision, just curious where it is so that I know what to look for in the future. I'm generally OK at picking blurry images but looks like I have missed this one.
Thanks as always
Chris
airkas1
Head Screener
Fri Nov 30, 2018 11:26 am
Probably the tail, but I don't find either that bad.
ChrisLait
Fri Nov 30, 2018 8:34 pm
Thanks Kas. Do you think I should appeal and would it be successful?
Runway28L
Fri Nov 30, 2018 9:16 pm
Looks a little flat personally but still ok.
It may help if you added a small amount of selective sharpening to the tail.
ChrisLait
Sat Dec 01, 2018 1:56 am
I have run some sharpening over the tail, hopefully its enough to fix issues??
Chris
airkas1
Head Screener
Sat Dec 01, 2018 11:44 am
I like the second version better.
ChrisLait
Sat Dec 01, 2018 2:00 pm
Thanks Kas
ChrisLait
Thu Dec 06, 2018 1:59 pm
Hi. Just after some feedback on this image ..
https://imgproc.airliners.net/photos/ai ... 245f129087
It has been rejected today for Dark, Halos, Low Contrast, Noise, Quality and Underexposed which is the most amount of rejection reasons I have had in a while.
Is the image really that bad? Would appreciate your feedback.
Chris
airkas1
Head Screener
Tue Dec 11, 2018 9:13 pm
Not that it really helps you, but dark and underexposed are the same. Could use a bit more contrast (maybe +10, or +15 max) and the titles look somewhat soft, but otherwise it looks nice.
ChrisLait
Fri Dec 14, 2018 8:55 am
Thanks Kas .. I didn't think it was as bad as it sounded. I should be able to re-edit these areas into a new version.
ChrisLait
Sun Dec 16, 2018 2:52 am
Hi Community
Have had another photo rejected that i'm confused by and would love some feedback.
This photo was originally rejected for being over exposed, specifically the white areas of the fuselage. I submitted an appeal as the histogram looks ok to me however now the appeal decision says it's been rejected fo: Blurry, Overexposed, Over-sharpened, Quality, High in Frame.
https://i.ibb.co/bFWVB5R/Qantas-737-800 ... 118-V3.jpg
I can fix the over-exposed but I would like some feedback on the other new rejection reasons as now I am just confused as to what is actually wrong with it (if anything actually at all)
Thanks for your help
Chris
ChrisLait
Sun Dec 16, 2018 3:09 am
New Question .. is there too much fence in this shot to be acceptable to the site? It is only just touching the main wheels so not really blocking the aircraft but I know the site has rules about fences.
Chris
jelpee
Screener
Sun Dec 16, 2018 4:26 pm
Fence is too distracting. Together with the obstruction of the main landing gear, I would give it a "Motive" rejection. Not the best of lighting conditions :(
Jehan
ChrisLait
Sun Dec 16, 2018 9:36 pm
Thanks Jehan
ChrisLait
Sun Dec 16, 2018 9:37 pm
Any thoughts on the rejection above the Singapore 777 would also be appreciated.
Runway28L
Sun Dec 16, 2018 10:25 pm
The fuselage of the QF B738 looks blurry and the whites are a bit too strong. Framing looks fine to me.
airkas1
Head Screener
Mon Dec 17, 2018 11:32 am
The initial rejection of the Qantas B738 was my doing, so I guess that already explains my thoughts on it.
Agree that the fence and main gear for the SQ 777 are the main issue.
ChrisLait
Mon Dec 17, 2018 8:35 pm
Thanks Guys. Appreciate the feedback. I guess this one goes in the bin.... can’t fix blury ..
Good to know on the 777 too. I have a couple of others that may work in place of this one.
Chris
ChrisLait
Wed Jan 02, 2019 5:34 am
Hi All .. and Happy New Year!
Just after some feedback on this dash 8. It would be the first in the database in its current livery so I am hoping it is ok.
Thanks as always
Chris
Runway28L
Wed Jan 02, 2019 6:22 am
Lighting looks marginal. Not entirely sure about motive re the fence.
ChrisLait
Wed Jan 02, 2019 7:54 am
Thanks .. I thought it might be which is why I needed a second opinion.
ChrisLait
Wed Jan 02, 2019 7:55 am
.. also after some feedback on this Korean 787-9
Chris
airkas1
Head Screener
Wed Jan 02, 2019 3:37 pm
The Dash has poor light and the fence isn't great. But, new livery, I don't know. You can always try, the worst that can happen is a rejection with absolutely no consequences. the Koreean looks flat and light is really not great.
ChrisLait
Thu Jan 03, 2019 12:45 am
Thanks Kas
ChrisLait
Sat Jan 05, 2019 4:36 am
Hi All
Just after some pre screen feedback on this Qantas 737. I am hoping that the aircraft is in focus.
Chris
airkas1
Head Screener
Sat Jan 05, 2019 10:30 am
Focus looks alright, but it's a bit distant and the foreground looks cluttered. I'm so-so on the latter.
ChrisLait
Sat Jan 05, 2019 10:54 am
Thanks Kas. The main thing to me is that it is in focus and not blurry. Once I crop it down a bit the clutter should be contained / reduced so it should be ok.
ChrisLait
Tue Jan 08, 2019 12:24 pm
Hi Community
I would appreciate some feedback on the below pictures. I have just bought a new camera and have applied my normal workflow to these images but want to see if this is too much / too little / just right for the new camera given the step up in camera quality.
Thanks for your feedback
Chris
Runway28L
Wed Jan 09, 2019 8:33 pm
VH-VQE: Tail a bit OS, otherwise ok
V8-DLC: Front of aircraft OS
9V-SMT #1: OS
9V-SMT #2: Needs more contrast
ChrisLait
Fri Jan 11, 2019 6:31 am
Thanks for the feedback .. much appreciated :-)
ChrisLait
Thu Feb 14, 2019 8:59 am
Hi Community ..
Just had a couple of rejections I would like some thoughts on and if their updated versions are more suitable for upload ...
Air Canada 787
Rejected Image for Over-exposed - https://imgproc.airliners.net/photos/ai ... bb0399a2d2
Updated Image - https://i.ibb.co/ZGwq6f1/Air-Canada-787.jpg
Jetstar A320 (VQW)
Rejected Image for Over Exposed - https://imgproc.airliners.net/photos/ai ... 88f844c6ad
Updated Image - https://i.ibb.co/B48kp77/Jetstar-A320-VH-VQW.jpg
Jetstar A320 (VQH)
Rejected Image for Overexposed and low contrast - https://imgproc.airliners.net/photos/ai ... 6704beeac4
Updated Image - https://i.ibb.co/P4cG8YD/Jetstar-A320-VH-VQH.jpg
Qantaslink 717
Rejected Image for Low Contrast - https://imgproc.airliners.net/photos/ai ... 4c76df5eb1
Updated Image - https://i.ibb.co/9nhTJVb/Qantaslink-717-VH-YQU.jpg
REX (Regional Express) Sabb 340
Rejected Image for Low Contrast & Under Exposed - https://imgproc.airliners.net/photos/ai ... db45fd9352
Updated Image - https://i.ibb.co/Xp8Qv78/Rex-S340.jpg
Chris
ChrisLait
Sat Feb 16, 2019 1:14 am
Hi All .. just after some feedback on this Qantas Dreamliner I took in pretty much darkness. I wanted to try and push beyond perfect light and see what I could capture so any feedback would be appreciated. Also, if it needs re-editing, where, and would it stand a chance of making the site?
Chris
jelpee
Screener
Sat Feb 16, 2019 1:21 am
I see some blur in the tail cone and wingtip. Perhaps uploading at a smaller size (e.g. 1200 pixels) plus a light round of selective sharpening and it would be acceptable for me. There is a slight red tint, but I think that is OK for the conditions. Try some WB adjustment and see if it makes a difference. Again. if you can mitigate the slight blur, it would be OK for me.
Jehan
ChrisLait
Sat Feb 16, 2019 1:26 am
Thanks Jehan .. I'll make the suggested edits and repost to see how i did. I appreciate the help
ChrisLait
Sat Feb 16, 2019 2:21 am
Have re-edited based on the feedback .. would it be acceptable now? (I played with the WB and wasn't happy with the results so I went back to the original)
Chris
jelpee
Screener
Sat Feb 16, 2019 3:19 am
Chris,
This version seems like it could use some additional contrast.. I have sent you a PM with another suggestion.
Jehan
ChrisLait
Sat Feb 16, 2019 4:18 am
Thanks Jehan .. I have sent you a PM in return
ChrisLait
Sun Feb 17, 2019 4:49 am
Is this angle too rear focused to make the site?
Chris
HarryLi
Screener
Sun Feb 17, 2019 9:07 am
Hi Chris,
This one looks pretty blurry for me maybe because of the exhaust from the engines. I think it would be hard to make it ;(
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
ChrisLait
Sun Feb 17, 2019 9:41 am
Thanks Harry.
From what I can take from that, this image itself has issues, but the framing of a similar image without these issues would be ok?
airkas1
Head Screener
Sun Feb 17, 2019 11:35 am
Angle and crop are fine :thumbsup:
ChrisLait
Sun Mar 03, 2019 10:10 am
Hi Guys .. I have been at the Australian International Airshow and am slowly working my way through all my shots.
Question for this one .. Are these grouped too far apart and too small to make it on the site?
Chris
jelpee
Screener
Sun Mar 03, 2019 2:48 pm
Unable to access your image Chris.
Jehan
airkas1
Head Screener
Sun Mar 03, 2019 2:53 pm
The image shows for me. Lots of empty space on the sides, this would work better in a 3:4 or 2:3 crop.
ChrisLait
Mon Mar 04, 2019 9:52 am
Thanks Kas. Is this any better?
Chris
ChrisLait
Mon Mar 04, 2019 9:56 am
I'm also liking this one. Do you think it would make it?
Appreciate your feedback.
Chris
fsx98
Mon Mar 04, 2019 2:08 pm
Both of these shots look amazing; however the photo in the last post (#347) looks a bit blurry, I'm afraid.
HarryLi
Screener
Sat Mar 09, 2019 6:11 am
The second one looks blurry IMO.First one looks not so bad.
ChrisLait
Tue Mar 12, 2019 9:11 am
Thanks for the feedback :)
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
