  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
ChrisLait
Re: Pre Screen Feedback Please
Sun Aug 18, 2019 10:21 am
Thanks guys .. exactly what I thought. Frustrating as I have been chasing this one for a while and never seem to have the right conditions. I'll bin this one and keep chasing.
Thanks again.
ChrisLait
Thu Nov 07, 2019 8:42 am
Hi Community
Just after some feedback on this Air New Zealand Dreamliner please.
Chris
310815
Thu Nov 07, 2019 10:18 am
Hi Chris,
looks heat hazed / oversharpened (titles) and light is very harsh. So it won't make it as it is, and there's nothing to be done against heat haze. The quality is not really there.
I would really recommend to not shoot at midday during times with high sun. And look for opportunities to shoot with lower sun..
Julien
HarryLi
Screener
Thu Nov 07, 2019 4:11 pm
I would totally agree with Julien's point on Heat Haze which destroys most of it. Sorry about it.
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
ChrisLait
Sun Nov 17, 2019 6:19 am
Thanks for the feedback on the last air nz. now in the bin.
Just after feedback on this one too if I can ...
I am a little concerned about the lighting ...
Chris
310815
Sun Nov 17, 2019 9:13 am
Your concerns are right. It is backlit and therefore has a dark forgreground but yet a bright sky. So if you expose the aircraft more the sky will look blown out. I am afraid, but this one is rather for the personal collection.
Julien
ChrisLait
Wed Nov 27, 2019 10:59 am
Hi Community
Just after some feedback on this Shanghai Airlines Dreamliner.
I have some concerns around the heat haze coming from the engines distorting the aircraft body but not sure if these kill the image for the site or are acceptable. I have exported at a smaller size than I normally would to try and minimise the effect.
Chris
spompert
Wed Nov 27, 2019 11:11 am
HI Chris,
To me it looks like there is a lot of heathaze in general. Not only from the engines but also around the front of the aircraft, clearly visible to me. I would say this photo is not fixable.
Greets Stefan
jelpee
Head Screener
Wed Nov 27, 2019 12:16 pm
Agree with Stefan. Heat hazed and very harsh lighting. Also looks over sharpened. Perhaps, bet to move on.
Jehan
310815
Wed Nov 27, 2019 1:39 pm
Well as Jehan and Stefan have noted the quality is not there. Heat haze is all over. Again, I would recommend to not shoot at times when the sun is at the highest, this will lead to not really nice light and also heat-haze, especially at a larger distance.
So in the warmer month I would recommend to only shoot early morning / late evening and avoid midday shooting.
ChrisLait
Sat Nov 30, 2019 3:57 am
Thanks Guys for the feedback. Unfortunately its starting summer here and to get anything outside of the standard domestic 737s shooting is limited. I was 99% sure it wasn't going to make it but was just hoping. Anyway, thanks as always and this one is in the bin :-(
ChrisLait
Sat Nov 30, 2019 4:00 am
Ok .. a different question this time. Most of my shots are normally landing or take off as I can rarely get shots of the ramp, however this time I could. I'm confident the picture itself is ok but, is there too much going on and would it be given a motive rejection?
Chris
airkas1
Sat Nov 30, 2019 9:52 am
Motive is fine. I assume this is the unedited photo?
ChrisLait
Sun Dec 01, 2019 2:02 am
Thanks Kas .. yes, unedited. I didn't want to spend too much time on it if it was going to be an instant rejection. Now that I know that it will be ok, I'll do an actual edit.
ChrisLait
Sat Jan 04, 2020 2:03 am
Hi Community
Just after some feedback on the below images before uploading please.
Asiana 777
Batik / Malindo Air 737
Jetstar A320
Chris
Crosswindphoto
Sat Jan 04, 2020 7:41 am
Asiana: Looks ok.
Batik: Nose looks a little blurry, probably better at a smaller size.
JetStar: Poor crop (the a/c is in the top left of the frame), blurry.
Tim
ChrisLait
Sat Jan 04, 2020 8:28 am
Thanks Tim
airkas1
Sat Jan 04, 2020 9:38 am
Asiana: fine
Batik: blurry nose
JetStar: needs a tighter crop, but also looks a little OOF.
ChrisLait
Sat Jan 04, 2020 9:39 am
Thanka Kas
ChrisLait
Sat Jan 04, 2020 9:50 am
and another quick one ...
Not sure on this one. Was a very smokey day so I am not sure how this has impacted the image. Obviously not as clear as I would like but is it too far gone?
Chris
310815
Sat Jan 04, 2020 10:44 am
Well other than being flat and hazy it's very toplit for a very common plane. I would let this one go.
Because it would need quite a boost in contrast which then accentuates the shadows. Try to shoot in better light / circumstances.
ChrisLait
Sun Feb 16, 2020 6:14 am
HI
Just after some feedback on this Singapore 777 and Qantas Dreamliner please. I can't decide if they are blurry or not - and if they are, are they salvageable at a smaller image size?
Chris
ChrisLait
Mon Feb 24, 2020 7:49 am
Can I please have some thoughts on the above? Thanks :)
HarryLi
Screener
Tue Feb 25, 2020 4:52 am
Hi Chris,
Sorry for the late reply.
Singapore 77W looks in low quality for me since it suffers from some heat haze I think, and the light isn't very good, which would decrease the possibility of accepting because our DB has already had lots of photo of this REG. Standard would be increased due to this.That's also why some of you will get "Common" sometime.
Qantas B789 looks very underexposed for me. Low contrast slightly due to light and weather problems I think. Hard to make it sorry.
Hope can be helpful for you .
Harry
ChrisLait
Tue Feb 25, 2020 6:10 am
Thanks Harry. No problem on the pics - in the bin they go. No problem on the delay either, I know you guys work hard at keeping the site running :-)
ChrisLait
Sun Apr 26, 2020 2:15 am
Hi All ... one for the screening team
I have been trying to scan some of my older film images into digital with varying levels of success. Is the criteria for film scans the same as digital shots or is there a bit more leniency in the image?
This is one I have been working on (from about 1997), just not sure if its something that acceptable, or I just something nice for me to play with but isn't for the site?
Any feedback is much appreciated.
Chris
jelpee
Head Screener
Sun Apr 26, 2020 2:20 am
Hi Chris,
Vintage images are screened with some leniency with regards to sharpness, quality, grain and even motive. My recommendation is to try to use editing tools available today to try to restore the image to as good a quality as possible without making it looked "cooked". The image above looks a little over exposed to me. Otherwise should be OK. I am not on the vintage screening team and can't speak specifically to the details. A lot is up to screener discretion. You can also take a look at some of the accepted vintage shots to get an idea of what is acceptable. I know that images from the 1960's through the 1980's tend to get a lot more lenience due to their rarity.
Jehan
ChrisLait
Sun Apr 26, 2020 2:35 am
Thanks Jehan
ChrisLait
Thu May 07, 2020 10:24 am
Hi .. just after some more feedback on another couple of scanned film images please.
Chris
ChrisLait
Sun May 17, 2020 9:34 am
Hi Screening Team - would love some feedback on the above 2 images scanned from negatives.
HarryLi
Screener
Sun May 17, 2020 8:13 pm
Hi Chris,
Sorry for the late reply. Since both of these photos are Scanned Photos (I suppose), we (normal screener & Heads) cannot give accurate opinions on them because these photos would be distributed to another queue (Vintage Queue)for scanned experts to screen.
For the second one, if it's possible to adjust the color I would try to make it less blue/ purple.
Sincerely,
Harry
ChrisLait
Mon May 18, 2020 5:03 am
Thanks Harry
JakTrax
Mon May 18, 2020 4:31 pm
The 737 looks blurry and both appear to have had a bit too much noise reduction applied, resulting in a high degree of fine detail loss. they also look a bit oversharp. I think the Sunstate stands a good chance with a more careful edit.
ChrisLait
Sun May 31, 2020 5:52 am
Thanks :D :thumbsup: :thumbsup:
ChrisLait
Sun May 31, 2020 5:59 am
Hi. Just looking for some feedback on this Air New Zealand 777. Was a cold morning so I am most concerned about the heat from the engines. They don't seem to be interfering with the aircraft in my opinion but I would like an independent opinion.
https://drive.google.com/file/d/1oCbLLy ... sp=sharing
Chris
dutchspotter1
Sun May 31, 2020 10:20 am
Chris
Needs CW rotation, also slightly oversharped and the wheels are not clear.
NO URLS in signature
jelpee
Head Screener
Sun May 31, 2020 12:31 pm
Agree with Joost. Needs CW rotation, Over-sharpened; also looked a bit over exposed (nose).
Jehan
ChrisLait
Mon Jun 01, 2020 9:39 am
Thnaks Guys
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
Users browsing this forum: No registered users and 19 guests
