• 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 8
jelpee
Screener
Re: Pre Screen Feedback Please
Mon Jul 09, 2018 10:34 pm
Slight indication of jaggies on the leading edge of the horizontal stabilizer but acceptable for me.
Jehan
ChrisLait
Mon Jul 09, 2018 11:46 pm
Thanks Jehan. I'll slightly drop the sharpening again.
ChrisLait
Mon Jul 16, 2018 9:02 pm
Hi. Just after some feedback on this rejection as I am trying to decide if I appeal or not.
This was rejected for Blurry and common and also a personal message that I think was missed off the rejection email as there was no message on my email.
This one will look familiar as it was only about 3 or 4 posts ago I posted here for feedback.
The forum is normally a good place to get a feeel for the suitability of the picture before uploading so I was a little surprised.
Also not sure about the common rejection ... Not sure it’s any more common than any of my other pictures?
https://imgproc.airliners.net/photos/airliners/3/2/3/5083323.jpg?v=v411575a2551
Your guidance on an appeal would be much appreciated
Chris
airkas1
Head Screener
Mon Jul 16, 2018 9:54 pm
I didn't screen it, but the nose and tail look blurry. Common always refers to the number of photos already in the database (of that particular registration). Usually after 100+ photos already in the DB, we sometimes give common to indicate that it's a common frama in the DB and quality needs to be above par.
In the end, I don't advise appealing and probably let this shot go.
ChrisLait
Mon Jul 16, 2018 10:04 pm
No problem. Thanks Kas.
Miguel1982
Head Screener
Tue Jul 17, 2018 7:52 am
Hi Chris, that was my doing and it appears that I forgot to write the message (apologies). I think it was along the lines that the tail and esp. nose looked blurry, nothing else.
Miguel
ChrisLait
Tue Jul 17, 2018 9:59 am
All good Miguel. :-)
I have seen the numbers in the screening queue so I'm sure there are some occasional oversights. Hopefully the rest of the photos I have in my queue have more luck! :-)
Chris
ChrisLait
Tue Jul 17, 2018 11:43 am
Hi.
Just looking for some feedback on this Jetstar A321.
Thanks as always :-)
Chris
dutchspotter1
Tue Jul 17, 2018 8:30 pm
Looks a little bit oversharped and perhaps a tad low in frame.
NO URLS in signature
ChrisLait
Wed Jul 18, 2018 12:55 am
I thought it might be a little low in frame but when I ran a grid across it it was pretty much centered. I think the angle is deceiving however I will move it up a tad as it does look a bit low. Sharpening can be easy fixed too.
Thanks for the feedback. much appreciated! :-)
ChrisLait
Wed Jul 18, 2018 12:13 pm
Hi All
This one was just rejected for Grainy, Soft and Low Contrast - https://imgproc.airliners.net/photos/air ... 658f03be4f
Is this re-edit any better?
https://image.ibb.co/nqJM4J/Qantaslink_ ... 010718.jpg
Chris
Runway28L
Wed Jul 18, 2018 8:25 pm
Still seeing grain on the underside of the fuselage as well as where there are shadows.
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
DL747
Wed Jul 18, 2018 11:31 pm
Seems better but also still grainy, probably would be better at a smaller size. Doesn't seem to have the overall quality for 1400, probably better at 1200 or 1024.
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
ChrisLait
Thu Jul 19, 2018 2:03 am
Thanks. I’ll re-edit and see how I go
ChrisLait
Thu Jul 19, 2018 2:08 am
Hi community :-)
I seem to be having some issues with my exposure and sharpening recently for some reason. I just had this one rejected for oversharp and overexposed. I am considering an appeal but thought I would get some feedback first.
https://imgproc.airliners.net/photos/airliners/9/6/0/5087069.jpg?v=v40ff521cefe
If it is both of these I’m happy to re-edit. Just starting to doubt what I’m doing slightly as I haven’t really changed my workflow from the earlier ones that have been accepted.
Chris
DL747
Thu Jul 19, 2018 2:15 am
The nose is a bit blown out and there are some jaggies on the tail. Imo its marginal, but I think the rejection is valid. I am struggling with sharpening too, my results are very inconsistent. New issue seems to pop up every time I submit, even if I only changed the previous rejection reason. :?: :? :? :shock:
airkas1
Head Screener
Thu Jul 19, 2018 6:15 am
-EBJ looks passable.
ChrisLait
Thu Jul 19, 2018 7:16 am
Thanks Kas. I’ll appeal it and see what happens
Update - appealed and accepted. Thanks :-)
ChrisLait
Thu Jul 19, 2018 12:27 pm
With some of my recent rejections I second guessing some things I thought I was staring to get OK at. That being the case I am interested in feedback on this one - particularly with exposure and sharpening settings.
https://image.ibb.co/dZxnDd/Virgin_Aust ... 718_V1.jpg
airkas1
Head Screener
Thu Jul 19, 2018 4:58 pm
Definitely overexposed for me (needs reduced highlights) and perhaps even a bit blurryish.
ChrisLait
Fri Jul 20, 2018 5:38 am
Runway28L
Fri Jul 20, 2018 8:22 pm
Area around the cockpit looks a bit soft/blurry. I'd say 50/50.
airkas1
Head Screener
Fri Jul 20, 2018 10:07 pm
Better yes, but I'd give the titles and cockpit section (incl. nose sticker) a bit more sharpening. Perhaps also some +5/+8 contrast.
ChrisLait
Fri Jul 20, 2018 10:36 pm
Thanks guys
DL747
Sat Jul 21, 2018 1:16 am
Probably a fairly moot point since Kas weighed in, but the cockpit windows and nose gear door appear to me to be in particular need of another small dose of sharpening.
ChrisLait
Sat Jul 21, 2018 7:10 am
Hows this edit? I sharpened the titles, the cockpit, the nose decal and the nose wheel door. I also increased the contrast 8 points.
https://image.ibb.co/ez0JOd/Virgin_Aust ... 718_V3.jpg
airkas1
Head Screener
Sat Jul 21, 2018 11:34 am
Good to go I think.
ChrisLait
Sat Jul 21, 2018 2:38 pm
Thanks Kas :-)
DL747
Thu Jul 26, 2018 7:00 am
Looks soft in spots to me, almost blurry
ChrisLait
Thu Jul 26, 2018 7:01 am
Hi All
Just after a second opinion on this one before I add it to the screening queue.
Chris
DL747
Thu Jul 26, 2018 8:28 am
Parts look oversharpened, but parts are also appearing soft/blurry. Contrast is probably fine, but could maybe do with a minor increase. Color is fine on my screen. This is probably better at a smaller size (1024).
spompert
ChrisLait wrote:
Hi All
Chris
Hi, text on the plane looks oversharpened to me. Not sure if it needs some more contrast as well. I would also add some more blue in the photo. Good luck
ChrisLait
Thu Jul 26, 2018 8:58 am
Thanks Guys. I have taken the sharpening off the titles (this was a mask so easy to do). I have added more blue, increased the contrast a couple of points and re-sized.
Did it help?
ChrisLait
Thu Jul 26, 2018 9:13 am
Also interested on opinions on this one?
airkas1
Head Screener
Thu Jul 26, 2018 11:10 am
Jetstar re-edit looks passable.
QFlink is overexposed and jaggy on the underside of the aircraft.
ChrisLait
Thu Jul 26, 2018 11:28 am
Thanks Kas. I'll re-edit the QF link.
ChrisLait
Thu Jul 26, 2018 11:42 pm
I have reduced the exposure and the sharpening. Hopefully now OK?
ChrisLait
Sun Jul 29, 2018 5:55 am
Hi All
Just after some feedback on this Capital Airlines A330 Departing Melbourne today. The weather wasn't great so I'm a little unsure.
Chris
ChrisLait
Sun Jul 29, 2018 8:23 am
Also just interested in thoughts on the framing of this one. I don't think the pic is good enough to add to the screening list, but I am interested to know what people's thoughts are on its framing and would a better picture framed int he same way be accepted?
https://image.ibb.co/ipkPDo/Qantas_A330 ... 718_V1.jpg
(if you do think its good enough to add to the queue, please let me know, although I am not expecting it is :-) )
ChrisLait
Sun Jul 29, 2018 2:03 pm
Just a couple more for feedback please
Jetstar 787-8 - https://image.ibb.co/mXMPg8/Jetstar_787 ... 718_V1.jpg
Qantas A380 - https://image.ibb.co/fO8jET/Qantas_A380 ... 718_V1.jpg
airkas1
Head Screener
Sun Jul 29, 2018 3:22 pm
The A330 is OS and light is pretty bad. I wouldn't bother to be honest. Did you shoot through a fence? I'm having a hard time explaining the large darker patches on the grass.
QF 330 looks blurry/hazed and the angle isn't that flattering.
787 looks oversharpened to compensate for blur. Wingtip quite jaggy.
A380 underexposed, flat and motive (more than 50% of the gear cut off).
ChrisLait
Mon Jul 30, 2018 10:29 am
Thanks Kas. Not my best but i needed a 2nd opinion to confirm.
You are right, the first A330 was shot through a fence and I was hoping that the fence was diluted enough, which it doesn’t look like it has, which is ok.
All 4 going in the bin.
Thanks again
Chris
ChrisLait
Wed Aug 01, 2018 12:47 pm
Hi Guys
Just after some feedback on this Cathay Pacific A350 - https://image.ibb.co/fVviDz/Cathay_Paci ... _B_LRI.jpg
Chris
ChrisLait
Thu Aug 02, 2018 10:38 am
Also after some feedback on this Thai 787-8 (late afternoon)
Version 1 - https://image.ibb.co/kSdWJz/Thai_787_8_HS_TQF.jpg
Version 2 - https://image.ibb.co/c2JvBK/Thai_787_8_ ... type_2.jpg
ChrisLait
Thu Aug 02, 2018 11:30 am
Runway28L
Thu Aug 02, 2018 5:04 pm
CX A359: Some parts look a bit OS but may be passable
QF B738: Tail looks slightly soft. I'd add noise reduction to the sky too.
As for the TG B788, I prefer the 2nd version.
DL747
Thu Aug 02, 2018 6:06 pm
CX looks fine to me, TG v2 may need a little contrast and parts are borderline oversharpened, QF looks soft in parts to me as well, the roo, Spirit of Australia titles, and forward door, and agree it does need noise reduction in the sky.
ChrisLait
Thu Aug 02, 2018 9:24 pm
Thanks guys. I will do some editing and hopefully these are all fixable.
ChrisLait
Sat Aug 04, 2018 12:24 am
I have re-edited the Qantas to hopefully address the issues raised. Hopefully this is better ..
https://image.ibb.co/evXfFe/Qantas_737_ ... XZM_V2.jpg
DL747
Sat Aug 04, 2018 1:14 am
Still a bit noisy, especially the sky. I'd say its borderline, but I'd wait for a screener.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 8
