  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 9
ChrisLait
Re: Pre Screen Feedback Please
Sat Aug 04, 2018 6:08 am
So, I have a new lens which I got to put properly into action today for the first time! It's a Canon 70-200mm f2.8 L IS II .
Being a professional lens it is obviously a lot different to the one I was using so I'm just after some feedback on the quality of these images as my editing process is likely to change slightly with a higher quality lens. (as you can see the light changed throughout the shoot so I have tried to pick a range from the day)
AirCalin A320 - https://image.ibb.co/cHg5gK/Air_Calin_v1.jpg
Thai A350 - https://image.ibb.co/heMuae/Thai_HS_THC_v1.jpg
Cathay Pacific A350 - https://image.ibb.co/d3Pxve/Cathay_B_LRL_V1.jpg
Qantas 737 - https://image.ibb.co/fXWhTz/Qantas_737_ ... 818_V1.jpg
REX Sabb 340 - https://image.ibb.co/is231K/REX_Sabb340 ... 818_V1.jpg
China Eastern A330 - https://image.ibb.co/dkNaFe/China_Easte ... 818_V1.jpg
As always .. thanks in advance for the feedback :-)
Chris
ChrisLait
Sun Aug 05, 2018 3:38 am
Hi All ... I like the darkness in the clouds in these one but am not sure how that fits in with the screening rules.
Any feedback is appreciated
Chris
airkas1
Sun Aug 05, 2018 10:26 am
-XZM: perhaps little noisy sky, but not superbad and otherwise very nice.
-OJSB: passable
-THC: passable
-LRL: passable
-XZL: OS underside of main gear, engines, nose/fuselage.
-ZLQ: nice
-5968: OS underside fuselage.
ChrisLait
Sun Aug 05, 2018 11:15 am
Thanks Kas. Good to know that most of these are acceptable .. and that some are actually quite good. The 2 that are OS hopefully sounds fixable. Seems like a good start with the new lens :-)
ChrisLait
Sun Aug 05, 2018 12:16 pm
Have done some re-editing of the 2 from above that were both over sharp. I have reduced the sharpening so hopefully they are OK
Qantas 737 VH-XZL - https://image.ibb.co/doDNwK/Qantas_737_ ... 818_V2.jpg
China Eastern A330 B-5968 - https://image.ibb.co/jYMpAe/China_Easte ... 818_V2.jpg
Also, a new one I would like some feedback on please :-)
Qantas 737 VH-VZC - https://image.ibb.co/i6ixwK/Qantas_737_ ... 818_V1.jpg
Chris
... also, if there are any in my screening list that I should pull and re-edit, can you please let me know? :-)
ChrisLait
Fri Aug 10, 2018 7:08 am
Hi All
Just after some feedback on this one. Not sure of the cropping. Its not tight on the plane however I wanted to try to include some of the rain cloud background as a contrast to the white of the plane.
Thanks in advance :-)
Chris
Miguel1982
Fri Aug 10, 2018 5:17 pm
Hi Chris, I think that by cropping tighter you won't lose any significant feature of the clouds or background, so I would go for that.
Miguel
ChrisLait
Sat Aug 11, 2018 4:43 am
Thanks Miguel
Do you think this one is any better?
Chris
DL747
Sun Aug 12, 2018 4:13 am
To me the sky looks noisy and there are hints of oversharpening, registration and winglet in particular
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
ChrisLait
Thu Aug 16, 2018 12:14 pm
dutchspotter1
Thu Aug 16, 2018 7:17 pm
1. Overexposed, oversharped
2. same
3. low contrast, oversharped
4. same
5. backlit, upper part of the sky is very bright
6. Overexposed/low contrast, oversharped
7. Oversharped, but some parts look blurry/soft. Also a bit low contrast
8. Probably the best one, but still a little bit oversharped
9. Similar to 7.
10. Oversharped, overexposed, too much contrast.
NO URLS in signature
ChrisLait
Thu Aug 16, 2018 9:47 pm
Thanks for your feedback .. I am a little disappointed that none are any good but that’s more frustration with myself. The oversharpening im guessing is a workflow issue as I have changed lenses to a much better lens but not really changed my process.
I’ll go back to re-editing and see what I can improve.
Thanks again :)
airkas1
Fri Aug 17, 2018 8:47 am
I agree with Joost's comments. The overexposure in most cases isn't very bad and will just require a minor tweak in highlights (maybe -20). The Brunei is unfortunately a no-go due to the light. From #7 onwards, there isn't much oversharpening, but they do look soft.
ChrisLait
Fri Aug 17, 2018 1:22 pm
Thanks Kas. Looks like I’ll be doing some re-editing. Fortunately I already have a full queue do I have time to get these ones sorted.
Much appreciated :-)
ChrisLait
Sat Aug 18, 2018 3:18 am
Hi All
After reviewing the above feedback and re-editing, hopefully I have improved the next batch sufficiently. Would appreciate your thoughts.
QF 737 (VH-VZO) - https://image.ibb.co/gcG4oK/Qantas_737_ ... 818_V2.jpg
QF Q400 (VH-LQQ) - https://image.ibb.co/egRXaz/Qantaslink_ ... 818_V2.jpg
QF Q400 (VH-LQH) - https://image.ibb.co/muPqTK/Qantaslink_ ... 818_V2.jpg
QF Q400 (VH-QON) - https://image.ibb.co/dLvKNe/Qantaslink_ ... 818_V2.jpg
Tiger A320 (VH-VNB) - https://image.ibb.co/j2kavz/Tigerair_A3 ... 818_V2.jpg
VA 737 (VH-YFU) - https://image.ibb.co/cU0m2e/Virgin_Aust ... 818_V2.jpg
VA 737 (VH-YUG) - https://image.ibb.co/bT2Naz/Virgin_Aust ... 818_V2.jpg
VA 737 (VH-VUC) - https://image.ibb.co/fDaavz/Virgin_Aust ... 818_V2.jpg
VA 737 (VH-VUA) - https://image.ibb.co/gswhaz/Virgin_Aust ... 818_V2.jpg
Also, the Royal Brunei had a mask on the sky in the last version to try and brighten it up a bit but it looks like this may have caused some problems. This is the version without the mask - maybe its better, maybe its still destined for the bin?? https://image.ibb.co/ijpeNe/Royal_Brune ... 818_V2.jpg
Thanks as always
Chris
Runway28L
Sat Aug 18, 2018 3:50 am
VH-VZO: Cockpit area looks soft. I'd add some selective sharpening to that region.
VH-LQQ: A bit yellow but may be ok.
VH-LQH: Could be a bit brighter... I would add another 10%.
VH-QON: Ok.
VH-VNB: Ok.
VH-YFU: A bit soft/blurry. Lighting doesn't seem to help.
VH-YUG: Oversharpened in some areas.
VH-VUC: I'd go over the right winglet's edges with the eraser tool.
VH-VUA: Same as above.
The Royal Brunei is backlit, oversharpened, and hazed. I'd unfortunately bin that one.
ChrisLait
Sat Aug 18, 2018 3:59 am
Thanks .. RB going in the bin .. as for the others it sounds like they are headed in the right direction but some still not quite there yet! I'll go back to editing.
ChrisLait
Sat Aug 18, 2018 5:19 am
Also Just after some feedback in this A380. It was rejected a little while ago for Soft, Low Contrast, Noise, and Underexposed abd I have only just now got back to seeing if I can do a re-edit on it.
QF A380 - https://image.ibb.co/bQQHse/Qantas_A380 ... OQF_V2.jpg
Thanks in advance
ChrisLait
Sat Aug 18, 2018 12:11 pm
HarryLi
Screener
Sat Aug 18, 2018 4:44 pm
QF A38 : OVC weather makes the sky almost Overexposed. It needs some CW Rotation i think.Slight OS but not serious to me. Hard to make it due to the poor light condition and marginal quality sorry.
VXU : Tail part looks OS to me but not serious. Could be brighter. Halos around aircraft.
EBC : Also tail looks OS to me but not quiet serious. Could be brither. Halos around aircraft.
EKX : Very poor light condition which could probably be given Dark/UE. Some parts also look blurry. Slight vignetting. Hard to make it i think.
YIB : It has slight halos but not as serious as VXU and EBC.
YVA : Marginal quality i think, still has slight halos above the aircraft and around the winglet.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
ChrisLait
Tue Aug 21, 2018 9:50 am
Thanks Harry. I'll see what I can do with most of these although EKX is now in the bin.
ChrisLait
Tue Aug 21, 2018 10:08 am
Hi Everyone
Quick one .. the below picture appears to have halos especially around the landing gear. As I don't normally encounter this issue, I am a little lost in how to remove these. I have watched a couple of Youtube clips which sounds easy but I'm not a Photoshop user so got lost pretty quickly. (I am using lightroom)
Does anyone have any tips, trick or just general guidance on how to fix these?
QF A330 (VH-EBC) - https://image.ibb.co/cY6S8K/Qantas_A330 ... 818_V1.jpg
Thanks and Very much appreciated!!
Chris
HarryLi
Screener
Tue Aug 21, 2018 12:54 pm
Hi Chris,
Halos are hard to remove or cover actually. I encounter sometime but most of time they occur when my editing process has problem. For example, using too much Highlight & Shadow will cause, HDR will cause (It doesn't look like you apply it), using too much Noise reduction could cause it too.
I would suggest you to check the origin image first to see if they have already existed before you screen.
Harry
ChrisLait
Tue Aug 21, 2018 1:01 pm
Thanks Harry. I’ll go back and check the original and see where it leads me.
ChrisLait
Tue Aug 28, 2018 9:42 am
Hi All
Just after some feedback on this one. It was taken against quite a dark sky just before the rain set in. I think it looks OK, but just after a 2nd opinion particularly on the exposure of the aircraft. Not sure if its just because its white and stands out against the sky or, perhaps its slightly overexposed.
I have a number of others to edit similar to this so if this one is OK, then there is a good chance thee others will be too.
Thanks as always
Chris
airkas1
Tue Aug 28, 2018 10:18 am
It's a bit low in frame and could use maybe +5/+10 contrast.
ChrisLait
Tue Aug 28, 2018 10:34 am
Thanks Kas .. that sounds easily fixable if that is all that is wrong with it.
This is another similar one I would appreciate feedback on ..
airkas1
Tue Aug 28, 2018 11:10 am
Look good to me.
ChrisLait
Tue Aug 28, 2018 11:26 am
Thanks Kas
ChrisLait
Wed Sep 05, 2018 10:27 am
Hi Everyone ..
Just after a bit of feedback on this LATAM 787-9. It was taken pretty much on sunset , on a cloudy day with not much light around (the lens certainly helped pull it out this far!) however I keep looking at it thinking its too blue or too dark.
I think I have pushed it about as far as it will go so your feedback would be much appreciated .. because I am just not sure on this one.
Thanks as always
Chris
HarryLi
Screener
Fri Sep 07, 2018 5:36 pm
Hi Chris,
The LATAM B787 looks poor quality for me. Since the background is brighter than the aircraft, the aircraft seems unerexposed. Some parts look Oversharpened to me such as REG and tail.Engine and gears look bit of iffy as they look like blurry to me. Hard to make it i think.
Harry
ChrisLait
Mon Sep 10, 2018 10:10 am
Thanks Harry. Your feedback confirmed my thoughts. This one is confined to the bin.
Much appreciated as always
ChrisLait
Thu Sep 13, 2018 9:42 am
Hi All ..
Provided my current screening list is accepted, I will be on 99 photos which means I have been looking for one to be my 100th. I have selected the one attached however, I would just like some feedback on it before uploading. I think its good and will make it but I don't want to load it and then have if rejected so thought I would test it out here first.
Thanks as always for your thoughts
Chris
airkas1
Thu Sep 13, 2018 9:46 am
The bottom outline of the aircraft seems a bit sharp, plus the hor.stab. Using the eraser on these areas will remove the sharpening and things will look smoother. Otherwise looks nice.
Feels like many people hitting 100 this week, good on all of you!
ChrisLait
Thu Sep 13, 2018 9:51 am
Thanks Kas. Will do. Looks like I have about a week before my queue is cleared so I’ll do a bit of editing and load up again for review in the next couple of days.
100 has come round fast. Thanks for all the help you have provided to help me get there!
ChrisLait
Thu Sep 13, 2018 10:35 am
Have re-edited and hopefully have pulled the sharpening back on the bottom of the aircraft and the hor.stab.
Can you please pet me know if I have pulled this back enough, not enough or now too much?
airkas1
Thu Sep 13, 2018 11:55 am
I don't see the difference, but it looks passable as is (maybe my morning eyes were a bit strict on you).
ChrisLait
Thu Sep 13, 2018 11:58 am
Haha ... maybe I’ll go with the original then! :-)
ChrisLait
Fri Sep 14, 2018 1:29 pm
Just after some feedback on this Qantas 737. It was taken 15-20 mins after sunset but just before the light totally disappeared.
Thanks as always
Chris
dutchspotter1
Fri Sep 14, 2018 6:48 pm
Oversharped, but the rear of the a/c and top of the tail look blurry.
ChrisLait
Sat Sep 15, 2018 1:39 am
Thanks. I might have gone too hard on the sharpening due to the time of day and to maybe compensate for that bit of blur you mentioned.. I guess I couldn’t hide it and it will go in the bin. Shame though as I think it’s a nice pic otherwise :(
ChrisLait
Sat Sep 15, 2018 5:15 am
Just after some feedback on this one please... mainly for motive. I know fences are a contentious topic and while I would always prefer not to have one in the frame, sometimes it happens.
I have reviewed the acceptance guide and feel that the fence line in the above shot would fall into the acceptable category as it is not more than 1/3 of the frame .. "Fences are often a problem when photographing static displays at airshows. Try to work around them when shooting if possible. They will lead to a motive rejection on airliners.net. For regular shooting situations, fences should not block any part of the aircraft. Fences taking up more than one-third of the frame can also be considered motive rejections even if not blocking part of the aircraft."
Putting aside personal preferences one way or the other .. does the above shot fit within the acceptance criteria and if yes .. is it also an acceptable photo?
Thanks for the feedback as this will help with a couple more I have where the shot is good but there is similar amount of fence.
Chris
dutchspotter1
Sat Sep 15, 2018 6:45 am
Looks slightly oversharped, e.g. jaggies near the tail and trailing edge of the left wing.
The light is absolutely perfect, but next time you should use a stepladder. Without the fence the photo would be so much better (even though this one should be accepteble as per A.net standards).
ChrisLait
Sat Sep 15, 2018 7:51 am
Thanks Dutch. You are right, the light for this one was perfect. Was definitely the right time of day! I agree that it would have been preferable to have the step ladder .. but just one of those things this time :-( The sharpening is easy enough to fix so looks like while not as good as it could have been, I'm pleased to have another opinion that the fence isn't going to kill this one off.
I do have alternative to the fence shot ...
ChrisLait
Fri Sep 21, 2018 9:16 am
Hi everyone, hope you can help
Just had this one rejected for Blurry and Under Exposed. Happy to accept this decision but so I can continue to improve, I am interested in your thoughts on where the blurriness is as obviously I missed it when selecting the pic.
Not worried about the under exposed as thats easily fixed but if its unfixable blurry, then I guess its going in the bin.
https://imgproc.airliners.net/photos/airliners/5/8/9/5186985.jpg?v=v44ddc143f5c
Thanks as always!
Chris
airkas1
Fri Sep 21, 2018 9:38 am
The tail section looks blurry.
ChrisLait
Fri Sep 21, 2018 9:46 am
Thanks Kas. In the bin it goes then.
ChrisLait
Fri Sep 21, 2018 10:20 am
.. just after some general feedback on the below Garuda Indonesia A330.
Just had a number of rejects come through for the first time in a while (2 did get overturned on appeal though) so just checking in to make sure I'm back on track.
dutchspotter1
Fri Sep 21, 2018 10:56 am
Excellent light, looks good to me except there might be halo's around the bottom of the fuselage/landing gear, but unable to judge on my work screen.
airkas1
Fri Sep 21, 2018 11:36 am
The bottom outlines (fuselage, wings, gear, etc.) are a bit too sharp. Otherwise nice.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 9
