andrewmoir
Screening inconsistency
Tue Jun 05, 2018 4:33 am
I had this photo rejected for being underexposed: https://imgproc.airliners.net/photos/air ... f0b149a037
and this one for "blurry": https://imgproc.airliners.net/photos/air ... b71d38b569
airkas1
Head Screener
Re: Screening inconsistency
Tue Jun 05, 2018 9:26 am
Not sure why rejections for 2 different photos is seen as inconsistency?
The Delta will stand a bit more brightness and is also a bit oversharpened. The Westjet does look blurry/poor quality (and a bit low in frame).
andrewmoir
Tue Jun 05, 2018 1:22 pm
The brightness is pretty much cranked on the Delta. Also where on the Westjet do you see blurriness?
airkas1
Head Screener
Tue Jun 05, 2018 2:59 pm
the Delta can use some 0.3 increase in brightness (which is quite a bit). The fuselage of the Westjet seems blurry and OS to compensate.
alevik
Tue Jun 05, 2018 7:43 pm
The Delta is quite a bit underexposed - looking at the levels in PS it seems you may have forgotten to adjust them? The Westjet looks out of focus and oversharpened in an attempt to fix.
I have the same question as Kas - were these rejected for different reasons previously? Unclear how this relates to inconsistency.
Improvise, adapt, overcome.
andrewmoir
Fri Jun 08, 2018 4:35 am
I appealed 3 rejections within the last 2 weeks and all 3 were accepted into the database. In fact one of the photos gained 2K views in 24 hours. You need to train your screeners better.
airkas1
Head Screener
Fri Jun 08, 2018 5:13 am
Good thing the appeal function works properly then.
Also, in the past 2 weeks you're 3/5 in appeals, not 3/3.
andrewmoir
Fri Jun 08, 2018 1:19 pm
That should not be the only way to get a photo accepted. But it appears to be that way.
scbriml
Tue Jun 12, 2018 11:16 am
It certainly isn't, but you have a long history of complaining about "unfair rejections".
You need to learn how to read the Levels histogram - it's flat on the white end meaning the image is underexposed.
A quick levels adjustment on the left half of the image shows how dark the original is:
Users browsing this forum: fsx98 and 6 guests
