DL747
Re: Pre-Screening DL747
Fri Aug 24, 2018 7:09 pm
Hi all, here's the re-edits on the MAX 7 and the 130, along with three more. Doing something a little special for 100, so focusing on getting to 99 for now lol. As far as I can understand, the 787-10 from this angle should not be considered double with the one that was accepted into the db already, since it is a different side and angle. Am I correct in thinking that? Thanks!
KC-130J: https://imgproc.airliners.net/photos/ai ... 721d4fd5df
737-MAX7: https://imgproc.airliners.net/photos/ai ... f5c8cf9307
WN 738: https://imgproc.airliners.net/photos/ai ... 9c9147a11f
Saudi 77W: https://imgproc.airliners.net/photos/ai ... b589893cce
787-10: https://imgproc.airliners.net/photos/ai ... 4a4cff1a6b
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
dutchspotter1
Sat Aug 25, 2018 6:43 am
All except Southwest seem a little too bright, especially the 787-10 which has whiteouts.
Southwest might need a little CCW rotation.
Saudi is low in frame (too much sky)
NO URLS in signature
DL747
Sat Aug 25, 2018 8:06 am
Thanks Dutch! I brought down the exposure on the 130 quite a bit and dropped highlights on the MAX quite a bit as well. The Saudi does look a little low to me, but I think I'll wait for screener feedback to be certain of adjustments.
DL747
Mon Aug 27, 2018 6:40 am
So here are re-edits of the MAX, 787-10, and Saudi. Additional/screener feedback on the two from the original post (WN 738 and KC-130J) along with these three new would be great. Thanks!
Saudi 77W: https://imgproc.airliners.net/photos/ai ... 9448abd62c
787-10: https://imgproc.airliners.net/photos/ai ... 26121e8b2a
737-MAX7: https://imgproc.airliners.net/photos/ai ... 2b6db848fc
airkas1
Tue Aug 28, 2018 10:21 am
The Saudi is decently centered, although the empty sky vs busy foreground make it look low in frame. But that's an optical illusion.
The 787-10 seems alright.
The MAX7 looks nice too.
DL747
Tue Aug 28, 2018 1:03 pm
Thanks Kas! Do the WN and the KC-130 look alright as well?
Kaphias
Tue Aug 28, 2018 1:52 pm
Why is this not taken into account? It's long been said that vertical centering is not an exact science, but perception. If a photo appears low/high in frame because of the background, than it is.
airkas1
Tue Aug 28, 2018 2:56 pm
WN looks somewhat blurry on the engine & nose, otherwise alright
The C130 I'm not sure, but give it a go.
As for the centering. Good point. And while I'd also be fine with the aircraft a bit higher in frame, I find the current centering passable as well.
DL747
Tue Aug 28, 2018 5:00 pm
Thanks again, I agree the WN appears blurryish but not sure why, since the original is pretty sharp. Here's a re-edit with some more sharpening. Thanks!
WN 738: https://imgproc.airliners.net/photos/ai ... 137fe66d9a
DL747
Sun Sep 02, 2018 3:54 pm
So updates, 130 was accepted, as was 787. The Saudi was rejected for low in frame. Is that worth an appeal? Geometrically it’s actually slightly high. The MAX was rejected for noisy banding and vignetting, so I guess I’ll try again with that one.
DL747
Tue Sep 04, 2018 6:22 am
So here's a re-edit of the MAX, highlights decreased, but not as much to avoid haloing, along with hopefully what will be #100 in the db. Thanks all!
MAX: https://imgproc.airliners.net/photos/ai ... e30f73fdc9
DC-3: https://imgproc.airliners.net/photos/ai ... be0ac6a5d7
DL747
Mon Sep 10, 2018 6:52 am
So still looking for feedback on those two, they should be screened within the next 48 hours or so. Here are a few more as well. Thanks!
DL 752: https://imgproc.airliners.net/photos/ai ... 719d19be42
Thai AF 738: https://imgproc.airliners.net/photos/ai ... 4a287ad675
UH-1: https://imgproc.airliners.net/photos/ai ... 206b5af9bc
dutchspotter1
Mon Sep 10, 2018 3:09 pm
DC-3: feels unbalanced to me. A/c is in the left part of the frame, the right wing is cut off too much.
DL 752: blurry
airkas1
Mon Sep 10, 2018 3:33 pm
The crop on the DC-3 is fine. Unable to comment on the rest since I'm on my work PC.
DL747
Tue Sep 11, 2018 6:29 am
Thanks Dutch and Kas. The 752 was sharp at full size, so maybe there's something wonky with my resize. Kas, or another screener, if you all are able to comment on additional items, I'll wait for those before making changes. Thanks!
airkas1
Tue Sep 11, 2018 10:28 am
DL: blurry (nose), overall soft at best.
Thai: marginal with hints of OS on the tail and registration (why does it have a dutch reg.?)
UH-1: better to move the crop a bit to the left and use 3:2 ratio.
MAX: looks alright.
DC-3: soft on the fuselage.
DL747
Tue Sep 11, 2018 3:59 pm
So some updates...the screening team moved faster than I thought and the MAX/DC-3 got screened. DC-3 was accepted as #100! MAX rejected for oversharpened. Should I appeal that?
Now, for the images not screened. Thanks Kas, must be something with the resizing on the DL. I have no idea why the Thai has a Dutch reg, that didn't make sense to me either. Is it marginal for overall quality or something in particular? I had a mental error going 4:3 on the Huey, so I'll fix that up. Personally I'm not a fan of chopping the front rotor off, would it be acceptable leaving it in frame?
fsx98
Tue Sep 11, 2018 5:05 pm
Congrats on your 100th photo!
DL747
Tue Sep 11, 2018 10:59 pm
Thank you Victor!
DL747
Wed Sep 12, 2018 7:49 am
Hi all, if a screener could clarify my above questions, that would be great! :) Here are some re-edits and a couple new ones. Thanks!
DL 752: https://imgproc.airliners.net/photos/ai ... 999121ec08
UH-1: https://imgproc.airliners.net/photos/ai ... 14848b25b4
73G BBJ: https://imgproc.airliners.net/photos/ai ... 3449dd1e05
P-51: https://imgproc.airliners.net/photos/ai ... aa1bf45cfb
dutchspotter1
Wed Sep 12, 2018 8:12 pm
DL 752: looks better now
UH-1: love this shot, looks like it was taken in the seventies or so. The nose could probably use some more sharpening
73G BBJ: windowline is extremely vague (i.e. low contrast). The image could use a little more contrast overall, but I don't think it will be enough to fix the windows.
P-51: not sure about this one.
Runway28L
Wed Sep 12, 2018 8:37 pm
Seems like there is a dust spot near the top left corner of the P-51, although I'm wondering if it's just an odd cloud.
DL747
Thu Sep 13, 2018 5:35 am
Thanks Dutch and Evan. The spot is a distant cumulus cloud. I'll wait for a screener to chime in to be sure before making adjustments.
airkas1
Thu Sep 13, 2018 9:55 am
DL: much better than the previous version, but still blurryish
UH-1: passable
BBJ: HIF, otherwise passable
P-51: passable
Runway28L
Thu Sep 13, 2018 11:02 pm
Ah alright. Looked at it again on my PC this time and I have to agree. The P-51 looks good to me then.
Congrats on 100 images accepted BTW. ;)
DL747
Fri Sep 14, 2018 4:04 am
DL747
Thu Sep 20, 2018 12:37 am
Hey all,
Thai 738 was accepted, still looking for feedback on those 4. Interesting note, apparently it had a Dutch reg for cabin outfitting. That airframe has also undergone at least 4 registration changes by my count. Here are a couple new ones as well. Thanks!
P-8: https://imgproc.airliners.net/photos/ai ... c194973f33
DL 739: https://imgproc.airliners.net/photos/ai ... 43c941d057
airkas1
Fri Sep 21, 2018 1:26 pm
P8 and DL 739 look passable
Delta still looks blurry, BBJ passable, P51 blurry front half of fuselage (incl. cockpit) and Ryanair high in frame.
DL747
Sat Sep 22, 2018 1:18 am
Thanks Kas! I’ll probably dump the DL 752 then. I don’t see the blur on the 51, but I can try it again. FR sounds like an easy fix. The first P-51 (blue one NL51KD, Delta model) was rejected for OS and blur, and I appealed that per your confirmation it looked passable as well as Evan’s remarks. I’ll have some re-edits when I get back to my editing computer sometime today or tomorrow.
DL747
Sat Sep 22, 2018 5:39 am
So the appeal also rejected. Quite frustrated. Have one screener and uploader saying it looks good, then its blurry/oversharpened, now its "soft at best." I guess I can see a little softness, but I'm kinda lost. It looked good to me...
DL747
Sat Sep 22, 2018 7:50 am
Hi all, here's some re-edits. Decided to go with a different shot from the NL51KD series, in hopes it removes the supposed blurry/soft/os issues. Added some sharpening to the other Mustang (Impatient Virgin), the original is soft but free of blur as far as I can tell. Moved the FR higher in frame. Thanks!
FR 738: https://imgproc.airliners.net/photos/ai ... ee56c12938
NL51KD (P-51D): https://imgproc.airliners.net/photos/ai ... 96b85e41ad
NX5087F (P-51B): https://imgproc.airliners.net/photos/ai ... 9e1594ab18
airkas1
Tue Sep 25, 2018 6:38 pm
N5087F looks blurry and oversharpened to compensate.
The other 2 look passable.
DL747
Tue Sep 25, 2018 10:16 pm
Thanks Kas. Where are you noticing the blur/OS? The original is pretty sharp so possibly something went amiss in the workflow.
DL747
Sat Oct 06, 2018 10:47 pm
So I have returned, took a bit to get moved back to university again and then find a bit of time to edit/upload, here are five new ones. Thanks all!
N54GZ (Mallard): https://imgproc.airliners.net/photos/ai ... f88f93b8c5
N51ZM (P-51): https://imgproc.airliners.net/photos/ai ... 4ae1e6407c
B-1165 (CZ 738 MAX): https://imgproc.airliners.net/photos/ai ... 08dfd55c75
N259DS (328Jet): https://imgproc.airliners.net/photos/ai ... a089037c1f
N308UP (UP 767): https://imgproc.airliners.net/photos/ai ... 2dd61b7a42
Runway28L
Sun Oct 07, 2018 12:53 am
N54GZ: Trailing edge of the wing looks OS but otherwise passable.
N51ZM: Front part of the aircraft is borderline soft but I'd say it's passable.
B-1165: Passable
N259DS: Noise on the green part of the fuselage.
N308UP: Tough call on framing. It feels a little low but I checked the image with grids and I'd say it's likely passable.
HarryLi
Screener
Mon Oct 08, 2018 3:17 pm
N54GZ : Slight HIF to me. I would tend to move it bit of lower since the tail dominate a lot upper space.
N51ZM : Partly soft / blurry to me (Iffy). Reducing exposure or highlight slightly would be better IMO.
B-1165 : Tad Oversharpened to me.
N259DS : Tad cyan/green cast. Otherwise looks not bad to me.
UPS : Tad yellow/green cast on the aircraft probably due to morning light. I would tend to reduce bit of it. Iffy level for me, seems bit of CCW needed.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
DL747
Tue Oct 09, 2018 12:29 am
Thanks Harry. Here's re-edits of everything but the Mallard, I based that one off of other accepted images, could a head screener weigh in there? I have no issue with lowering it, but I want to make sure I'm doing the correct adjustment. Thanks!
N51ZM: https://imgproc.airliners.net/photos/ai ... f390450f17
B-1165: https://imgproc.airliners.net/photos/ai ... b3f61bfbf6
N259DS: https://imgproc.airliners.net/photos/ai ... c669d6dfee
N308UP: https://imgproc.airliners.net/photos/ai ... efe52171f0
airkas1
Sun Oct 14, 2018 2:59 pm
I just saw this photo:
Please keep this thread in mind when uploading: viewtopic.php?f=7&t=1353727
I've submitted the necessary correction for this image now, so no action needed from your side for this particular photo.
DL747
Mon Oct 15, 2018 3:33 pm
Thanks Kas, I did know about that, but old habits die hard and they got the best of me recently. I'll be doing that going forward for sure. Any feedback on those four above? I'll be redoing the Mallard sometime in the next few days after my midterms settle down.
airkas1
Tue Oct 16, 2018 7:08 pm
51ZM is nice but on the cyan side. Needs to be a bit warmer. It seems like all saturation except for the reds are gone.
I'd accept the other 3 (as well).
DL747
Fri Oct 19, 2018 6:32 am
Thanks Kas, I'll have a reupload of the Mustang tomorrow. In the meantime, this: https://imgproc.airliners.net/photos/ai ... 8a4fb9dd78 was deprioritized and I'm not really sure why. Its an unexpected visit of a military aircraft to an airport that doesn't usually get this traffic, as well as a governmental VIP, so in theory covered by two different priority categories?
DL747
Tue Oct 23, 2018 8:45 pm
Alright so the USAF 73G was accepted, here's the re-edit of 51ZM, and a Four Seasons 757. Thanks!
N51ZM: https://imgproc.airliners.net/photos/ai ... 7d1a25b7da
G-TCSX: https://imgproc.airliners.net/photos/ai ... c1fc06f31e
airkas1
Wed Oct 24, 2018 9:41 am
Bit tired eyes, but both look fine to me.
DL747
Wed Oct 24, 2018 3:34 pm
Thanks Kas, I totally empathize there, we're right in the middle of university midterms right now! I'll check back with a few more in a few days.
DL747
Sun Nov 04, 2018 7:20 am
dutchspotter1
Sun Nov 04, 2018 7:09 pm
The UPS looks a little too green/yellow, other than that I think they are good to go.
airkas1
Thu Nov 08, 2018 11:03 pm
I agree with Joost (the above poster).
DL747
Sat Nov 10, 2018 6:35 pm
Thanks Joost and Kas, I have pulled that one for now and will do that simple fix when back from test flight spotting today.
DL747
Sun Nov 18, 2018 12:48 am
So this got rejected for blurry, appealed, and rejected for "soft at best." I am thoroughly confused as to how this is blurry, and/or where it is soft. Any thoughts?
https://imgproc.airliners.net/photos/ai ... ab6157ca92
fsx98
Sun Nov 18, 2018 4:37 am
I'm guessing that either the Aeroflot title is soft, or the aircraft nickname written in Russian is also soft, or both.
