• 1
  • 4
  • 5
  • 6
  • 7
  • 8
fsx98
Re: Pre-screening photos - fsx98
Tue May 28, 2019 7:28 pm
I have photos from my LA trip for feedback please:
N526VL:
VH-ZNC:
B-LJC:
N183DN:
N642FE:
D-AIMH:
jelpee
Screener
Tue May 28, 2019 11:33 pm
My thoughts:
Volaris A320: Underexposed; Be careful when adding the brightness since it may blow the highlights on the nose. Angle of lighting is tricky.
Qantas 787: OK for me.
Cathay Cargo 747: Angle of light is rendering this under exposed.
Delta B763: Angle of light is rendering this one underexposed as well. A bit over sharpened and could use more contrast.
FedEX MD11: Top light is rendering the nose as underexposed.
Lufthansa A380: Looks good to me.
Jehan
fsx98
Wed May 29, 2019 12:27 am
Thanks Jehan; will keep the QF 787 and LH A380 in queue and fix the remaining ones.
While I fix these photos, I also have some photos that I would like feedback on:
N775UA window:
N910DU (a long-shot attempt):
N941LT (fixed halos and noise rejections):
N258NN:
N237NN:
N216UA:
airkas1
Head Screener
Wed May 29, 2019 9:59 am
Qantas is low contrast/weak blacks and a bit iffy quality-wise, but still your best bet. All others are rejections for me, sorry.
Volaris: UE, marginal quality
Cathay: UE, poor quality
Delta: OS (very jaggy), marignal/poor quality
FedEx: blurry front half & engine
Lufthansa: blurry, oor/unbalanced crop
Wingview: very noisy, dirty above the wingtip, poor quality. Phone photo?
Delta: very blurry aft section, dirty above the "E", poor quality
941: still noisy/marginal sky, light halo around the wingtip(?)
258: heat haze, marginal quality
United: blurry, quality
fsx98
Wed May 29, 2019 11:30 am
Thanks Kas; some of these photos are long-shot chances, in which are unlikely to be accepted anyway, but gave them a shot; will bin some from the queue completely and then fix some that may be fixable.
As for the wing view, it was taken from a DSLR, so I'll see how far I could fix this one, otherwise I'll bin this one completely as well.
I have two more photos in the upload queue for prescreening feedback:
N478WN:
VH-OQK:
Crosswindphoto
Wed May 29, 2019 4:54 pm
Southwest 738: Blurry/soft, slightly OS.
Qantas A380: Heat-haze, jpeg compression, also maybe a tad OS.
Southwest might be passable at 1024 but I don't think Qantas has a chance.
fsx98
Thu May 30, 2019 8:02 pm
Thanks Tim; will try to fix the WN B738 and probably bin the QF A380; may give it another shot at a smaller size.
I have some long-shot photos in the queue that I would like pre-screening feedback on (and by long-shot, I mean photos less likely to be accepted, but to point out if there is anything that warrants a rejection):
C-GBIP:
N149AN:
LX-VCA:
HB-JNB:
N669NK:
Let me know what you guys think!
jelpee
Screener
Thu May 30, 2019 9:14 pm
Unfortunately, I don't think any of these would will approval from the screeners. From what I can see:
C-GBIP:Heat haze; blurry on the right side of teh frame).
N149AN:Heat haze and low contrast
LX-VCA: Underexposed, compression, blurry, slight green color cast
HB-JNB:Underexposed, noise, soft, blurry nose
N669NK:Underexposed; low contrast; noise
Jehan
fsx98
Thu May 30, 2019 11:00 pm
Thanks Jehan; I figured these were long-shot attempts, since I feel they aren't likely to be accepted; will bin all of these from queue and maybe fix on N669NK.
I have several more photos in the queue that I would like pre-screening feedback on:
N409AS:
N7737E:
N974AT:
N202NN:
VH-VPF:
N384HA:
N27205:
VH-ZNC:
fsx98
Tue Jun 04, 2019 11:58 am
In addition to the photos on the previous post, I have one more photo for pre-screening feedback:
N840AN:
Crosswindphoto
Tue Jun 04, 2019 4:13 pm
N409AS: maybe a tad underexposed, but otherwise ok.
N7737E: heathaze/Jetwash, also a tad UE.
N974AT: Might be ok.
N202NN: Looks ok.
VH-VPF: a tad soft at the nose, slight heat haze, might be ok at 1024.
N384HA: Jpeg compression, heat haze/jet wash, OS, Light is also kinda harsh.
N27206: Heathaze, might be ok at 1024.
VH-ZNC: Soft, doesnt look recoverable IMO.
N840AN: A tad soft, might be ok at 1024.
Wait for a screeners input.
Tim
fsx98
Tue Jun 04, 2019 9:05 pm
Thanks Tim; will wait for screeners input for all but for the time being will keep N409AS, N974AT, and N202NN in the queue.
fsx98
Tue Jun 11, 2019 8:52 pm
Update:
N237NN rejected for color, motive, noise, and UE with the following personal message:
"Too distracting glare on the fuselage."
Will most likely be binning this one for good; I have this DL E175 that I would like pre-screening feedback on:
N605CZ:
airkas1
Head Screener
Wed Jun 12, 2019 7:21 pm
605CZ: blurry/OS.
fsx98
Wed Jun 12, 2019 7:27 pm
Thanks Kas; I have a similar shot of this aircraft in the same sequence for prescreening feedback; any better from the previous photo?
fsx98
Thu Jun 13, 2019 3:36 am
Updates:
N478WN rejected for blurry and soft; re-uploaded w/ smaller size:
N57852 rejected for blurry, yellow cast color, and UE; re-uploaded w/ downsized photo, corrected color, and increased exposure:
N642FE rejected for Low Contrast and soft; re-uploaded with increased contrast and an extra kick of sharpness:
N647QX rejected for low contrast and UE; re-uploaded w/ increased contrast and exposure:
VH-ZNC rejected for low contrast and soft; re-uploaded w/ increased contrast and an extra kick of sharpness; also removed is the accidental cloning of the antenna while attempting to remove dirty spots:
N27205 rejected for noise, UE, and quality w/ a personal message of backlit conditions; binning this one for good
Including the above re-uploaded photos, I would also like pre-screening feedback on the following photo, please:
N127AA:
fsx98
Thu Jun 13, 2019 11:26 am
Update:
N941LT is in the database!
Here's another photo I would like pre-screening feedback on, in addition to the six re-uploaded photos from my last post; it may be a long-shot attempt, but was wondering if this photo would make it:
N263AK:
jelpee
Screener
Thu Jun 13, 2019 11:55 am
Looks a bit over-sharpened to me (main titles). I would also prefer it lower int he frame. Especially from this angle, the tail dominates the frame and presently looks too high in the frame for me.
Jehan
fsx98
Thu Jun 13, 2019 12:38 pm
Fair enough; will lower the aircraft in frame and take it easy on the sharpening with the main titles; thanks Jehan!
fsx98
Thu Jun 13, 2019 1:15 pm
I have another photo of B-LJC from my LA trip that I would like pre-screened:
Crosswindphoto
Thu Jun 13, 2019 5:01 pm
Cathay Paciic ( :p ): Yellow/brown colour cast, also looks a little noisy and Os to me.
fsx98
Thu Jun 13, 2019 5:53 pm
Thanks for the feedback Tim!
I have just uploaded N750SK for pre-screening feedback:
jelpee
Screener
Thu Jun 13, 2019 11:01 pm
Looks over sharpened to me. I see jaggies on the outer edges of the tail, fuselage, wings and titles.
Your CP Cargo also looks over sharpened.
Jehan
fsx98
Fri Jun 14, 2019 12:01 pm
Thanks Jehan; I have adjusted these photos and was wondering if these are any better now:
B-LJC:
N750SK:
N263AK:
And some updates:
N7737E rejected for color, dark, and soft
N974AT rejected for dark and UE
N409AS rejected for dark, halos, and UE
VH-VPF rejected for common, dark, and soft; may have to bin this one
N202NN rejected for halos, UE, and vignetting
N384HA rejected for dark, OS, and UE
N202NN is most likely fixable, while everything else (except VH-VPF) will also be a make-or-break fix attempt.
spompert
Fri Jun 14, 2019 3:56 pm
B-LJC is not centered properly (too much to the left). If I were you I would cut off the wing just behind the tail.
fsx98
Fri Jun 14, 2019 4:48 pm
Thanks for the feedback Stephan; here's a cropped version of B-LJC; how does this look?
spompert
Fri Jun 14, 2019 5:22 pm
Hmmm, the front looks a bit soft to me while the wing and wheels are a bit oversharpened in my opinion (some jaggies visible). Personally I would crop tighter on the right side, but I understand you loose a lot of pixels and thus quality.
airkas1
Head Screener
Fri Jun 14, 2019 5:25 pm
The right wingtip is cut off (motive). It also needs a cooler white balance. But honestly, the quality is not good enough and it's backlit. I would let it be.
airkas1
Head Screener
Fri Jun 14, 2019 5:26 pm
750 looks blurry/soft, Alaska has a blurry/out of focus windowline it seems.
fsx98
Fri Jun 14, 2019 5:28 pm
Thanks Kas; will bin this cropped version and maybe even the original version of B-LJC; will also bin the Alaska and probably upload a different angle of N750SK.
I have a couple more photos that I would like to have pre-screened:
N41135:
Here's a different sequence of N750SK:
VH-OQK:
fsx98
Sun Jun 16, 2019 6:11 pm
In addition to the three photos from my previous post, I would also like to have this re-upload pre-screened please:
N840AN (reuploaded w/ a downsized photo to mask blurriness and heat haze):
spompert
Sun Jun 16, 2019 8:56 pm
Hi, I see heathaze on the left wing. Don`t think it`s acceptable like this. Fuselage (American text) looks a bit soft to me.
fsx98
Sun Jun 16, 2019 9:38 pm
Thanks Stefan; kind of disappointed about the heat haze on the left wing, as I was looking forward to having my first Dreamliner photo on the database; guess I'm binning this one for good...
I have an Alaska A320 photo that I would like to have pre-screened:
N626VA:
jelpee
Screener
Mon Jun 17, 2019 11:57 am
The AA 787 also looks over-sharpened (visible along the window line and leading edge of vertical stabilizer).
The Alaska A320 looks blurry to me; not a fan of the lighting which is rendering the bottom half of the fuselage dark. Also looks yellow.
Jehan
fsx98
Mon Jun 17, 2019 12:51 pm
Thanks Jehan; I have already binned the AA 787 and will probably bin the Alaska A320 from queue.
I have a 10-year old photo taken from my old point-and-shoot camera days that I would like pre-screened:
Crosswindphoto
Mon Jun 17, 2019 4:52 pm
OS, blurry, backlit, quality.
In general point and shoot photos wont be acceptable on JP.
fsx98
Mon Jun 17, 2019 11:29 pm
Thanks Tim; I may try this one again in a smaller size and further reduction of shadows later.
In the meantime, I have a FedEx B77F photo that I would like to have pre-screened, please:
Crosswindphoto
Tue Jun 18, 2019 10:12 am
Shit, I said JP and not airliners lol.
Fedex: UE, and backlit.
fsx98
Tue Jun 18, 2019 11:27 am
Thanks Tim; I have another photo of the FedEx B77F in a different angle for pre-screening:
spompert
Tue Jun 18, 2019 3:27 pm
Underexposed, blurry (cockpit, wing tip, text), oversharpened, not fixable if you ask me.
fsx98
Tue Jun 18, 2019 4:35 pm
Thanks Stephan; will probably bin this one for now - may downsize the photo later...
I have an El Al Dreamliner photo that I would like pre-screened:
JKPhotos
Screener In Training
Wed Jun 19, 2019 6:26 am
as for the El AL Dreamliner:
It is quite underexposed, oversharpened and looks afftected by heat haze. Also has a blue cast.
I would spend my time on other shots to be honest.
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
