• 1
  • 6
  • 7
  • 8
  • 9
  • 10
fsx98
Re: Pre-screening photos - fsx98
Sun Aug 18, 2019 6:10 pm
I also have a couple more photos in the queue for pre-screening:
N661JA:
N7833A Window view of DCA:
Crosswindphoto
Sun Aug 18, 2019 8:28 pm
1 & 2: Soft, heat haze, a tad blurry.
3: Looks ok.
fsx98
Sat Aug 24, 2019 1:26 pm
Thanks Tim; will keep the 3rd one in queue and maybe fix the first two later
Post-Screening updates:
N478WN rejected for blurry and quality
"Winnie Mae" rejected for blurry; should I appeal this? Otherwise I'll resize it to 1024 wide.
Crosswindphoto
Sat Aug 24, 2019 1:43 pm
SWA: Definitely blurry towards the tail.
Winnie May: Whole image looks a little blurry, particularity around the tiles. Not worth the appeal, and to be honest, I don't know if it will work at 1024.
Tiim
fsx98
Sat Aug 24, 2019 2:28 pm
Thanks Tim; will bin N478WN completely; may try downsizing Winnie Mae and see what I'll go from there.
jelpee
Screener
Sat Aug 24, 2019 3:10 pm
N7833A Window view looks OS. Jaggeis are visible on trailing edges of winglet, awing flaps and spoilers. Perhaps a little less sharpening or sharpen in layers and erase the jaggies.
The 2 AA ERJ's look blurry to me, especially 1JA.
Jehan
fsx98
Sat Aug 24, 2019 4:36 pm
Thanks Jehan; I have applied UM only once but will not apply sharpening on re-edit.
The 2 AA ERJs will be removed from queue; will resize the two to mask the blurriness.
fsx98
Sun Aug 25, 2019 1:44 am
This may not be the best quality, but how is this one?
ABissonnette
Sun Aug 25, 2019 8:25 pm
IMHO, it looks like it has some noise/grain, and some jagged edges (Possibly JPEG compression)
But check with an actual screener first...
Andrew
Andrew
Canon T4i - 75-300mm
fsx98
Sun Aug 25, 2019 9:03 pm
Thanks Andrew; will wait on screeners' input...
airkas1
Head Screener
Tue Aug 27, 2019 8:31 am
Very noisy and poor quality, will not make it.
fsx98
Tue Aug 27, 2019 11:13 am
Thanks Kas; will remove the N299WN window photo from queue.
fsx98
Thu Aug 29, 2019 1:35 am
I have three re-uploaded photos that I would like feedback on, please:
N223WN (angle 1):
N223WN (angle 2):
N407WN:
Crosswindphoto
Thu Aug 29, 2019 7:09 am
All 3 are Soft and maybe a tad blurry in parts
fsx98
Sun Sep 01, 2019 3:44 pm
I have a photo of N761ND uploaded as priority and was originally rejected for soft and UE; corrected both of those and was rejected again for UE again, as well as high contrast; I didn't think that the contrast was bad so I left the contrast as is and also bumped up the exposure settings; uploaded the third time and rejected for high contrast and UE again, plus noise; if I lower the contrast and/or increase exposure of the photo, either the photo will have a grey feel or there would be a blow-out of the nose area or both. Is there any way I could appeal one of the rejected photos?
Here below is the most recently rejected photo:
jelpee
Screener
Sun Sep 01, 2019 9:25 pm
Lighting is not the best for this image. Could use a boost to exposure and contrast to improve the lighting (check histogram). But, the nose area looks blurry to me. Too many issue with this one for me to accept it.
Jehan
fsx98
Mon Sep 02, 2019 12:22 am
Thanks Jehan; I actually got the photo accepted to the database already after adjusting the exposure and even toning down the contrast; I have also adjusted the color settings to blue to correct yellow cast.
jelpee
Screener
Mon Sep 02, 2019 1:48 pm
Perhaps I was too harsh in my assessment. Congratulations!
Jehan
fsx98
Mon Sep 02, 2019 3:05 pm
Thanks Jehan!
fsx98
Wed Sep 04, 2019 6:30 pm
N7833A window view update: rejected for OS, but didn't use Unsharpen Mask to sharpen the photo; is this worth an appeal?
jelpee
Screener
Wed Sep 04, 2019 10:35 pm
Does not look OS to me.
Jehan
Crosswindphoto
Thu Sep 05, 2019 6:04 am
I'd appeal it.
fsx98
Thu Sep 05, 2019 2:19 pm
Thanks guys; will do that!
airkas1
Head Screener
Thu Sep 05, 2019 10:28 pm
I can see some sharp edges on the wing. Also the top middle cloud looks very oddly cut off. Did you clone there?
fsx98
Fri Sep 06, 2019 12:21 pm
For this edit, I have never used any cloning in this photo; I haven't cropped while editing this photo; is there any way to remove sharp artifacts from the edge of the wing if I haven't used Unsharp Mask to sharpen the photo?
fsx98
Sun Sep 08, 2019 7:07 pm
I have two photos of N772SK taxiing taken about 30 seconds apart; would these count as double?
Crosswindphoto
Sun Sep 08, 2019 8:00 pm
Maybe, that will likely vary from screener to screener.
However, Bump the exposure on the second a tad, and a little less contrast and it should be good to go!
Tim
airkas1
Head Screener
Sun Sep 08, 2019 8:47 pm
Yes, a double. And poor foreground on the second one.
fsx98
Sun Sep 08, 2019 11:51 pm
Thanks Kas and Tim; will bin the second one from queue and keep the first one for sure!
  • 1
  • 6
  • 7
  • 8
  • 9
  • 10
