airkas1
Head Screener
Re: Are the motives and crop on these photos acceptable?
Thu Dec 13, 2018 7:40 pm
Definitely a double. In general: same day, same side, same photographer = double.
jelpee
Screener
Tue Dec 18, 2018 3:13 pm
In addition to being a double, it would likely have drawn a motive rejection as well on account of the clipped main landing gear.
Jehan
ajaaron
Wed Dec 26, 2018 11:46 pm
Happy holidays to everyone...
Can I check out this pic of the inside of the terminal at LLBG. Thanks as always.
[url][url=https://flic.kr/p/Q3XFbr]Image[/url]IMG_3759 by Arnold Aaron, on Flickr[/url]
ajaaron
Mon Jan 07, 2019 11:29 am
Good morning all, can I get an opinion on these photos please...Happy New year to all...
This 777 below is a re-submission - I was asked to give it a tighter crop, and give it a CW rotation - hopefully all ok now - please confirm.
This A350 was rejected for being underexposed. I've added some brightness, please confirm now acceptable.
This A320 was rejected for low contrast, and having a bit of cyan colour in the photo. (Interestingly I ran it past this forum here first (see above) and got the thumbs up for it). Please advise if ok now. Thank you!
spompert
Mon Jan 07, 2019 6:15 pm
Hello Arnold,
This one looks blurry towards the end of the stairs. Also noisy.
spompert
Mon Jan 07, 2019 6:22 pm
Hello Arnold,
AC looks high in frame, oversharpened parts, Qantas oversharpened parts, BA is blurry (front), Malaysia noise on engine nr 2, EW also some noisy parts. Greets Stefan
ajaaron
Wed Jan 09, 2019 1:02 am
What are your thoughts on this? I hope all parameters are in check, and that Im one more step closer to being able to stand on me own two feet when it comes to editing!
HarryLi
Screener
Sat Jan 12, 2019 12:49 am
I can't load the image in your latest post.
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
ajaaron
Sun Jan 13, 2019 12:40 am
Image above should now show - the AA 777.
Also, have I got the centring correct on this one? -
spompert
Sun Jan 13, 2019 1:13 am
It looks slightly low in frame to me. But for this image a 3:2 ratio would work better balance-wise I guess
airkas1
Head Screener
Sun Jan 13, 2019 8:35 am
Cut the distance between the tail and top of frame in half and centering should be spot on. Crop ratio works fine in 16:9 in my opinion, but that’s up to you.
ajaaron
Wed Jan 16, 2019 1:54 am
Ok - as regards the Blue Air, I've made a tweak, and hopefully the centering is now acceptable....
Also, the AA 777 should be visible now below....is the cropping ok, and the photo acceptable? Many thanks...slowly but surely
airkas1
Head Screener
Wed Jan 16, 2019 5:34 pm
Not seeing the tweak on the Blue Air. Still low in frame for me. Unable to see the AA photo.
jelpee
Screener
Wed Jan 16, 2019 10:50 pm
The Blue air also looks blurry towards the nose.
Jehan
ajaaron
Wed Jan 16, 2019 11:16 pm
Here is the blue air again hopefully with centering now correct. As for any blurryness on the nose, do you suggest further sharpening?
jelpee
Screener
Thu Jan 17, 2019 1:43 pm
Blurriness unfortunately can rarely be fixed by additional sharpening. You might try editing it at a smaller size (1.e. 1024 pixels wide). Larger sized pictures tend to magnify flaws which can not be seen so well in smaller sized images.
Jehan
Users browsing this forum: cypilot and 5 guests
