samfgadd
Rejection Feedback
Tue Oct 02, 2018 4:30 pm
Posted in incorrect forum initially. Apologies.
-Motive
-Personal Message
-Soft
-Blurry
-Oversharpened
Can someone show me what proper sharpening looks like? I am unsure how to proceed with my editing. The first image was rejected for being soft, among other valid points. And when I tried to add some sharpening to the second one, it was rejected for oversharpening. I am trying to get better at editing, and I suppose I just need some direction and guidance.
The left-hand crop on both images are out of the camera, I am using a 200-500mm lens that is too much length for how close I was.
Thank you all! What a community this is.
jelpee
Screener
Re: Rejection Feedback
Tue Oct 02, 2018 5:54 pm
I don't see blurry, but I do see over-sharpening. There are jaggies visible on the cockpit windows as well as on the nose gear and nose gear doors.When I sharpen, I use a layer which allows me to then use the eraser tool on areas where jaggies appear. Send me a PM and I'd be happy to share my editing workflow with you.
I'm not a big fan of this crop: showing 3/4's of the aircraft makes me wonder why the rest of the aircraft is not included.Nice lighting.
Jehan
samfgadd
Tue Oct 02, 2018 6:01 pm
I appreciate that. Thank you. Believe me, I don't like the crop any more than you do, it's just the best I could do with what I had at the time. Cheers.
airkas1
Head Screener
Tue Oct 02, 2018 6:24 pm
The first photo look salvagable with a better (tighter) crop and a bit of sharpening.
The second photo *could be* blurry and oversharpened to compensate. A little hard to tell with the jaggies.
samfgadd
Tue Oct 02, 2018 6:36 pm
Jehan
Thank you both.
Crop between the "t" and "h" perhaps?
I will make those changes and roll the dice again. I am assuming I should notate a re-upload in the photographer comments?
Runway28L
Wed Oct 03, 2018 1:07 am
The first one I would crop just before the "t". And yes, I highly recommend leaving a comment to the screeners of the prior rejection and the changes made.
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
