airkas1
Head Screener
Re: Pre-Screen
Mon Nov 19, 2018 10:41 pm
757 looks blurry and OS to compensate.
Mu2 looks blurry (HH?) and needs a closer crop on the right.
C402(?) looks passable, but needs a tighter crop.
Wordpress
Re: Pre-Screen
Mon Nov 19, 2018 10:53 pm
I understand the Delta and MU2 (yes it was HH).
airkas1
Head Screener
Re: Pre-Screen
Mon Nov 19, 2018 11:07 pm
Cape looks passable.
Wordpress
Re: Pre-Screen
Tue Nov 20, 2018 4:07 pm
Some more from the same sequence, any opinions?
Runway28L
Re: Pre-Screen
Tue Nov 20, 2018 9:25 pm
N192AA: Passable
N190AA: Right wing OS, background needs NR, tighter crop on the right side (although that's just my opinion)
VP-LAD: Background needs NR
N36911: Blotchy sky
N14NA: Noisy
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
airkas1
Head Screener
Re: Pre-Screen
Tue Nov 20, 2018 9:26 pm
The 757's seem a bit affected by heat haze. The Cessna's look passable and the Falcon look flat and you cropped of a small antenna on the wingtip. Marginal light for that, but I think you could get away with that.
Wordpress
Re: Pre-Screen
Tue Nov 20, 2018 9:46 pm
Both of the 757's are affected by HH? I could see the one on the ground but I don't see it in the aerial photo (maybe soft?).
And to confirm, VP-LAD and N36911 are passable?
Here's the Falcon.
Also here's a noise reduced Cessna.
Wordpress
Re: Pre-Screen
Thu Nov 22, 2018 8:43 pm
Sorry, I can't edit my post. I wanted to make sure that the cessna noise reduced was better.
Runway28L
Re: Pre-Screen
Sat Nov 24, 2018 10:01 pm
N14NA: Crop is better. I agree with Kas that the lighting is 50/50.
VP-LAD. Sky still a bit blotchy but not as bad as the first one. Might be able to pass.
airkas1
Head Screener
Re: Pre-Screen
Mon Nov 26, 2018 9:13 pm
The airborne 757 looks slightly blurred/hazy too.
The Falcon is still a bit flat, the light not doing you any favors unfortunately.
VP-LAD looks passable.
Wordpress
Re: Pre-Screen
Thu Nov 29, 2018 3:08 pm
Thanks a ton Kas! How about any of these?
Wordpress
Re: Pre-Screen
Fri Nov 30, 2018 1:40 am
How about these same ones from the sequence?
airkas1
Head Screener
Re: Pre-Screen
Fri Nov 30, 2018 11:24 am
- I like the first C208 photo better, but both are a bit marginal.
- The Cape Airs seem passable.
- The Saab is a bit blurry on the nose but otherwise not too bad.
- Both Gulfstream photos look blurry.
Wordpress
Re: Pre-Screen
Fri Nov 30, 2018 1:19 pm
Do you think the Caravans are fixable? If they are, in what way should I fix them?
Also, I applied some selective sharpening, how does it look now? Also, would this be able to make it regardless? I don't understand what you mean by "not too bad."
airkas1
Head Screener
Re: Pre-Screen
Fri Nov 30, 2018 1:46 pm
Unfortunately the Saab still looks blurry on the nose. The Caravans look slightly blurry and I don't think much can be done to improve them. You could give it a try, but I wouldn't hold my breath,
Wordpress
Re: Pre-Screen
Fri Nov 30, 2018 5:03 pm
That's okay, I'll keep practicing and I'll have three cape airs in the queue! :lol:
Wordpress
Re: Pre-Screen
Fri Nov 30, 2018 9:37 pm
I doubt this will make it in, but how do you like it?
airkas1
Head Screener
Re: Pre-Screen
Sat Dec 01, 2018 11:46 am
I like it, but it's not going to make it here. Blurry/OOF and low quality in general, sorry.
Wordpress
Re: Pre-Screen
Sat Dec 01, 2018 12:28 pm
Yeah, I thought so. I'll leave it on my hard disk for the memories though. :)
Wordpress
Re: Pre-Screen
Mon Dec 10, 2018 6:20 pm
The 4 that were "passable" were all denied.
airkas1
Head Screener
Re: Pre-Screen
Tue Dec 11, 2018 8:43 pm
Appeal 5305809, 5301431 and 5301425 and let me know when done.
Wordpress
Re: Pre-Screen
Tue Dec 11, 2018 9:21 pm
I appealed the first two.
Users browsing this forum: No registered users and 4 guests
