rpd14
Pre-Screening feedback Rpd14
Mon Nov 12, 2018 3:42 pm
Dear all. I need your opinion about my photos
thanks in advance :) cheers :D
My Airliners.net photo collection : https://www.airliners.net/search?user=1 ... lay=detail
airkas1
Re: Pre-Screening feedback Rpd14
Mon Nov 12, 2018 5:22 pm
They look passable to me.
rpd14
Tue Nov 13, 2018 12:25 am
Thank you for your feedback. I'll keep them on the queue. ;)
rpd14
Thu Nov 15, 2018 11:40 am
Dear all
Another upload need your feedback here
Thanks in advance
ajaaron
Thu Nov 15, 2018 12:35 pm
airkas1
Fri Nov 16, 2018 4:43 pm
AirAsia: looks passable.
KLM: heathazed and oversharpened.
Finnair: blurryish, marginal
LOT: blurry, heathazed
rpd14
Mon Nov 19, 2018 11:35 pm
Thank you Kas for your feedback :) . I think 3 pics that you said will looks can't fixed. :(
rpd14
Mon Nov 19, 2018 11:39 pm
need another new feedback :D
airkas1
Tue Nov 20, 2018 10:52 pm
They all look passable, although the Gulfstream has jaggy cheatlines.
rpd14
Wed Nov 21, 2018 5:04 am
Thanks Kas for your feedback.
yes, for Gulfstream I did not add sharpend for cheatlines but when I resize it, just like that. Anyway Thank you
rpd14
Sat Nov 24, 2018 8:02 am
Dear All
I need feedback again for my pictures
Thank you in advance :D
Runway28L
Sat Nov 24, 2018 9:46 pm
The Scoot A320 could probably use a bit of a reduction in highlights due to the harsh lighting. The AirAsia A320 looks borderline OS, and the Trigana B732 is hazed plus needs some CW.
Other than that, the rest of them look ok to me.
airkas1
Mon Nov 26, 2018 9:17 pm
Scoot looks a bit flat, whites look alright.
Singapore looks blurry.
Jetstar is soft.
Singapore has really poor light (toplit).
AirAsia is not great, but might be passable.
Emirates is not great (aft section), but might be passable.
Garuda is not great, but might be passable.
B732 looks hazed.
rpd14
Tue Nov 27, 2018 9:22 am
Thank you Runway 28L and Kas for your feedback. I will try to fix it for every pics that possible or has chance to fixed.
rpd14
Sun Dec 02, 2018 3:19 pm
Dear all, I coming back posting for new feedback
Thanks in advance :)
rpd14
Thu Apr 18, 2019 12:50 am
Dear all,
quite long not posting here :D
I need your feedback for my pic as pre-screening.
spompert
Thu Apr 18, 2019 6:55 am
Looks a bit underexposed. I would also crop a bit tighter on the cockpit side. Greets Stefan
JakTrax
Thu Apr 18, 2019 8:25 am
Doesn't look underexposed to me but a touch of brightness wouldn't hurt; it does look a little flat but that's likely the milky light.
Karl
rpd14
Mon Apr 29, 2019 6:43 am
spompert wrote:
Doesn't look underexposed to me but a touch of brightness wouldn't hurt; it does look a little flat but that's likely the milky light.Karl
Thank you very much Stefan and Karl for your feedback. Last night this pic (China Airlines B-18051) was accepted. So, we know that this condition still possible to get accepted. Cheers :) ;)
rpd14
Sun Sep 22, 2019 7:15 am
Dear all, I need feedback about this picture.
Is this possible to get accepted if there is a sun reflection on the plane like this?
Cheers :)
r5k
Sun Sep 22, 2019 4:28 pm
I have 2 accepted recently that have the sun reflected in a similar way.
Richard
airkas1
Sun Sep 22, 2019 6:50 pm
It's not ideal and could lead to a motive rejection. Reducing the highlights by some -40 should help (and in general will improve the photo I think)
rpd14
Sun Dec 22, 2019 8:07 am
Richard
thanks Ricard.
yes, sun reflection should be able get accepted as long as not visible on entire fuselage (could be rejected overexposed) in my opinion :)
Hi Kas
Yes, I was try as your suggest by reducing highlights around -30 to -40 and it works :D
Thanks Kas
rpd14
Sun Dec 22, 2019 8:24 am
Dear all
this time I need feedback for my rejected pics
rejected reason : noise
rejected reason : halos and overexposed
can these two photos be fixed?
airkas1
Mon Dec 23, 2019 9:31 am
SQ: the aircraft has a very jaggy look overall, especially the cheatlines. Not seeing too much noise, but just to be sure you could add +20% noise reduction.
Xiamen looks OK to me.
rpd14
Wed Jun 17, 2020 8:23 am
Dear all
I need feedback for my picture that I want to upload.
I'm not sure about motive for this one, Is it acceptable?
Thanks in advance.
JakTrax
Wed Jun 17, 2020 8:38 am
Doesn't work for me, too much space in which there's nothing happening.
Kaphias
Wed Jun 17, 2020 2:55 pm
I like the composition but would probably bring the crop in on the right to exclude the wheel.
rpd14
Thu Jun 18, 2020 12:59 am
Thanks Karl
I agree with you, just realize too much space between both aircraft.
rpd14
Thu Jun 18, 2020 1:01 am
Thanks Kaphias for your feedback
Yes, I did wrong by crop for the main gear, it must be rejected motive.
tiziostanco
Head Screener
Mon Jun 22, 2020 10:21 am
Hi, this is a nice attempt.
There's a lot of empty space visible between aircrafts, wheel is cut as told before.
Try with another shot in sequence, with less space between the two aircrafts.
There's also a "reverse vignetting" visible in the sky on top-left and right (and sky quality is not so good).
I hope this helps.
Regards.
Fabrizio
Users browsing this forum: No registered users and 9 guests
