Schmave
Pre-Screening Feedback - Schmave
Tue Dec 04, 2018 4:57 am
Hi all, and thanks in advance. I've been struggling a little to get some shots accepted here and would like some editing feedback. I had two photos rejected recently:
https://imgproc.airliners.net/photos/ai ... 642ce4008e
This one had rejections "Info", "Personalized Message", and "Underexposed". Ok I get the first two, but maybe there is just a little too much contrast giving it an underexposure?
I re-edited this photo and uploaded it again:
https://imgproc.airliners.net/photos/ai ... 70ef87ef15
This time I got a bunch of rejection reasons: "editing", "blurry", "category", "quality", "soft", "halos". The only major changes I made were to some of the exposure settings. I don't really get why there are so many more rejection reasons on this version with just a few exposure adjustments. Can someone enlighten me?
I also edited another shot in this sequence and uploaded it to my Flickr account here:
https://www.flickr.com/photos/justinkan ... 2/sizes/o/
Do you think this one would get accepted? Any feedback would appreciated.
Runway28L
Re: Pre-Screening Feedback - Schmave
Tue Dec 04, 2018 6:14 am
The first image is a bit blurry; also underexposed but not too bad. However, it looks like you over-edited the second image. Way too bright and you probably lifted the shadows too high hence the haloing and other issues.
I like the third image the most. Although it looks a bit oversharpened and needs some noise reduction (both easy fixes).
jelpee
Screener
Tue Dec 04, 2018 2:10 pm
#1 and #2 are definitely underexposed and blurry. #3 looks over sharpened in the process of compensating for blur. Perhaps you have another one from the sequence that does not show any blur that would be better.
Jehan
Schmave
Tue Dec 04, 2018 3:46 pm
Thanks all for the feedback. For the 3rd image I agree I may have over-sharpened it a bit, but I'm still trying to get a feel for the sharpening "standard" here.
Both RAW images look plenty sharp to me when I pixel peep them. It is just after resizing and sharpening I'm having a little trouble getting it dialed in right. I'll try re-editing the 3rd one after work today with a little less sharpening and see how it looks.
jelpee
Screener
Wed Dec 05, 2018 1:02 am
When screening, if jagged edges (jaggies) are prominent along lines and edged, that indicates over-sharpening. When I apply sharpening, I do it on a duplicate layer. If jaggies are visible, then I use the eraser tool and remove the sharpening from those areas.
Jehan
Schmave
Wed Dec 05, 2018 5:10 am
Here's a re-edit of the 3rd pic above with less sharpening:
https://www.flickr.com/photos/justinkan ... 4/sizes/o/
What do you all think, is it passable? Thanks.
Schmave
Fri Dec 07, 2018 4:21 pm
What do you all think about this pic?
https://imgproc.airliners.net/photos/ai ... 0259d5a208
Runway28L
Sat Dec 08, 2018 6:00 am
Front half of the aircraft looks blurry. Seeing some minor halos around the tail and terminal building in the background.
I also see part of a reflection below the fuselage and near the engine, since it seems like you took this through a terminal window.
Schmave
Sat Dec 08, 2018 10:15 pm
Thanks for the feedback. Yeah I guess the front of the aircraft could use a little more sharpening. Is the reflection you are talking about a slight vertical line in front of and below the engine? I guess there's not much I can do about that.
jelpee
Screener
Sun Dec 09, 2018 1:05 am
I would try this at a smaller size (1200 pixels) with a light round of sharpening.
Jehan
Schmave
Sun Dec 09, 2018 5:14 am
Jehan
Thanks for the tip. I re-edited this at 1200 px wide. What do you think?
https://imgproc.airliners.net/photos/ai ... 8acaa84f6d
jelpee
Screener
Sun Dec 09, 2018 2:38 pm
I see a bit of over-sharpening (jaggies) on the trailing edge of the tail including the insignia on the tail. If you applied sharpening using a layer, you could apply the eraser tool and remove the sharpening in that area. Did you resize and sharpen your previously edited version? I recommend starting from you original image, resizing to 1200 pixels first, and then edit and apply your sharpening as the last step.
Jehan
Schmave
Sun Dec 09, 2018 4:47 pm
Jehan
Ok thanks. I did start from the original and resize first and then added sharpening. I do see what you are saying with the tail. I toned down the sharpening in the tail a little bit and re-uploaded here.
https://imgproc.airliners.net/photos/ai ... b44c6d1bc1
airkas1
Head Screener
Tue Dec 11, 2018 9:04 pm
For the last link, the fuselage looks a little soft, but otherwise it's a nice photo.
Schmave
Tue Dec 11, 2018 10:06 pm
Thanks! Do you think it will be accepted as is or should I go back for more sharpening on the fuselage? Also, are you talking about the outline of the fuselage or the lettering, logos, etc.?
airkas1
Head Screener
Tue Dec 11, 2018 10:55 pm
Windowline and titles. I would sharpen it a lottle more before uploading as final edit.
Schmave
Tue Dec 11, 2018 11:11 pm
Ok thanks. I'll do this later tonight. :)
Schmave
Wed Dec 12, 2018 4:26 am
Ok I re-uploaded the Etihad with a bit more sharpening. Hopefully that does it.
https://imgproc.airliners.net/photos/ai ... f6fec86a1b
Schmave
Sun Dec 16, 2018 10:12 pm
OK all, so I just had this photo rejected for being "soft":
https://imgproc.airliners.net/photos/ai ... 33a30f0d2a
This was one of the ones I had pre-screened. One of the pre-screened versions was said to be too sharp, so I toned it down a little. Now the screener says this one is too soft. It is barely less sharp than the one that was "over-sharp". Is it just me, or is there some inconsistency with screening, particularly when it comes to sharpening? I think I should appeal based on feedback I got from the forum here.
Schmave
Fri Dec 21, 2018 3:48 pm
Hi, thanks all for your help. I just got my first photo accepted!
https://www.airliners.net/photo/Etihad-A ... /5321549/L
jelpee
Screener
Sat Dec 22, 2018 4:09 am
Congratulations! Glad it worked out.
Jehan
jelpee
Screener
Sat Dec 22, 2018 4:11 am
Sharpening can be subjective. It looks acceptable for me.
Jehan
Schmave
Thu Jan 03, 2019 4:54 am
How does this one look? Captured the other day from San Diego:
https://imgproc.airliners.net/photos/ai ... a04df62da4
jelpee
Screener
Fri Jan 04, 2019 10:32 pm
The Alaska A320 looks too bright for my liking. Other aspects of it look fine for me.
Jehan
Schmave
Sat Jan 05, 2019 4:28 am
Jehan
How does it look now? I dropped the exposure just a little bit:
https://imgproc.airliners.net/photos/ai ... 2d73c9cf92
airkas1
Head Screener
Sat Jan 05, 2019 10:33 am
Looks alright to me.
Schmave
Sat Jan 05, 2019 5:20 pm
Thanks! I'll leave it in the queue.
Schmave
Mon Jan 14, 2019 3:44 pm
airkas,
I just got a rejection for the image above that you thought looked alright. The rejection reasons were "soft", "low contrast", and "noise". Is this worth an appeal? I don't really see the soft or noise, and at least at this time of day the sun was pretty low, so the bottom of the aircraft was illuminated a bit.
For reference here's the direct link to the image:
spompert
Mon Jan 14, 2019 7:04 pm
There`s noise on the belly of the plane and right wing, it also looks a bit soft to me
Schmave
Tue Jan 15, 2019 4:24 am
I mean, I guess I disagree, but whatever.
airkas1
Head Screener
Tue Jan 15, 2019 2:00 pm
Not seeing the noise. It's on the soft side, but still passable for me. Contrast; next time a bit more won't hurt.
Schmave
Tue Jan 15, 2019 3:55 pm
Ok, so do you think it's worth an appeal? Thanks.
airkas1
Head Screener
Tue Jan 15, 2019 4:30 pm
Yeah, try it. Will see if I can catch it.
Schmave
Tue Jan 15, 2019 4:56 pm
Thanks airkas. I just submitted an appeal.
Schmave
Wed Feb 20, 2019 6:49 pm
Hi all, I have a couple more images I was hoping could get pre-screened. Here are the two:
Southwest 737: https://imgproc.airliners.net/photos/ai ... a0c6f34277
United A320: https://imgproc.airliners.net/photos/ai ... 472d9c05f4
Thanks in advance.
JakTrax
Wed Feb 20, 2019 7:14 pm
Both look a bit cyan to me and the UA looks soft/blurry in parts (and oversharp to compensate).
Karl
Schmave
Wed Feb 20, 2019 7:45 pm
Karl
So they were both taken just before sundown, so the colors look more or less as they did at the time. I thought about correcting the white balance for the UA based on the fuselage, but then it didn't look right for the time of day.
For the UA, are there specific areas you think are blurry or OS?
JakTrax
Wed Feb 20, 2019 10:13 pm
Hmmmmm. I've been shooting for a very long time and I've never seen colours like those close to sundown - I'd expect more red/yellow.
With the UA the whole of the rear above the gold cheatline looks a touch soft to me, but the titles look oversharp. Could be the light, though. Not sure I can see blur, looking at it again - I have long stated that it's very difficult to tell from such a small image. The original file will tell you for sure.
I'm not really the right person to ask here as I only ever determine the level of sharpness from my original files.
Schmave
Thu Feb 21, 2019 4:50 am
Ok, after looking at them a little more I think you are right, they both have a bit of a green cast. If I use the color picker and choose something that should be white to change the WB it definitely looks better, though it makes it not look like just before sunset. I can add a slight bit of yellow to the color temp and I think it makes it look more like the time it was actually taken.
The original file of the UA A320 definitely looks sharp 1:1 in the original file. I think I'm still just figuring out the correct amount of sharpening for uploading here.
I re-edited both and re-uploaded. I think they look better now, but what do you all think?
https://imgproc.airliners.net/photos/ai ... 73048bd5bb
https://imgproc.airliners.net/photos/ai ... fbf1c60311
