wiggy
Re: wiggys photos
Wed Feb 06, 2019 1:51 am
thanks jehan
wiggy
Re: wiggys photos
Wed Feb 06, 2019 1:54 am
would those be worth pulling from the que
wiggy
Re: wiggys photos
Thu Feb 07, 2019 7:28 am
are those curvy lines be from the heat do you think ?
Psych
Re: wiggys photos
Thu Feb 07, 2019 12:10 pm
Hi Wiggy.
I find that it is sometimes difficult to know exactly what you are referring to in your thread, because of the one line posts - so, in this last post, I don't know which photo you are referring to when you talk about the 'curvy lines'. So if you can be more specific that would really help.
As regards the post previous to the one about the heat, I would agree that you should pull the photos you have linked from the queue, because none of those are going to make it through screening I am afraid.
Cheers - Paul
wiggy
Re: wiggys photos
Thu Feb 07, 2019 10:04 pm
Psych wrote:
Hi Wiggy.
Cheers - Paul
if you zoom up on this photo you may see it https://imgproc.airliners.net/photos/air ... ca8-15.jpg
airkas1
Re: wiggys photos
Thu Feb 07, 2019 10:25 pm
That photo is way too small to ever get accepted here, but it also seems to have quality issues.
Without sugar coating it, I would take Karl's advice to heart:
JakTrax wrote:
I'm going to pull no punches by saying that you need to considerably improve your technique because those images are awful. There really is no nice way to put it I'm afraid. Read up on photography and search the database to compare what's in there to what you're submitting. If you can't see a difference, there's your first problem......
wiggy
Re: wiggys photos
Thu Feb 07, 2019 11:50 pm
i have getting close to aircraft when im not ment to
wiggy
Re: wiggys photos
Thu Feb 07, 2019 11:51 pm
would smooth photos be acceptable ?
Psych
Re: wiggys photos
Fri Feb 08, 2019 12:15 am
Really sorry, Wiggy, but once again it’s really difficult to understand what you are saying in your last couple of posts.
wiggy
Re: wiggys photos
Fri Feb 08, 2019 1:39 am
in this link it is photo editor website i use to use and im sure can change the softness of the photos
https://www.freeonlinephotoeditor.com
Runway28L
Re: wiggys photos
Fri Feb 08, 2019 6:04 am
Sorry, but that site is going to get you nowhere. Best to download Lightroom and/or Photoshop.
In all honesty, I get the feeling that you don't really have any idea of what you are doing. I too would take Karl's advice if you want to see any sort of progress on your end.
wiggy
Re: wiggys photos
Fri Feb 08, 2019 9:43 pm
well im trying to
wiggy
Re: wiggys photos
Fri Feb 08, 2019 10:00 pm
can someone close the thread its tting out of control
wiggy
Re: wiggys photos
Sat Feb 09, 2019 4:08 am
what it matter if i took photos with the planes wings cropped ?
Psych
Re: wiggys photos
Sat Feb 09, 2019 2:09 pm
Hello Wiggy.
I know how tempting it can be to want to get your photos accepted here right away. But for this to happen you need to have some confidence about how you are taking your photos generally - which is all about getting familiarity with your camera and the basics of photography and then, these days, learning how to edit your photos once out of the camera to get them looking their best. You then need to be clear in your own mind what type of images are going to get through the screening process here, and what isn’t. So far what you have shown us won’t get through screening. Standards are high here, so there’s no shame in taking some time to get up to the required standard.
Take a look at the website generally; though I am not suggesting I am the best model, have a look at my photos via the link under my post here. If you look through a few pages of these this will give you an idea about acceptable motives, if you are able to get to an airport (I tend not to do anything too fancy). You’ll see the kind of crops that are acceptable - including crops of wings - which are fine so long as the photo is balanced.
I hope this helps.
Paul
wiggy
Re: wiggys photos
Sun Feb 10, 2019 12:37 am
Psych wrote:
Hello Wiggy.
I hope this helps.
Paul
thanks paul i'm doing a course on photography at school and also my school has a nikon d3500 slr camera
wiggy
Re: wiggys photos
Sun Feb 10, 2019 12:39 am
but how can you take photos of aircraft that are without being blurry ?
Psych
Re: wiggys photos
Sun Feb 10, 2019 9:15 am
Well, simply put, you need to hold the camera still enough and use a shutter speed fast enough that will freeze any movement. If you can do that you have a reasonable chance.
wiggy
Re: wiggys photos
Sun Feb 10, 2019 9:49 am
well i have been using a tripod
wiggy
Re: wiggys photos
Mon Feb 11, 2019 3:09 am
would half the trouble be that the lens be dirty
airkas1
Re: wiggys photos
Mon Feb 11, 2019 10:05 am
A dirty lens will never help, but it's not the main cause of the lower quality in your photos.
wiggy
Re: wiggys photos
Mon Feb 11, 2019 10:11 am
after watching video on spotters in action i am looking at buying a canon 1500D
wiggy
Re: wiggys photos
Mon Feb 11, 2019 10:13 am
and also the camera i have been using even when using a tripod it still comes out blurry
airkas1
Re: wiggys photos
Mon Feb 11, 2019 10:48 am
If there's a lot of wind, the image can still come out blurry. Even the slightest knock or vibration at your location can mess up the photo (depending on sturdyness of the tripod). If the focus is incorrectly set, the image will be out of focus (and thus appear blurry). If optimum settings are not used, the image can be blurry/out of focus. There are several reasons why this happens. A high-end camera won't fix this, although it may mask it a little. For moving aircraft, don't use a tripod. Practise steady hands.
I would really advise starting off with simple photos; sunny days, the sun behind you, the subject (aircraft) well within lens range, a shutter speed of 1/500 (or more) and an aperture of F8. Shoot Av mode. Doesn;t have to be static aircraft, can also be aircraft on approach that are within range of your lens.
wiggy
Re: wiggys photos
Mon Feb 11, 2019 9:50 pm
okey thanks because i have shooting photos of moving aircraft with the tripod and also i only have two quality settings on it>
wiggy
Re: wiggys photos
Mon Feb 11, 2019 9:51 pm
and also listen here my home airport has a little aerodrome and i have going out tom it when i'm not ment to
wiggy
Re: wiggys photos
Wed Feb 13, 2019 6:28 am
i am also interested in buying to samsung nx1
JakTrax
Re: wiggys photos
Wed Feb 13, 2019 1:42 pm
Well the NX1 is far from an entry-level camera and is mirrorless, so nothing like the EOS 1500D. Wiggy, I don't want to sound harsh here but I'm beginning to suspect that you're either trolling or have absolutely no clue about what you actually want to do. Until such time as you've figured it all out (including how to take advice without needlessly spamming the forum) I doubt you'll motivate too many people to respond.
Karl
wiggy
Re: wiggys photos
Thu Feb 14, 2019 12:01 am
:banghead:
wiggy
Re: wiggys photos
Thu Feb 14, 2019 12:04 am
with all do respect karl i am trying my absolute hardest to get good photos and i don't think you know how hard im trying.
wiggy
Re: wiggys photos
Thu Feb 14, 2019 12:05 am
could some please close the thread its getting out control !!!!!!!!!!!!!!
JakTrax
Re: wiggys photos
Thu Feb 14, 2019 3:42 am
80 posts and we're still no closer to knowing what kind of camera/lenses you require and no closer to getting you some photos accepted.
Either camera you mention will be fine but one's entry-level and one's not. For me, Samsung wouldn't be the way to go as their lens selection is nowhere near as good as Canon's.
Get your 1500D, read the manual, learn about photography and have a look through the database at what's acceptable and what isn't.
wiggy
Re: wiggys photos
Thu Feb 14, 2019 3:48 am
i have been and also im about to do a photography course as i stated early in the thread
wiggy
Re: wiggys photos
Fri Mar 15, 2019 6:27 am
hi I now have a canon EOS 1500D SLR camera
wiggy
Re: wiggys photos
Thu Mar 28, 2019 7:42 am
hi does anyone know what easy editing software there is ? fill free to reply to the message.
spompert
Re: wiggys photos
Thu Mar 28, 2019 9:50 am
Hi, Wig, I use Photoshop Elements. You have to buy it but it`s worth it, very easy to use and I use it for some years now. Good luck. Stefan
wiggy
Re: wiggys photos
Thu Mar 28, 2019 10:33 am
thanks Stefan I'll give it a go
airkas1
Re: wiggys photos
Thu Mar 28, 2019 10:39 am
I'm currently using Adobe Photoshop CC2018.
jelpee
Head Screener
Re: wiggys photos
Thu Mar 28, 2019 12:08 pm
I use Photoshop Elements as well (version 11) which serves my needs very well. I also use Dfine (Nik Software) for heavy duty noise reduction. But most of the time, the NR in PSE works quite well.
Jehan
wiggy
Re: wiggys photos
Thu Mar 28, 2019 10:16 pm
thanks for the tips
JakTrax
Re: wiggys photos
Sun Mar 31, 2019 5:51 pm
I still use Elements 5, from 2006. It's more than adequate.
Unless you're doing really low-light stuff or otherwise pushing boundaries you'll not need anything more than version 5.
wiggy
Re: wiggys photos
Mon Apr 01, 2019 1:22 am
thanks jak
wiggy
Re: wiggys photos
Mon Apr 15, 2019 1:56 am
hi all I bought a canon eos 1500d but I still get soft photos does anyone know how to fix it ? and also the zooms isn't very big on it. looking forward to hearing your comments
airkas1
Re: wiggys photos
Mon Apr 15, 2019 7:35 am
Can you show an example? It will help us determine the issue.
wiggy
Re: wiggys photos
Mon Apr 15, 2019 8:13 am
sorry im seem to be having trouble pasting links.
airkas1
Re: wiggys photos
Mon Apr 15, 2019 3:46 pm
You can upload it and then right-click the photo, copy the URL and paste it here. If the photo is not good enough, you can always delete it from the queue again.
wiggy
Re: wiggys photos
Tue Apr 16, 2019 2:22 am
that's what I have been doing.
wiggy
Re: wiggys photos
Wed Apr 24, 2019 6:08 am
does any have photoshop elements 2019
wiggy
Re: wiggys photos
Tue Apr 30, 2019 4:34 am
hi all i would like to receive some feedback from you all
https://www.airliners.net/user/photo-co ... to/5503641
wiggy
Re: wiggys photos
Tue Apr 30, 2019 4:37 am
Users browsing this forum: Google Adsense [Bot] and 14 guests
