airkas1
Head Screener
Re: wiggys photos
Mon Jul 29, 2019 2:09 pm
As for sharpening, are you sharpening in layers and using the eraser?
What values do you use for sharpening?
Can you walk us through your sharpening process?
wiggy
Re: wiggys photos
Mon Jul 29, 2019 10:02 pm
thanks kas its a long story about sharpening I started using photoshop elements 2019 as a 30 day trial then it expired so when the photos open up when I click on it it doesn't have many tools to edit photos so I have been editing it on there as I don't have photoshop any more.
wiggy
Re: wiggys photos
Tue Jul 30, 2019 4:58 am
Crosswindphoto
Re: wiggys photos
Tue Jul 30, 2019 5:17 am
Very Over-sharpened espcially around the engines.
As Kas said, not ll images can be uploaded at 1920/larger than 1600, and this is one of the ones that needs to dip down to about 1400px.
HOWEVER, with the above fixes this one may be acceptable.
Maybe a touch more contrast would help too :)
Tim
wiggy
Re: wiggys photos
Tue Jul 30, 2019 9:05 am
thanks tim
airkas1
Head Screener
Re: wiggys photos
Wed Jul 31, 2019 11:18 am
Not too bad, the engines look a bit soft/slightly out of focus perhaps, but could be masked by using a smaller size. On the latter subject, stop using these large sizes. We've told you plenty times before now. Make this one 1200px (1400px wide maximum).
wiggy
Re: wiggys photos
Wed Jul 31, 2019 10:55 pm
i tried too but it will just be the nose in the photo otherwise
Crosswindphoto
Re: wiggys photos
Thu Aug 01, 2019 5:00 am
Can you elaborate on “nose in”?
Perhaps send an example?
airkas1
Head Screener
Re: wiggys photos
Thu Aug 01, 2019 9:35 am
I'm talking about resizing, not cropping. You can just resize the entire photo and everything will stay the same, escept the size will be smaller. If your photo software the limiting factor, then get your hands on some decent editing software. It doesn't have to be expensive (if you get my drift).
Crosswindphoto
Re: wiggys photos
Thu Aug 01, 2019 9:40 am
What editing software do you use currently Wiggy?
Any version of Lightroom (except mobile) will do. Photoshop is nice but not necessary.
airkas1
Head Screener
Re: wiggys photos
Thu Aug 01, 2019 9:58 am
I would really recommend photo editing software where you have more options and/or control over the editing. And shoot RAW if your camera has it.
wiggy
Re: wiggys photos
Thu Aug 01, 2019 11:05 pm
it was photoshop elements 2019
but it doesn't work as it was only a 30 day trial and it has never worked ever since
Crosswindphoto
Re: wiggys photos
Fri Aug 02, 2019 5:37 am
Do you have some way of getting Lightroom, through school, work?
If not, you should probably invest in LR which I believe comes with PS but I’m not sure.
Either way you must get some kind of editing software.
Tim
wiggy
Re: wiggys photos
Fri Aug 02, 2019 9:34 am
Tim
thanks Tim I have trying to get dad to get it to work
Hadleigh
wiggy
Re: wiggys photos
Fri Aug 02, 2019 9:38 am
thanks i'll give it a go
wiggy
Re: wiggys photos
Sun Aug 04, 2019 10:59 pm
my mum thinks that you are trying to help me get photos accepted.
Crosswindphoto
Re: wiggys photos
Mon Aug 05, 2019 5:01 am
We are(?)
Is that a bad thing?
wiggy
Re: wiggys photos
Mon Aug 05, 2019 6:37 am
We are(?)
no I just wasn't sure that's all
Crosswindphoto
Re: wiggys photos
Mon Aug 05, 2019 7:37 am
wiggy
Re: wiggys photos
Mon Aug 05, 2019 7:41 am
sorry Tim my computer doesn't have open internet
Crosswindphoto
Re: wiggys photos
Mon Aug 05, 2019 9:16 am
airkas1
Head Screener
Re: wiggys photos
Mon Aug 05, 2019 9:45 am
Hadleigh, this entire subform is here to help people get their photos accepted. We all try to give advice in an attempt to imrpove the skills of the photographer.
wiggy
Re: wiggys photos
Mon Aug 05, 2019 10:22 am
thanks kas!!!!!!!!! i'll bare that in mind
wiggy
Re: wiggys photos
Fri Aug 09, 2019 12:18 pm
hi everyone I have just discovered that my RAW setting on my camera as kas mentioned earlier, when I saw it noticed the size of the with is 6000 px .
looking to reading your comment
Crosswindphoto
Re: wiggys photos
Fri Aug 09, 2019 1:58 pm
That’s pretty normal if I understand what you’re saying correctly.
airkas1
Head Screener
Re: wiggys photos
Fri Aug 09, 2019 3:35 pm
Yeah, that's about what I get out of my RAW files as well. Taking photos in RAW would always be my recommendation, especially if one knows how to use it to his/her advantage. You can do a lot of tweaking without ruining the file. It's pretty forgiving. There are likely tutorials on Youtube, but be careful not to overedit your images. A lot is trial and error. But you would still have to resize from 6000+ to around 1200-1600px wide.
jelpee
Screener
Re: wiggys photos
Fri Aug 09, 2019 7:38 pm
RAW has a lot of capability, but the only time I use RAW is for night time high ISO photography. For all other situations (including the majority of my images for a.net) I use JPEG. JPEG is much easier to process and for my usage works well.
Jehan
wiggy
Re: wiggys photos
Sat Aug 10, 2019 12:54 am
thanks everyone for your comments
wiggy
Re: wiggys photos
Fri Aug 16, 2019 10:42 am
wait are talking about the photo ratio ?
airkas1
Head Screener
Re: wiggys photos
Fri Aug 16, 2019 11:05 am
No, about size. But both are important, as an incorrect ratio will also result in a rejection, although we accept a variety of sizes/ratios.
Size is regarding the actual size (in pixels) of the photo. For example, 1200px wide, 1600px wide, etc.
Ratio has to do with the format (width vs height). For example, 3:2, 16:9, etc.
wiggy
Re: wiggys photos
Fri Aug 16, 2019 12:06 pm
got it kas !!!
Crosswindphoto
Re: wiggys photos
Fri Aug 16, 2019 12:56 pm
When you export, you should be able to enter the size you want. I would recommend a MAX of 1280 for your photos though.
wiggy
Re: wiggys photos
Fri Aug 16, 2019 10:39 pm
thanks tim!!!
wiggy
Re: wiggys photos
Wed Aug 21, 2019 10:58 pm
hi all i had this photo rejected for the following reasons
https://imgproc.airliners.net/photos/ai ... 74627e882f
blurry
compression
quality
oversharpened
noise
personnel massage was poor sky quality
cw rotation
I would appreciate your feedback on this photo
Crosswindphoto
Re: wiggys photos
Thu Aug 22, 2019 6:10 am
All rejection reasons are correct to me.
However, we have all told you before Wiggy, your images can't support high sizes like this. 1280px max.
Also, make sure the quality slider is at 100, and you have sharpen for screen ticked, and set to high, if you're using LR.
If you're using PS, then I don't know how the export works and you will have to wait for someone else to answer that.
Tim
wiggy
Re: wiggys photos
Thu Aug 22, 2019 7:06 am
thank tim I was once told be close to aircraft to get good photos but it mustn't help
Crosswindphoto
Re: wiggys photos
Thu Aug 22, 2019 8:04 am
it helps, you just exported wrong, or shot at the wrong settings, or both.
wiggy
Re: wiggys photos
Thu Aug 22, 2019 10:03 am
I shoot at 1920px then I crop it down to 1820px or less will that help or not?
airkas1
Head Screener
Re: wiggys photos
Thu Aug 22, 2019 10:23 am
The photo might be salvagable and I would like to give it a try at editing. If you are OK with that, send me the original image (preferable RAW, otherwise JPG) at **username**[at]airliners.net and I'll have a look.
wiggy
Re: wiggys photos
Fri Aug 23, 2019 7:13 am
ok kas I have sent it to you
airkas1
Head Screener
Re: wiggys photos
Fri Aug 23, 2019 7:51 am
Got it, thanks! It might be after the weekend that I have time to try an edit, I will get back to you.
wiggy
Re: wiggys photos
Fri Aug 23, 2019 9:55 am
wow that was quick, thanks a lot .
wiggy
Re: wiggys photos
Thu Sep 05, 2019 2:55 am
thanks for your email kas I got it
Crosswindphoto
Re: wiggys photos
Mon Sep 16, 2019 5:00 am
#1: Horizon (CW rotation, make the back treeline level,), also borderline cut off (I would crop wider), and maybe a little soft towards the tail, also OE.
#2: Possibly left in frame due to the wing, but may be ok, also a touch HIF.
#3: HIF, soft (particularly near the prop/front), but maybe passable lower in the frame.
#4: Horizon, Tail is soft, might be better at a smaller size.
#5: Backlit, no chance.
Tim
wiggy
Re: wiggys photos
Mon Sep 16, 2019 5:54 am
Thanks tim
wiggy
Re: wiggys photos
Tue Sep 24, 2019 10:20 am
TIM!!!!!!!!! if you cant say something positive keep out of it
Crosswindphoto
Re: wiggys photos
Tue Sep 24, 2019 10:29 am
You posted something very open with no other context, my answer wasn’t in any way mean or not positive.
wiggy
Re: wiggys photos
Tue Sep 24, 2019 10:59 am
oh I get ya and I have deleted it
JakTrax
Re: wiggys photos
Wed Sep 25, 2019 4:01 pm
You don't exactly have the attitude that makes people want to go out of their way to help you. And you don't seem to be particularly good at listening as, several months down the line, it doesn't seem you're any closer to getting images accepted.
What you're basically saying above is that you aren't interested in hearing anything but praise. Okay. Fine. Your images are superb and will breeze into the database. Better?
Users browsing this forum: No registered users and 23 guests
