Crosswindphoto
Re: wiggys photos
Sun Dec 22, 2019 8:39 pm
Karl, you’re right, bad phrasing on my part.
Also to correct the typo in my post. I mean floor, not flirty xD
wiggy
Re: wiggys photos
Sun Dec 22, 2019 10:56 pm
well last time I went there I had a tripod but I was holding it and I got poor quality images.
Crosswindphoto
Re: wiggys photos
Mon Dec 23, 2019 6:03 am
Holding... the... tripod...
Doesn’t that defeat the purpose?
Either way, when you use the tripod, if your lens has image stabilization, be sure to turn it off or the images will come out blurry.
Tim
wiggy
Re: wiggys photos
Mon Dec 23, 2019 6:14 am
ok
airkas1
Re: wiggys photos
Mon Dec 23, 2019 9:27 am
Never hold the tripod when taking photos, that defeats the entire purpose. And to be sure, this is a tripod:
Put the tripod on the ground --> aim, frame the photo and focus the camera --> leave it alone.
I recommend a shutter release cable, to be able to take the photo without touching the camera. It's like a remote control that is attached to the camera with a cable that you can plug in.
If you dont have one, use the in-camera timer (either 2 or 10 seconds on my camera). That way, you can press the shutter button and the camera takes the photo with a few seconds delay; enough for you to take a step back and not having to touch the camera.
wiggy
Re: wiggys photos
Mon Dec 23, 2019 9:16 pm
I have a tripod but it broken at the moment
wiggy
Re: wiggys photos
Wed Jan 08, 2020 2:01 am
can blurry photos be fixed ?
jelpee
Head Screener
Re: wiggys photos
Wed Jan 08, 2020 2:16 am
Unfortunately, No.
Jehan
wiggy
Re: wiggys photos
Wed Jan 08, 2020 2:58 am
ok thanks jehan
mrgrtt123
Re: wiggys photos
Wed Jan 08, 2020 7:34 am
No, but you need to make sure that the next you take a photo try to focus on the subject and adjust the camera settings if necessary.
wiggy
Re: wiggys photos
Wed Jan 08, 2020 11:14 am
ok ill try to thanks.
wiggy
Re: wiggys photos
Wed Jan 15, 2020 6:21 am
is one of the motive rejection for having covers on the aircraft.
jelpee
Head Screener
Re: wiggys photos
Wed Jan 15, 2020 1:07 pm
Covers are acceptable so long as it is the first image of the airframe in the database. If there is already an image of the airframe with a cover, then subsequent uploads with covers will elicit a motive rejection.
Jehan
wiggy
Re: wiggys photos
Wed Jan 15, 2020 11:47 pm
ok thanks jehan
wiggy
Re: wiggys photos
Mon Jan 27, 2020 12:04 am
hi all does anyone know why I cant submit photos ?
jelpee
Head Screener
Re: wiggys photos
Mon Jan 27, 2020 6:00 pm
The site experienced some technical issues during the past 48 hours. I understand that upload functionality is now restored.
Jehan
wiggy
Re: wiggys photos
Mon Jan 27, 2020 10:41 pm
Jehan
ok thanks jehan
wiggy
Re: wiggys photos
Sun Feb 16, 2020 10:53 pm
any thought on how this image could be improved ?
https://imgproc.airliners.net/photos/ai ... 850ca1f3fc
Starfuryt
Re: wiggys photos
Mon Feb 17, 2020 4:56 pm
It's a bit high in frame, I'm also having a hard time reading the reg.
Crosswindphoto
Re: wiggys photos
Mon Feb 17, 2020 5:53 pm
A touch HIF, UE, and very compressed.
Nice light though!
Tim
wiggy
Re: wiggys photos
Mon Feb 17, 2020 10:18 pm
Nice light though!
Tim
thanks tim
forhad0077
Re: wiggys photos
Sat Mar 21, 2020 10:15 am
Hi @wiggys think they are amazing.keep it up.
wiggy
Re: wiggys photos
Mon Mar 23, 2020 9:07 am
thanks much appreciated!!! :D
wiggy
Re: wiggys photos
Fri Apr 10, 2020 11:31 am
hi everyone I now have a canon 300mm lens and at the moment I seem to be getting blurry images when fully zoomed in.
does anyone know how to fix it ?
cheers Hadleigh
JakTrax
Re: wiggys photos
Fri Apr 10, 2020 4:03 pm
at 300mm your image frame becomes very unstable so you need a high shutter speed to get sharp results. The recommended approach is your focal length plus one stop, so 1/400th of a sec minimum at 300mm, but that will depend on how steady your hands are. This theory has always sounded a bit iffy to me and I'd recommend at least 1/640th to almost guarantee results. If you can get 1/800th, or 1/1000th, even better, although faster shutters will pick up on any heat-haze more.
Lens softness may also be playing a part if you've a cheap 300mm (is it a zoom or a prime?).
wiggy
Re: wiggys photos
Sat Apr 11, 2020 7:10 am
its a zoom. it a canon branded and also will a tripod help ?
JakTrax
Re: wiggys photos
Sat Apr 11, 2020 1:48 pm
Aside from the 70-300 f/4-5.6 L IS Canon's 300mm zooms (75-300s & 70-300s) will suffer quite bad softness at 300mm, particularly at apertures narrower than f/9. A tripod will help but you will be severely limiting your flexibility — it would be much more beneficial to improve your technique and understanding of photography.
wiggy
Re: wiggys photos
Sat Apr 11, 2020 11:30 pm
i'm trying to
wiggy
Re: wiggys photos
Mon May 18, 2020 3:38 am
Hi all!
Could I please get your feedback on this photo ?
https://imgproc.airliners.net/photos/ai ... 9a1980a4b0
Cheers Hadleigh
Crosswindphoto
Re: wiggys photos
Mon May 18, 2020 5:36 am
Very soft/blurry, not fixable
Tim
wiggy
Re: wiggys photos
Mon May 18, 2020 9:30 am
Tim
thanks Tim I wont try and fix it
Anyone else !?
JakTrax
Re: wiggys photos
Mon May 18, 2020 4:32 pm
Yes, blurry so no chance I'm afraid. Nice light though.
wiggy
Re: wiggys photos
Mon May 18, 2020 8:58 pm
thanks karl!
wiggy
Re: wiggys photos
Sun May 31, 2020 12:55 am
Hi all could i please get your feedback on this photo ?
https://imgproc.airliners.net/photos/ai ... 43bb468944
Cheers Hadleigh
bnoble
Re: wiggys photos
Sun May 31, 2020 1:09 am
Check with others, but in my opinion, soft and blurry (especially the trees in the background)
jelpee
Head Screener
Re: wiggys photos
Sun May 31, 2020 2:49 am
Could use a tighter crop: try cropping closer to the nose and tail. No worries about the background bring blurry. As long as the aircraft is in focus, it is fine. A little less brightness would be good as well.
Jehan
wiggy
Re: wiggys photos
Sun May 31, 2020 3:51 am
Jehan
thanks Jehan so should I sharpen it a bit more ?
HarryLi
Screener
Re: wiggys photos
Sat Jun 06, 2020 12:44 am
For me, the tail or the rear parts look soft / blurry for me. By the way, I would prefer to use a smaller size like 1200 - 1300px in this case.
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
wiggy
Re: wiggys photos
Sun Jun 07, 2020 11:02 am
thanks Harry
