  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
airkas1
Re: wiggys photos
Tue Apr 30, 2019 10:36 am
You need to right-click the photo and copy the URL. Any link with the word "photo-corner" in it will not work. The links should look like this:
https://imgproc.airliners.net/photos/ai ... e9ca89613e
https://imgproc.airliners.net/photos/ai ... 9e97853189
#1 is incredibly poor. Poor light, super oversharpened, way too distant.
#2 is very low in frame, underexposed, oversharpened, needs CCW,
Please look in the database of accepted photos to see how they compare to your photos.
Crosswindphoto
Re: wiggys photos
Tue Apr 30, 2019 4:32 pm
#1 to me doesn't look fixable, #2 looks like it could be fixable.
However, both photos (especially #1) wont make it at 1920px, 1280px would be good place to start.
wiggy
Re: wiggys photos
Wed May 01, 2019 6:28 am
I sharpened these photos on photoshop and i made that wasn't over 100
Crosswindphoto
Re: wiggys photos
Wed May 01, 2019 10:17 am
As Kas said, they’re OVERsharpened. A good way of telling if this is the case is if there are jaggy lines on the straight edges of things. Just turn down the sharpening a bit and fix the other points and the second one should be ok. The first will never make it.
airkas1
Re: wiggys photos
Wed May 01, 2019 12:49 pm
Honestly, both will not make it. The second one requires too much fixing and starting quality is not good enough.
wiggy
Re: wiggys photos
Wed May 01, 2019 11:56 pm
mm thats what i thought
wiggy
Re: wiggys photos
Wed May 01, 2019 11:57 pm
i'll try smart sharpen on photoshop then
wiggy
Re: wiggys photos
Tue May 14, 2019 9:08 am
what number do you think I should sharpen my photos to ? fill free to reply to the comment
airkas1
Re: wiggys photos
Tue May 14, 2019 4:30 pm
I use amount 30%, radius 0,3px and noise 0%.
wiggy
Re: wiggys photos
Tue May 14, 2019 9:35 pm
[quote="airkas1"]I use amount 30%, radius 0,3px and noise 0%.[/quote
thinks i'll give it go
wiggy
Re: wiggys photos
Wed May 22, 2019 3:16 am
why does a photo have bad quality when screening but clear when you click on it ?
wiggy
Re: wiggys photos
Wed May 22, 2019 3:17 am
is it how it looks if it was accepted or what
airkas1
Re: wiggys photos
Wed May 22, 2019 10:14 am
During screening, we see the photo how they were uploaded.
wiggy
Re: wiggys photos
Wed May 22, 2019 11:12 am
okay
wiggy
Re: wiggys photos
Wed May 29, 2019 4:07 am
hi guys im after some feedback on these photos and do you think they could be improved more or sty as they are ?
wiggy
Re: wiggys photos
Wed May 29, 2019 4:10 am
i would appreciate your feedback
airkas1
Re: wiggys photos
Wed May 29, 2019 9:49 am
F900: Sky is very overexposed and the photo is severly oversharpened. It's also insufficient quality for that size and blurry/out of focus.
CL60: needs CW rotation (to the right), a tighter crop on the right side, insufficient quality for the size.
Sorry to say I don't think either of them will make it, even with the necessary adjustments. But to end on a positive note, these photos are already an improvement over your earlier examples.
wiggy
Re: wiggys photos
Wed May 29, 2019 11:23 am
thanks kas would the CL60 be worth editing again or not ? and also for some reason a guy like you I always get scared what the comment is going to be.
wiggy
Re: wiggys photos
Mon Jun 03, 2019 2:06 am
DL747
Re: wiggys photos
Mon Jun 03, 2019 5:32 am
Tiger is probably not worth even attempting an edit due to poor lighting conditions, the second aircraft (not good with vintage military types, sorry) is quite noisy and lacks the quality for that size. The light is also posing some issues as it has blown out the wing/fuselage.
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
wiggy
Re: wiggys photos
Mon Jun 03, 2019 7:44 am
okay I will pull them from the que then
wiggy
Re: wiggys photos
Wed Jun 05, 2019 10:50 pm
have i been banned uploading
Crosswindphoto
Re: wiggys photos
Thu Jun 06, 2019 10:09 am
I hate to point out the obvious and sound like a jerk, but, if you go to the upload screen, and it won't let you upload, you have either been banned uploading, or you've reached your queue limit.
airkas1
Re: wiggys photos
Thu Jun 06, 2019 10:49 am
No.
wiggy
Re: wiggys photos
Fri Jun 07, 2019 2:54 am
airkas1 wrote:
No.
thanks because i had this photo rejected for on of the reasons banding and i thought it mean't that i was banned uploading
https://imgproc.airliners.net/photos/ai ... 9cc87c745c
wiggy
Re: wiggys photos
Tue Jun 11, 2019 3:17 am
JakTrax
Re: wiggys photos
Wed Jun 12, 2019 5:58 pm
Serious oversharpening and compression. Light is poor also. Not a chance in its current form.
airkas1
Re: wiggys photos
Wed Jun 12, 2019 7:16 pm
Distance, compression, oversharpened, noisy, quality.
Crosswindphoto
Re: wiggys photos
Wed Jun 12, 2019 7:34 pm
All of the above are true, but with fixing I think this one might be ok!
wiggy
Re: wiggys photos
Thu Jun 13, 2019 12:35 am
I tried to fix it
wiggy
Re: wiggys photos
Fri Jul 26, 2019 12:36 am
i just had this photo rejected in priority for a registration for the data base , any thoughts on how i can fix it
https://imgproc.airliners.net/photos/ai ... 37d511d9bd
looking to your feedback
Crosswindphoto
Re: wiggys photos
Fri Jul 26, 2019 4:44 am
What was it rejected for?
From what I can see it’s underexposed and the crop is a little on the loose side.
Crosswindphoto
Re: wiggys photos
Fri Jul 26, 2019 5:51 am
On a second look I'm also noticing that it is over sharpened. It is hard to say whether or not it will be fixable.
Tim
wiggy
Re: wiggys photos
Fri Jul 26, 2019 11:18 am
COME ON !!!!!!!!!! I can not seem to get the sharpness right for some reason
reasons
personal message
soft
size
quality
underexposed
thanks for the feedback Tim!!!!
Crosswindphoto
Re: wiggys photos
Fri Jul 26, 2019 11:33 am
What did the personal message say?
jelpee
Head Screener
Re: wiggys photos
Fri Jul 26, 2019 12:35 pm
Definitely underexposed, right in frame and needs a tighter crop. Sharpening seems passable. OVerall quality seems marginal at best. Perhaps and increase in brightness and contrast along with a smaller size will help.
Jehan
wiggy
Re: wiggys photos
Fri Jul 26, 2019 11:09 pm
please try a lower resolution
wiggy
Re: wiggys photos
Fri Jul 26, 2019 11:10 pm
Jehan
thanks i'll give it a go
wiggy
Re: wiggys photos
Fri Jul 26, 2019 11:12 pm
Jehan
should I try again ?
jelpee
Head Screener
Re: wiggys photos
Sat Jul 27, 2019 12:20 am
Lets see what you get with another try.
wiggy
Re: wiggys photos
Sat Jul 27, 2019 1:26 am
Still rejected i did what you said
jelpee
Head Screener
Re: wiggys photos
Sat Jul 27, 2019 3:01 pm
Some details, please along with the reworked image.
Jehan
Crosswindphoto
Re: wiggys photos
Sat Jul 27, 2019 3:42 pm
Showing us the RAW file(s) might help.
wiggy
Re: wiggys photos
Sun Jul 28, 2019 4:59 am
sorry but the thumbnail won't work on the computer i'm using
wiggy
Re: wiggys photos
Mon Jul 29, 2019 1:02 am
spompert
Re: wiggys photos
Mon Jul 29, 2019 6:51 am
I can see that the left side of the photo looks blurry. Also the outside is overexposed.
wiggy
Re: wiggys photos
Mon Jul 29, 2019 8:00 am
thanks for your feedback, I noticed that in the email from the screener
wiggy
Re: wiggys photos
Mon Jul 29, 2019 11:22 am
I was so close to having accepted but it got rejected only for oversharpened.
airkas1
Re: wiggys photos
Mon Jul 29, 2019 2:05 pm
Protip #1: not all photos are suited for 1920px size. Don't use that size when just beginning. Keep it in the 1200-1400/1600px wide range.
VH-ZAL is overexposed and blurry, likely due to insufficient Depth of Field. There is no EXIF available for that photo, so I can't see what aperture you shot it at, but anything less than F8 is likely going to get you DOF problems. The crop is also a bit too wide and the horizon doesn't look level.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
