Page 4 of 5
Re: wiggys photos
Posted: Mon Jul 29, 2019 2:09 pm
by airkas1
As for sharpening, are you sharpening in layers and using the eraser?
What values do you use for sharpening?
Can you walk us through your sharpening process?
Re: wiggys photos
Posted: Mon Jul 29, 2019 10:02 pm
by wiggy
thanks kas its a long story about sharpening I started using photoshop elements 2019 as a 30 day trial then it expired so when the photos open up when I click on it it doesn't have many tools to edit photos so I have been editing it on there as I don't have photoshop any more.
Re: wiggys photos
Posted: Tue Jul 30, 2019 4:58 am
by wiggy
Re: wiggys photos
Posted: Tue Jul 30, 2019 5:17 am
by Crosswindphoto
Very Over-sharpened espcially around the engines.
As Kas said, not ll images can be uploaded at 1920/larger than 1600, and this is one of the ones that needs to dip down to about 1400px.
HOWEVER, with the above fixes this one may be acceptable.
Maybe a touch more contrast would help too :)
Tim
Re: wiggys photos
Posted: Tue Jul 30, 2019 9:05 am
by wiggy
thanks tim
Re: wiggys photos
Posted: Wed Jul 31, 2019 11:18 am
by airkas1
Not too bad, the engines look a bit soft/slightly out of focus perhaps, but could be masked by using a smaller size. On the latter subject, stop using these large sizes. We've told you plenty times before now. Make this one 1200px (1400px wide maximum).
Re: wiggys photos
Posted: Wed Jul 31, 2019 10:55 pm
by wiggy
i tried too but it will just be the nose in the photo otherwise
Re: wiggys photos
Posted: Thu Aug 01, 2019 5:00 am
by Crosswindphoto
Can you elaborate on “nose in”?
Perhaps send an example?
Re: wiggys photos
Posted: Thu Aug 01, 2019 9:35 am
by airkas1
I'm talking about resizing, not cropping. You can just resize the entire photo and everything will stay the same, escept the size will be smaller. If your photo software the limiting factor, then get your hands on some decent editing software. It doesn't have to be expensive (if you get my drift).
Re: wiggys photos
Posted: Thu Aug 01, 2019 9:40 am
by Crosswindphoto
What editing software do you use currently Wiggy?
Any version of Lightroom (except mobile) will do. Photoshop is nice but not necessary.
Re: wiggys photos
Posted: Thu Aug 01, 2019 9:58 am
by airkas1
I would really recommend photo editing software where you have more options and/or control over the editing. And shoot RAW if your camera has it.
Re: wiggys photos
Posted: Thu Aug 01, 2019 11:05 pm
by wiggy
it was photoshop elements 2019
but it doesn't work as it was only a 30 day trial and it has never worked ever since
Re: wiggys photos
Posted: Fri Aug 02, 2019 5:37 am
by Crosswindphoto
Do you have some way of getting Lightroom, through school, work?
If not, you should probably invest in LR which I believe comes with PS but I’m not sure.
Either way you must get some kind of editing software.
Tim
Re: wiggys photos
Posted: Fri Aug 02, 2019 9:34 am
by wiggy
Tim
thanks Tim I have trying to get dad to get it to work
Hadleigh
Re: wiggys photos
Posted: Fri Aug 02, 2019 9:38 am
by wiggy
thanks i'll give it a go
Re: wiggys photos
Posted: Sun Aug 04, 2019 10:59 pm
by wiggy
my mum thinks that you are trying to help me get photos accepted.
Re: wiggys photos
Posted: Mon Aug 05, 2019 5:01 am
by Crosswindphoto
We are(?)
Is that a bad thing?
Re: wiggys photos
Posted: Mon Aug 05, 2019 6:37 am
by wiggy
We are(?)
no I just wasn't sure that's all
Re: wiggys photos
Posted: Mon Aug 05, 2019 7:37 am
by Crosswindphoto
Re: wiggys photos
Posted: Mon Aug 05, 2019 7:41 am
by wiggy
sorry Tim my computer doesn't have open internet
Re: wiggys photos
Posted: Mon Aug 05, 2019 9:16 am
by Crosswindphoto
Re: wiggys photos
Posted: Mon Aug 05, 2019 9:45 am
by airkas1
Hadleigh, this entire subform is here to help people get their photos accepted. We all try to give advice in an attempt to imrpove the skills of the photographer.
Re: wiggys photos
Posted: Mon Aug 05, 2019 10:22 am
by wiggy
thanks kas!!!!!!!!! i'll bare that in mind
Re: wiggys photos
Posted: Fri Aug 09, 2019 12:18 pm
by wiggy
hi everyone I have just discovered that my RAW setting on my camera as kas mentioned earlier, when I saw it noticed the size of the with is 6000 px .
looking to reading your comment
Re: wiggys photos
Posted: Fri Aug 09, 2019 1:58 pm
by Crosswindphoto
That’s pretty normal if I understand what you’re saying correctly.
Re: wiggys photos
Posted: Fri Aug 09, 2019 3:35 pm
by airkas1
Yeah, that's about what I get out of my RAW files as well. Taking photos in RAW would always be my recommendation, especially if one knows how to use it to his/her advantage. You can do a lot of tweaking without ruining the file. It's pretty forgiving. There are likely tutorials on Youtube, but be careful not to overedit your images. A lot is trial and error. But you would still have to resize from 6000+ to around 1200-1600px wide.
Re: wiggys photos
Posted: Fri Aug 09, 2019 7:38 pm
by jelpee
RAW has a lot of capability, but the only time I use RAW is for night time high ISO photography. For all other situations (including the majority of my images for a.net) I use JPEG. JPEG is much easier to process and for my usage works well.
Jehan
Re: wiggys photos
Posted: Sat Aug 10, 2019 12:54 am
by wiggy
thanks everyone for your comments
Re: wiggys photos
Posted: Fri Aug 16, 2019 10:42 am
by wiggy
wait are talking about the photo ratio ?
Re: wiggys photos
Posted: Fri Aug 16, 2019 11:05 am
by airkas1
No, about size. But both are important, as an incorrect ratio will also result in a rejection, although we accept a variety of sizes/ratios.
Size is regarding the actual size (in pixels) of the photo. For example, 1200px wide, 1600px wide, etc.
Ratio has to do with the format (width vs height). For example, 3:2, 16:9, etc.
Re: wiggys photos
Posted: Fri Aug 16, 2019 12:06 pm
by wiggy
got it kas !!!
Re: wiggys photos
Posted: Fri Aug 16, 2019 12:56 pm
by Crosswindphoto
When you export, you should be able to enter the size you want. I would recommend a MAX of 1280 for your photos though.
Re: wiggys photos
Posted: Fri Aug 16, 2019 10:39 pm
by wiggy
thanks tim!!!
Re: wiggys photos
Posted: Wed Aug 21, 2019 10:58 pm
by wiggy
hi all i had this photo rejected for the following reasons
https://imgproc.airliners.net/photos/ai ... 74627e882f
blurry
compression
quality
oversharpened
noise
personnel massage was poor sky quality
cw rotation
I would appreciate your feedback on this photo
Re: wiggys photos
Posted: Thu Aug 22, 2019 6:10 am
by Crosswindphoto
All rejection reasons are correct to me.
However, we have all told you before Wiggy, your images can't support high sizes like this. 1280px max.
Also, make sure the quality slider is at 100, and you have sharpen for screen ticked, and set to high, if you're using LR.
If you're using PS, then I don't know how the export works and you will have to wait for someone else to answer that.
Tim
Re: wiggys photos
Posted: Thu Aug 22, 2019 7:06 am
by wiggy
thank tim I was once told be close to aircraft to get good photos but it mustn't help
Re: wiggys photos
Posted: Thu Aug 22, 2019 8:04 am
by Crosswindphoto
it helps, you just exported wrong, or shot at the wrong settings, or both.
Re: wiggys photos
Posted: Thu Aug 22, 2019 10:03 am
by wiggy
I shoot at 1920px then I crop it down to 1820px or less will that help or not?
Re: wiggys photos
Posted: Thu Aug 22, 2019 10:23 am
by airkas1
The photo might be salvagable and I would like to give it a try at editing. If you are OK with that, send me the original image (preferable RAW, otherwise JPG) at **username**[at]airliners.net and I'll have a look.
Re: wiggys photos
Posted: Fri Aug 23, 2019 7:13 am
by wiggy
ok kas I have sent it to you
Re: wiggys photos
Posted: Fri Aug 23, 2019 7:51 am
by airkas1
Got it, thanks! It might be after the weekend that I have time to try an edit, I will get back to you.
Re: wiggys photos
Posted: Fri Aug 23, 2019 9:55 am
by wiggy
wow that was quick, thanks a lot .
Re: wiggys photos
Posted: Thu Sep 05, 2019 2:55 am
by wiggy
thanks for your email kas I got it
Re: wiggys photos
Posted: Mon Sep 16, 2019 1:41 am
by wiggy
Re: wiggys photos
Posted: Mon Sep 16, 2019 5:00 am
by Crosswindphoto
#1: Horizon (CW rotation, make the back treeline level,), also borderline cut off (I would crop wider), and maybe a little soft towards the tail, also OE.
#2: Possibly left in frame due to the wing, but may be ok, also a touch HIF.
#3: HIF, soft (particularly near the prop/front), but maybe passable lower in the frame.
#4: Horizon, Tail is soft, might be better at a smaller size.
#5: Backlit, no chance.
Tim
Re: wiggys photos
Posted: Mon Sep 16, 2019 5:54 am
by wiggy
Thanks tim
Re: wiggys photos
Posted: Tue Sep 24, 2019 10:20 am
by wiggy
TIM!!!!!!!!! if you cant say something positive keep out of it
Re: wiggys photos
Posted: Tue Sep 24, 2019 10:29 am
by Crosswindphoto
You posted something very open with no other context, my answer wasn’t in any way mean or not positive.
Re: wiggys photos
Posted: Tue Sep 24, 2019 10:59 am
by wiggy
oh I get ya and I have deleted it
Re: wiggys photos
Posted: Wed Sep 25, 2019 4:01 pm
by JakTrax
You don't exactly have the attitude that makes people want to go out of their way to help you. And you don't seem to be particularly good at listening as, several months down the line, it doesn't seem you're any closer to getting images accepted.
What you're basically saying above is that you aren't interested in hearing anything but praise. Okay. Fine. Your images are superb and will breeze into the database. Better?
