musicman4327
Pre-screening for musicman4327
Mon Apr 15, 2019 6:42 pm
Howdy,
I'm worried that these might be a little soft which is why I exported them at 1024px wide. Also, not sure about the color balance. Feedback would be much appreciated. I'm going to pic the best of these two if either is ok.
https://inner-marker.com/pictures/C17-1.jpg
https://inner-marker.com/pictures/C17-2.jpg
Thanks.
jelpee
Re: Pre-screening for musicman4327
Mon Apr 15, 2019 8:49 pm
Soft and 'Id even say blurry on both. Quality is not sufficient to pass screening for a.net.What kind of equipment are you using? Stay with this group...we can help :)
Jehan
musicman4327
Tue Apr 16, 2019 2:14 pm
EOS5D MK IV (new, getting used to it still), and a Tamron 100-400.
These shots were from a good ways away at almost 400mm of zoom.
spompert
Tue Apr 16, 2019 2:23 pm
The shots look affected by atmospheric disturbance or heathaze. What ISO was used? There seems some noise on the fuselage too.
airkas1
Tue Apr 16, 2019 3:32 pm
The nose looks blurry in both photos and the aircraft is quite backlit/toplit. The camera is certainly fine, I'm unfamiliar with the lens and its quality. Better to take photo where the sun is more or less behind you.
musicman4327
Mon Oct 28, 2019 5:38 pm
jelpee
Mon Oct 28, 2019 10:19 pm
N674G: Passable
N824TE: Looks a little oversharpened as well. I also wonder if it could be cropepd better to avoid a lot of empty space?
N49265:Passable
N62379: May be better in 16:9 crop to avoid empty space on top and bottom of frame. IF the main subject is the covered aircraft, unless it is a first submission, it will draw a motive rejection for the cover.If N62379 is the main subject, it may also draw a motive rejection since it is obstructed by the aircraft in front. Not a fan of this composition.
Jehan
airkas1
Tue Oct 29, 2019 3:41 pm
#2 looks distant and high in frame
#3 looks compressed somehow. Also low in frame
#4 Cheatlines of the Cessna are jaggy. Main subject should be the Mooney and is subject to whether or not we already have it in the DB without cover.
Agree with Jehan for the rest.
musicman4327
Wed Oct 30, 2019 12:49 am
Thanks much for the feedback.
Re-edits of the beach and R44:
https://flic.kr/p/2hCukTV
https://flic.kr/p/2hCvjxH
I am a little unsure of how to place the R44 laterally in the frame with this crop; is this OK?
Thank you in advance,
-mm
musicman4327
Thu Nov 07, 2019 5:45 pm
Hello all,
I'd love to hear any feedback from yall. Thank you.
1. https://flic.kr/p/2hGzYAt
2. https://flic.kr/p/2hGB56a
3. https://flic.kr/p/2hGB55i
4. https://flic.kr/p/2hGxni5
jelpee
Thu Nov 07, 2019 11:46 pm
All passable for me.
Jehan
musicman4327
Sun Jul 05, 2020 1:20 am
Thank you in advance for any feedback.
https://flic.kr/p/2ji9ZJY
musicman4327
Fri Sep 04, 2020 9:22 pm
HarryLi
Screener
Tue Sep 08, 2020 1:13 pm
Hi Stuart !
Sorry for the late reply for your thread. Here're my opinions for them :
N624XA : CW rotation needed (Using consturctions outside airport) ; Too low in frame (Too much space on the upper frame) ; Could be slightly brighter.
N542NM: Vignettings from left and right side ; Slightly low in frame for me.
N726DR: CW rotation needed ; Too low in frame as well.
N151MH: I can see slight halos (black) surround the upper edge of the aircraft and the cover of the cockpit although it's not obvious ; Slight vignetting at the upper left corner. Otherwise ok.
N53... : Looks ok for me.
Rgrds,
Harry
JakTrax
Tue Sep 08, 2020 3:33 pm
Stuart,
Looking at some of those images I see you've either very wide apertures or higher ISO sensitivities coupled with unnecessarily fast shutter speeds. The vignetting issue in your second image will be a direct result of shooting your lens close to wide open — you'd have been much better shooting at f/8+ with ISO100 to reducing the shutter speed by a good few stops.
Karl
musicman4327
Thu Sep 10, 2020 4:03 pm
HarryLi and JakTrax,
Thank you much. I appreciate the feedback and shooting tips. These are older photos so I was in no rush.
musicman4327
Fri Sep 11, 2020 8:42 pm
Good afternoon,
I'd love for some feedback on these two photos:
N108HQ https://flic.kr/p/2jFD3qx
N281NN https://flic.kr/p/2jFD3qY
Thank you.
Users browsing this forum: No registered users and 22 guests
