DanielK
Pre-Screening - DanielK
Sun May 05, 2019 11:05 pm
Hi all,
What do you guys think of these three images.
https://imgproc.airliners.net/photos/airliners/3/7/4/5517473.jpg?v=v4e6347e1a69
https://imgproc.airliners.net/photos/ai ... c77d4d9946
https://imgproc.airliners.net/photos/ai ... e522bdf744
Thank you all for your input,
Daniel
wiggy
Re: Pre-Screening - DanielK
Mon Jun 03, 2019 3:23 am
sorry mate the first one won't work the other two how ever look blurry and soft to me
DL747
Mon Jun 03, 2019 5:30 am
QF 738 might be a little flat/soft, and the EK maybe a little soft at the back but they look pretty good to me. Best to wait for screener input though.
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
DanielK
Thu Jul 11, 2019 2:58 am
Hi all. Was wondering on your thoughts about this image. It was taken in tough lighting, but I feel I may have been able to save it.
https://imgproc.airliners.net/photos/ai ... fefe5afff2
Daniel
spompert
Thu Jul 11, 2019 8:09 am
Hi, looks a bit oversharpened around the cheatlines (jaggies). I was thinking of overexposed but it might be okay.
JakTrax
Thu Jul 11, 2019 10:57 am
The Crystal 77L looks heavily processed to me and there are blown out areas. I'd say no to it making it into the database but I've said that before about images that were subsequently accepted.
The earlier three all look soft to me (the 737 blurry in fact), although it's so hard for me to tell from such small images. The EK 388 rear softness can be attributed to jetwash from the outboard port engine, however.
airkas1
Thu Jul 11, 2019 11:41 am
I agree on overedited (too little shadows). low contrast, borderline overexposed.
DanielK
Mon Jul 15, 2019 6:59 am
Thank you everyone for your help in regards to that Crystal image, I since have taken it off the queue.
DanielK
Mon Jul 15, 2019 7:01 am
Hi all,
Was wondering on your opinion with these various shots that I took today.
https://imgur.com/IKffrTY
https://imgur.com/KjXsaTK
https://imgur.com/d1tixRH
https://imgur.com/EuPQqPj
Kind regards,
Daniel
airkas1
Mon Jul 15, 2019 12:04 pm
Hi Daniel,
1. On the sharp side, a little overexposed top half of the fuselage. Nice shot though, perhaps better with reduced highlights.
2. Oversharpened, blurry nose
3. Very noisy and very oversharpend, top half fuselage overexposed.
4. Very oversharpened and a bit overexposed.
Harsh light on all 4.
DanielK
Wed Jul 17, 2019 6:47 am
airkas1 wrote:
Hi Daniel,
Thanks for the feedback, I have fixed the images as above.
DanielK
Wed Jul 17, 2019 7:17 am
Could I have someone check these images please:
https://imgur.com/w3CnAmS
https://imgur.com/MsoOIiU
https://imgur.com/kL3EczU
https://imgur.com/PHTz1Su
https://imgur.com/5RmNbTp
https://imgur.com/aZgvFfP
https://imgur.com/nuFr7Ay
I'm sorry If I've sent too many in at once, and am grateful for the time taken to check each one out.
Kind regards,
Daniel
DanielK
Sun Jul 21, 2019 8:13 am
Hi, I'm just wondering which crop would be accepted as this is a new rego to the database:
1. https://imgur.com/WrMPX97
2. https://imgur.com/rjbO43k
3. https://imgur.com/A44lLVW
Daniel
airkas1
Sun Jul 21, 2019 8:23 am
Crop #1. #2 is right in frame and #3 is definitely not passable.
DanielK
Sun Jul 21, 2019 8:33 am
Thank you, I’ll submit that. I made it harder because I messed up when taking the photo framing wise.
DanielK
Sun Jul 21, 2019 12:25 pm
Hi, this image was rejected. Do you think it’s fixable?
Thanks Daniel
airkas1
Sun Jul 21, 2019 1:29 pm
A version of the photo has just been added. Looked nice. Please remember the c/n next time ;)
DanielK
Mon Jul 22, 2019 12:26 am
Thank you, definitely won't next time.
DanielK
Mon Jul 22, 2019 12:28 am
Could I ask for thoughts on this edit. My main concern is that equipment are moving towards the A/C and they may destroy the image.
https://imgur.com/9toOQ2E
Daniel
airkas1
Mon Jul 22, 2019 9:02 am
Photos with active loading are passable. If you have a photo with the front highloader at the fuselage, that's fine. But as is, it's blocking the engine (and that's avoidable by simply waiting a few seconds longer before taking the photo). Also not sure of the blue strobe on the right wing. Was it still on?
DanielK
Tue Jul 23, 2019 2:14 am
Thank you, so as long as they aren’t blocking engines, etc then its fine
airkas1
Tue Jul 23, 2019 9:03 am
If the highloader was at the fuselage, it would be fine.
DanielK
Tue Jul 23, 2019 10:03 am
Thank you, I'll remember that for next time.
Could I ask for the opinion of this edit, and whether it can get accepted on ANet?
https://imgur.com/0O84V2Y
Daniel
airkas1
Tue Jul 23, 2019 10:11 am
Too cyan and overexposed as-is. The sky and aircraft kinda blend, not enough contrast between the 2. Actual contrast seems OK (blacks are dark enough), so try tweaking the exposure of the sky.
DanielK
Tue Jul 23, 2019 11:06 am
I've re-edited it, how is it now?
https://imgur.com/0C30464
Daniel
airkas1
Tue Jul 23, 2019 11:30 am
The color is better and fine now, but the contrast is still the same. Add +20 contrast and try to tweak the highlights a bit. Not sure if it's fixable in the end though. If you shoot RAW, I can give it a try if you want.
DanielK
Tue Jul 23, 2019 12:02 pm
Thank you, I'll give it one more try. I'm not really the best when it comes to editing overcast conditions.
https://imgur.com/6VF3cCb
Thanks again,
Daniel
DanielK
Wed Jul 24, 2019 9:50 am
Hi, I'm wondering if this image is able to be fixed?
Kind regards,
Daniel
spompert
Wed Jul 24, 2019 10:15 am
Hi Daniel, you have to link the photo another way because it`s not visible for us like this.
310815
Fri Jul 26, 2019 9:20 pm
The shot is in the db, what are we supposed to say?
https://www.airliners.net/photo/Air-Mau ... /5611983/L.
Or was it meant to be this one
https://imgproc.airliners.net/photos/ai ... c9fb28c111
As it is a clear double to the shot I linked first I also don't see the point.
DanielK
Sat Jul 27, 2019 12:20 am
Hi, yes sorry about that. I had linked my rejected shot. Bu with no responses, I had another go myself.
DanielK
Sat Aug 03, 2019 2:24 am
Hi, Could I please ask whether this is too toplit? My first impression is that it is, but could I please have a second-opinion.
https://imgur.com/AheFLsz
Kind regards,
Daniel Kotronis
airkas1
Sat Aug 03, 2019 9:16 am
Yes.
DanielK
Sun Aug 04, 2019 4:33 am
Hi,
Could I please ask whether these shots are exposed correctly.
https://imgur.com/UkzLeJW
https://imgur.com/3ws1VDN
https://imgur.com/JFpckey
Kids regards,
Daniel
JakTrax
Mon Aug 05, 2019 2:51 pm
Exposures look okay but all are a bit blue.
Karl
DanielK
Tue Sep 17, 2019 11:57 pm
Hi, Could I please get a a quick yes or no in regards to this shot. I'm going to assume its a no, but I still would like know from Anet crew.
https://imgur.com/K7sTrmS
Daniel
jelpee
Head Screener
Wed Sep 18, 2019 12:01 am
Would like to see a larger image than what the link shows. Silhouettes are routinely accepted. Just cant judge this one based on the small image size.
Jehan
DanielK
Wed Sep 18, 2019 12:16 am
Jehan
I'd love to send a larger image size, unfortunately that's as large as it gets. I myself is getting the impression it would be a waste of time to upload.
Daniel
airkas1
Wed Sep 18, 2019 10:52 am
Size-wise a no by default, but this looks horribly jaggy. Surely you can see that as well?
Crosswindphoto
Wed Sep 18, 2019 10:59 am
I looked, its 667x375, not even upload size.
DanielK
Wed Sep 18, 2019 1:36 pm
Yes I could. Was just seeking clarification
DanielK
Wed Sep 18, 2019 1:37 pm
In regards to this image of a rego which is yet to be added to the database. Is it possible to get this image to ANet standard. Obviously the tough lighting, as well as sunset timing didn’t quite help.
https://u11091607.ct.sendgrid.net/wf/cl ... EF2wtGg-3D
Thanks, Daniel
DanielK
Wed Sep 18, 2019 1:38 pm
Thanks, Daniel
I got it to this stage and then corrected it as the screener’s rejection reasons stated. But then it was rejected for a variety of other reasons
airkas1
Thu Sep 19, 2019 10:09 am
Looks like tough light indeed and I'm not sure it's fixable.
DanielK
Sun Sep 22, 2019 12:52 pm
Hi, Could I pleas get your opinion on this shot. Thanks Daniel
https://imgur.com/7hjoDNQ
airkas1
Sun Sep 22, 2019 6:42 pm
Hi Daniel,
It looks quite compressed, noisy and blurry. The crop on the left is too tight.
DanielK
Sun Sep 22, 2019 11:30 pm
airkas1 wrote:
Hi Daniel,
Thanks, I’ll keep working on it. The shot was a night pan as it taxied onto the bay, shot at ISO 1000. Are these types of shots possible to get on the database?
DanielK
Mon Sep 23, 2019 12:22 am
If it helps. Here is the original image, which looks to be compressed and a bit darker than the original
https://m.imgur.com/zBxMA6S
DanielK
Sat Sep 28, 2019 12:04 am
Hi, Could I please ask how I could improve these two images. With the second image, I don't understand how a sharp image when taken can go blurry.
https://imgproc.airliners.net/photos/ai ... 3e066e3851
3 SO's and rejected for motive and right in frame.
https://imgproc.airliners.net/photos/ai ... 6021d9ddde
Rejected for blurry, colour, compression and oversharpened
310815
Sat Sep 28, 2019 11:06 am
Hi,
I don't think the first image can be improved, as the cut wingtip will always be a motive rejection. I also agree with right-in-frame, the composition looks unbalanced as it is. I think the shot can only work with a close-up / closer crop to the fuselage.
As for the SAA:
Honestly at 1.024px it is hard to tell if a shot is just soft or blurry. For me ist just looks soft, quality doesn't seem to bad.
I agree that the colour is off as the fuselage is not really white. But I don't see evidence for compression or oversharpening (again at 1.024 a photo will looked jagged no matter how).
Generally I would at least upload in 1.200px, I think these ultra-tiny sizes don't help.
If you want you can send me the original of the SAA and I can have a look: jkphotos [at] airliners.net. As I said before at 1000px hard to tell how the quality really is.
Julien
Users browsing this forum: No registered users and 9 guests
