ABissonnette
Pre-screening please
Tue May 07, 2019 4:16 am
Hello, please pre-screen these photos, thank you! :-)
Edit: I can't seem to be able to post the pictures on the forum, so here's the link to them on my Flickr account. Sorry for any inconvenience.
1. https://www.flickr.com/photos/162440596 ... ed-public/
2. https://www.flickr.com/photos/162440596 ... ed-public/
3. https://www.flickr.com/photos/162440596 ... ed-public/
4. https://www.flickr.com/photos/162440596 ... ed-public/
5. https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
Andrew
Canon T4i - 100-400mm
jelpee
Head Screener
Re: Pre-screening please
Tue May 07, 2019 12:03 pm
Hello Andrew,
All of the images appear blurry and unlikely to be accepted.
Jehan
ABissonnette
Tue May 07, 2019 1:33 pm
jelpee wrote:
Hello Andrew,
Jehan
OK, thanks for taking a look at my photos!
Is this one blurry as well?
Andrew
Andrew
jelpee
Head Screener
Tue May 07, 2019 5:00 pm
The last one does not appear blurry to me. However it is underexposed due to the unsuitable angle of light (overhead). Also, it will draw a "Motive" rejection due to the obstruction by the stairs.
Jehan
ABissonnette
Wed May 08, 2019 6:49 pm
Hello, I shoot photos with Aperture priority, (normally set at f8), and I did f6.3 on the photos that I had you pre-screen.
Is there a way to avoid the blurry photos? The shutter speed is automatically set, depending on the lighting conditions, but can I manually pick aperture speed, and shutter speed while on the Av Priority mode?
A experienced spotter at CVG airport, helped me configure my Canon T4i identically to his 5DMII, but I don't understand what caused my photos to become blurry, as I've never had that issue before with the new settings.
Thank you,
Andrew
Andrew
jelpee
Head Screener
Wed May 08, 2019 9:50 pm
I would use the fastest shutter speed possible to avoid any kind of camera shake, which is one cause of blur. Another cause of blur could be the sharpness characteristics of the lens itself. The 3rd issue would be a focusing issue. If you have an alternate lens, you might see if the image quality is better. I would also recommend photographing in good light (sunny day with light behind you). For e.g. at the Viewing Area at CVG in the morning for Rwy 18L. You might also test your gear out on some stationary subjects using a tripod. If images are still blurry, your gear might need attention.
Jehan
ABissonnette
Thu May 09, 2019 8:46 pm
Hello, please pre-screen this one, thank you!! :-)
Edit: Please give it about 10 seconds for the photo to refine on Flickr, thank you!
Andrew
Andrew
jelpee
Head Screener
Thu May 09, 2019 9:29 pm
Passable for me.
Jehan
airkas1
Thu May 09, 2019 9:43 pm
Same for me.
ABissonnette
Fri May 10, 2019 2:47 am
OK, thanks so much!! :-)
Can you please pre-screen this photo? Thank you!
Andrew
Andrew
jelpee
Head Screener
Fri May 10, 2019 9:11 pm
Lighting is harsh,,,best to avoid noon lightning from overhead. While the lighting is not the most flattering, I can't see anything else that would keep it from getting accepted.
Jehan
airkas1
Mon May 13, 2019 6:32 pm
Hi Andrew,
#1: yellow, soft fuselage. Marginal quality.
#2: underexposed, needs a tighter crop. Poor light angle.
#3: blurry, low contrast, poor light.
#4: underexposed (way too backlit, unfixable by default).
#5: underexposed, low contrast, marginal light.
ABissonnette
Mon May 13, 2019 7:48 pm
Hello,
Thanks for taking a look at my photos?
I tried fixing #1 and #5, do they look acceptable now?
Andrew
Andrew
Crosswindphoto
Fri May 17, 2019 4:20 pm
1: Dark/underexposed, slightly blurry towards the nose, a tad over-sharpened, jpeg compression.
2: Centering, CCW rotation, maybe a tad more contrast and an extra kick of exposure would help, jpeg compression
3: Jpeg compression, Noise, underexposed.
4: underexposed, jpeg compression, and needs a tighter crop IMO.
5: Green/yellow colour cast, borderline backlit, Jpeg compression, underexposed, a tad high in frame.
ABissonnette
Tue May 28, 2019 3:28 am
Please pre-screen this photo, thank you!! :-)
Andrew
Andrew
airkas1
Tue May 28, 2019 1:50 pm
Needs a bit more contrast, but seems passable otherwise. However if you have a more interesting motive (with more to be seen outside, for example lower to the ground, nicer cloud formations, etc.) that would be better.
ABissonnette
Tue May 28, 2019 6:14 pm
Hello, OK! No, this is the only good photo I got (Pretty much the whole flight we were in the clouds)
Also, I have three new photos that I'd like you to please take a look at.
BTW, #2 is a Airport Overview/Ramp overview
#1: https://www.flickr.com/photos/162440596 ... ed-public/
#2: https://www.flickr.com/photos/162440596 ... ed-public/
#3: https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
airkas1
Tue May 28, 2019 6:32 pm
#1: blurry, heathaze, chromatic abberation, quality.
#2: distant, low contrast, too far away.
#3: blurry nose/tail, soft, heat haze, quality.
Crosswindphoto
Tue May 28, 2019 6:33 pm
I’m on my iPhone so I can’t comment about sharpness:
#1 could use a tighter crop, it also looks a little yellow
#2 will be motive/distance, it’s to much dead space.
#3 a tad yellow and could use some more contrast.
Wait for a screeners comment on sharpness and for a better analysis on the photos.
ABissonnette
Tue May 28, 2019 6:52 pm
Is this any better?
Andrew
Andrew
airkas1
Tue May 28, 2019 6:56 pm
Not really, sorry.
jelpee
Head Screener
Tue May 28, 2019 11:37 pm
Andrew,
The overview of the DHL ramp also has a lot of empty space and the aircraft are too far away. The view from the Viewing Area at CVG is unfortunately too far away and also causes a lot of heat haze.
Jehan
ABissonnette
Wed May 29, 2019 2:41 am
airkas1 wrote:
Not really, sorry.
Hello, please take a look at this one. Thank you!! :-)
Andrew
Andrew
Runway28L
Wed May 29, 2019 5:17 am
Looks underexposed from being backlit. Also needs some CCW rotation.
airkas1
Wed May 29, 2019 9:52 am
I agree with Evan. Also too much empty space on the sides for such a crop. This one will not make it.
ABissonnette
Wed May 29, 2019 2:08 pm
OK, thank you!! :-)
I have two newly edited ones, that I'd like you to please take a look at.
And thanks so much for pre-screening these for me, I really appreciate it! :-)
Andrew
Andrew
Crosswindphoto
Wed May 29, 2019 4:05 pm
Both have a green color cast and are heavily jpeg compressed. Some more contrast may help for both of them as well.
jelpee
Head Screener
Wed May 29, 2019 5:21 pm
I agree about the green cast...perhaps from photographing through the terminal glass window. Looks quite soft as well.
Jehan
ABissonnette
Mon Jun 03, 2019 6:39 pm
Hello,
I have three new photos that I'd like to have pre-screened, please. Thank you!! :-)
Andrew
Andrew
jelpee
Head Screener
Mon Jun 03, 2019 10:46 pm
Andrew:
#1 is backlit and therefore will draw an "underexposed" rejection.
#2: The Ultimate Air Shuttle is over exposed and has a red color cast. Also soft in the nose area.
#3: The Cirrus is over exposed, soft, has a yellow color cast. There is also some purple fringing.
Jehan
ABissonnette
Mon Jun 03, 2019 11:15 pm
jelpee wrote:
Andrew:
Jehan
OK, thanks for taking a look! I tried fixing #2 and #3:
Additionally, do you know what would cause the discoloration? Is it something caused by my camera's settings, or in editing?
Andrew
Andrew
jelpee
Head Screener
Tue Jun 04, 2019 1:39 am
#2 Looks better
#3 Still looks soft and the quality is just not there. The lettering on the Cirrus should be blue not purple. It just may be the characteristics of the lens you're using. Typically the purple fringing is caused by chromatic aberration which is a characteristic of the quality of the glass material and the construction of the lens. Try a different lens...perhaps borrow one or rent one. At least you'd know if it was your lens that was at issue or something inherently wrong with the body of your camera.
Jehan
JakTrax
Tue Jun 04, 2019 3:31 pm
Hmmm. That doesn't look like CA around the reg. to me in that Cirrus shot — I'd expect to see CA on the higher contrast edges such as the black 'SR20' logo on the white tail. Incorrect white balance leading to a hue is the more likely culprit but it's hard to clarify at such a small size. There does appear to be a touch of CA on the fin's leading edge, however.
CA is more a characteristic of the light as all lenses in certain circumstances will produce it. I've known high-end Canon L lenses be particularly bad offenders, and crappy budget lenses control it surprisingly well. Wide-angles are generally more susceptible in my experience.
Karl
ABissonnette
Fri Jun 07, 2019 10:53 pm
jelpee wrote:
#2 Looks better
Jehan
OK, thank you!
I know that the lighting is a bit harsh on this one, but do you think that it has a chance?
Andrew
Andrew
JakTrax
Sat Jun 08, 2019 1:55 am
Looks blurry to me.
ABissonnette
Mon Jun 10, 2019 8:07 pm
JakTrax wrote:
Looks blurry to me.
OK, thanks for taking a look at my photo! :-)
Andrew
Andrew
jelpee
Head Screener
Mon Jun 10, 2019 11:39 pm
Yes, unfortunately blurry and over sharpened to compensate.
Jehan
ABissonnette
Wed Jun 12, 2019 6:43 pm
Jehan
OK, thank you! :-)
Andrew
Andrew
airkas1
Wed Jun 12, 2019 7:20 pm
Looks passable.
jelpee
Head Screener
Wed Jun 12, 2019 10:17 pm
Looks OK to me as well. Was that taken at Sporty's?
Jehan
ABissonnette
Wed Jun 12, 2019 10:26 pm
Jehan
OK, thank you!
Yes, it was taken at Sporty's, actually taken today..
That plane was the one that I flew in for my introductory flight lesson today.
Andrew
Andrew
ABissonnette
Thu Jun 13, 2019 2:17 am
ABissonnette wrote:
Jehan
OK, thank you!
Andrew
Additionally, can you please pre-screen this photo?
Thank you!! :-)
Andrew
Andrew
jelpee
Head Screener
Thu Jun 13, 2019 11:58 am
N825AE looks blurry.
Great that you have started flight school!
Jehan
airkas1
Thu Jun 13, 2019 12:04 pm
Agree on blurry (especially the front section).
ABissonnette
Thu Jun 13, 2019 6:01 pm
I know this isn't the best quality image, but please take a look at it, thank you!! :-)
Andrew
Andrew
fsx98
Thu Jun 13, 2019 6:10 pm
Looks like this photo could use a little CCW rotation; photo is also soft to me.
ABissonnette
Thu Jun 13, 2019 6:18 pm
OK, thanks for taking a look! Is this any better? https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
Andrew
fsx98
Thu Jun 13, 2019 6:28 pm
Looks better in terms of sharpness, though I'm concerned about the photo being overexposed; I would wait for pre-screening feedback from the screeners.
