ABissonnette
Re: Pre-screening please
Thu Jun 13, 2019 7:37 pm
fsx98 wrote:
Looks better in terms of sharpness, though I'm concerned about the photo being overexposed; I would wait for pre-screening feedback from the screeners.
OK, thank you!! :-)
Please also take a look at this one, too: https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
fsx98
Thu Jun 13, 2019 8:08 pm
The Cessna 310 photo is low on contrast, maybe overexposed; looks borderline soft/blurry, especially on the engine area; heat haze on top of the fueselage? Quality may be marginal; I would wait for screener's input but I highly doubt that this photo would make it.
airkas1
Head Screener
Thu Jun 13, 2019 9:53 pm
Low contrast, overexposed and soft.
ABissonnette
Fri Jun 14, 2019 2:08 am
OK, thanks! I have three new ones that I'd like you to please take a look at, thank you!! :-)
#1: https://www.flickr.com/photos/162440596 ... ed-public/
#2: https://www.flickr.com/photos/162440596 ... ed-public/
#3: https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
jelpee
Screener
Fri Jun 14, 2019 11:59 am
All 3 look blurry and significantly underexposed to me.
Jehan
ABissonnette
Fri Jun 14, 2019 10:10 pm
Jehan
OK, thanks! I just went to CVG this morning to go spotting, and here a few....
Please take a look at these photos, thank you!! :-)
#4: https://www.flickr.com/photos/162440596 ... ed-public/
#5: https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
ABissonnette
Sat Jun 15, 2019 4:01 am
ABissonnette wrote:
Jehan
Andrew
Sorry for so many pre-screening requests, but I'd like to add two more onto the other five that I'd like you to please take a look at. Thank you so much for taking the time to pre-screen my photos, I very much appreciate it!! :-)
#6: https://www.flickr.com/photos/162440596 ... ed-public/
#7: https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
jelpee
Screener
Sat Jun 15, 2019 2:37 pm
In you first set, they are all blurry towards the nose. There is also a purple shift in the color evidenced by the color if the UNITED title. Overall quality is marginal at best.
In the second set, the AA777 needs some additional contrast and should be fine. Same with the AA787.
Jehan
ABissonnette
Sat Jun 15, 2019 5:20 pm
Jehan
OK, thank you!! :-)
I have added more contrast to the AA777 and the AA787, do they acceptable now?
Andrew
Cvgspotter15
Mon Jun 17, 2019 12:27 am
Jehan
OK, thank you!! :-)
Andrew
Both have weird contrast levels, 2nd is overexposed especially towards the top of the plane. I think the main problem exists in contrast.
ABissonnette
Mon Jun 17, 2019 3:15 am
Cvgspotter15 wrote:
Jehan
OK, thank you!! :-)
Andrew
Hello! OK, thanks for the feedback! Do you think I need more or less contrast? Thank you!! :-)
Andrew
Runway28L
Mon Jun 17, 2019 4:30 am
Both images are underexposed, flat (low in contrast), and need CCW rotation. The AA B772 is also low in frame.
Greetings from KPIT! Check out my photos here: https://www.airliners.net/search?user=45 ... teAccepted
ABissonnette
Mon Jun 17, 2019 7:24 pm
OK thanks for the feedback!! :-)
I went to Lunken briefly today, but I unfortunately didn't have my 75-300mm lens with me, all I had was an 18-55mm, so I know that the quality of these aren't the best, but please take a look at these two photos, thank you!! :-)
Andrew
fsx98
Mon Jun 17, 2019 8:24 pm
#1 is a bit flat (low contrast); soft; motive due to clipped horizontal stabilizer (poor crop?) - highly doubt this will make it in this edit
#2 is also a bit flat (low contrast); underexposed; blurry/soft; needs CW rotation
ABissonnette
Mon Jun 17, 2019 8:29 pm
What about this one? https://www.flickr.com/photos/162440596 ... ed-public/
Andrew
JakTrax
Mon Jun 17, 2019 9:33 pm
Unwarranted motive in that last one I think. That said, there appear to have been some big rule shifts here lately so I really don't know.
jelpee
Screener
Tue Jun 18, 2019 11:59 am
Agree with the feedback from JakTrax and FSX98. Definitely motive rejections on both the images of the Flamingo Air. On the first one the horizontal stabilizer is clipped on the left side. Images are overall underexposed and flat. The Ultimate Air Dornier also looks soft.
Jehan
ABissonnette
Thu Jun 20, 2019 2:52 am
Jehan
Hello,
OK, thanks for the feedback! :-)
These two photos were rejected a while back, and I finally put them back through the editor again.. Please take a look:
Andrew
fsx98
Thu Jun 20, 2019 3:03 am
The Atlas Air looks blurry, borderline OE, maybe low contrast, and probably color (green is too light); not sure if that could be fixed further.
The Frontier looks soft and appearing backlit.
ABissonnette
Thu Jun 20, 2019 3:05 am
Hello,
OK, thanks for the feedback!! :-)
Andrew
ABissonnette
Thu Jun 20, 2019 3:09 am
Any chances on this one being accepted?
Andrew
ABissonnette
Thu Jun 20, 2019 3:56 am
Andrew
Also, please take a look at this one.
This is an older one that I found on my computer taken with my old camera, so the quality isn't the best, sorry, but please take a look, thank you!! :-)
https://imgproc.airliners.net/photos/ai ... 8c6bd67801
Andrew
fsx98
Thu Jun 20, 2019 7:10 am
The American Eagle ERJ looks backlit, heat hazed, and underexposed.
The Cessna looks blurry, noisy/grainy, dark, and low contrast; overall poor quality.
Neither of them would likely be accepted, I'm afraid.
JKPhotos
Screener In Training
Thu Jun 20, 2019 12:27 pm
Hi,
let me put this straight, the Embraer is underexposed, blurry and heat hazed. The Cessna is really blurry. I am afraid (and sorry for the harsh critique) but they have zero chance of being accepted.
I would really recommend of checking other shots in the db of the same registrations and you should see a difference.
As an advice (especially for the Embraer); I would try to shoot objects that are closer to you, the objective you are using (from then flickr EXIF) is not that sharpest and its long end.
Again sorry for the harsh words, but I am trying to make it clear that there is no point in putting any time into these shots above. They are for your personal collection, but not for airliners.net.
Julien
ABissonnette
Thu Jun 20, 2019 2:27 pm
JKPhotos wrote:
Hi,
Julien
Andrew
ABissonnette
Fri Jun 21, 2019 4:32 pm
Hello,
Please take a look at this photo:
Thank you!! :-)
Andrew
jelpee
Screener
Fri Jun 21, 2019 5:50 pm
Very blurry. As Julien recommended, take a look at other images on the site to get an idea of the standards.
Jehan
ABissonnette
Fri Jun 21, 2019 6:15 pm
Jehan
OK, thank you, I will do that! Also, I'm going to see if I have a clearer version of this image, as I took lots of photos today of that helicopter..
Andrew
ABissonnette
Sat Jun 22, 2019 12:30 am
OK - So I spent a few hours browsing through different kinds of photos from all over the world on here, and I think I'm getting a better idea of your standards..
Here's another one of the helicopter... The only thing that I see are blurry are the blades that are moving..
Thank you!! :-)
Andrew
spompert
Sat Jun 22, 2019 7:10 am
Hi Andrew, the problem with Flickr is that we are not shown the real photo. It is smaller then your original and looks different. I downloaded the original file and watched it that way. It looks really sharp to me. There are only some jaggies visible around texts, and cheatlines. So I would say you oversharpened the photo a bit. Regards Stefan
ABissonnette
Sat Jun 22, 2019 11:40 am
Oops, sorry.
I uploaded it to Airlines, how does it look now? https://imgproc.airliners.net/photos/ai ... 9312801dcf
Thank you!! :-)
Andrew
spompert
Sat Jun 22, 2019 12:36 pm
Didn`t change my opinion :)
jelpee
Screener
Sat Jun 22, 2019 2:41 pm
I agree...still looks quite blurry.
Jehan
ABissonnette
Sun Jun 23, 2019 2:51 am
OK - I don't have any queue space to upload my photos through Airlines right now, so we'll have to stick to Flickr..
I went to the Dayton Air Show today, and rented a 100-400mm L series lens.. Very nice lens. Anyway, here are some pics taken with it.
Thankfully the clouds eventually cleared, and the lighting got very good..
Andrew
jelpee
Screener
Sun Jun 23, 2019 12:44 pm
Hi Andrew,
Here's what I see:
1. The T'Bird: Blurry, underexposed and low contrast
2. Royal Navy Harrier: Underexposed and low contrast.
3 KC 135. Overexposed on the top and low contrast
4.C-117 Same as the KC 135
Glad the weather cleared for the show.. I was thinking of going up there myself but did not make plans due to forecast.
Jehan
ABissonnette
Sun Jun 23, 2019 5:05 pm
jelpee wrote:
Hi Andrew,
Here's what I see:
Jehan
Hello,
Thanks for taking a look!! :-) I edited these three again, do they look acceptable now?
Andrew
jelpee
Screener
Sun Jun 23, 2019 9:50 pm
Sorry to say that they all look quite underexposed now.. I would be happy to assist you with some editing. Send me a PM with the original file for the C117 and the KC135 and the Harrier.
Jehan
ABissonnette
Sun Jun 23, 2019 10:31 pm
Jehan
OK, thanks!! :-) I sent you a PM.
Andrew
Runway28L
Tue Jun 25, 2019 4:36 am
I'll chime in that the crop on the Altus KC-135 is really tight and should be widened.
airkas1
Head Screener
Thu Jun 27, 2019 3:47 pm
Hi Andrew,
For this photo:
- The airline was missing (= "Untitled")
- The category 'Single Engine Prop" needs to be ticked.
- The category 'Private' needs to be ticked (as owner).
- The 'builder' field is not applicable, that is only for license-built aircraft.
I've submitted the corrections already, so no action needed from your side for this photo. But please keep it in mind for future uploads. Saves us some time :thumbsup:
ABissonnette
Thu Jun 27, 2019 9:47 pm
airkas1 wrote:
Hi Andrew,
For this photo:
Hello, sorry... I just updated another Cessna photo in my queue, and I won't let this happen again.
Thanks for bringing this to my attention!! :-)
Andrew
ABissonnette
Fri Jun 28, 2019 10:52 pm
Hello,
Please pre-screen these three photos, please:
1. https://www.flickr.com/photos/162440596 ... ed-public/
2. https://www.flickr.com/photos/162440596 ... ed-public/
3. https://www.flickr.com/photos/162440596 ... ed-public/
I know that the lighting was not ideal, but I tried to make the best of it when taking the photos...
Andrew
jelpee
Screener
Fri Jun 28, 2019 11:33 pm
#1: Motive due to cropped landing gear. A bit over exposed.
#2: Motive: Cropped antenna on top of canopy. Not the best crop
#3 Motive due to crop (landing gear, tail. Also over exposed and soft.
Jehan
ABissonnette
Sat Jun 29, 2019 1:28 am
Jehan
Hello,
OK, thanks for taking a look!! :-)
Here's the last batch for today:
Andrew
JakTrax
Wed Jul 03, 2019 6:12 pm
From the first batch (posted 4 days ago)...
1. Severe heat-haze and blurry fence.
2. Soft/blurry, heat-haze, fence.
3. Same as 2.
From the latest batch...
1. Looks slightly blurry and has some strong purple fringing.
2. Winglet looks a bit blurry but otherwise okay to me.
3. heat-haze and obscured undercarriage.
4. Touch of heat-haze but might be passable.
5. Looks reasonable to me.
6. Blurry and dark.
7. Blurry and obstructed undercarriage.
8. Looks okay to me but could perhaps be a touch brighter. Looks a bit flat.
9. Heat-haze, undercarriage obstruction and bad magenta fringing.
Karl
ABissonnette
Thu Jul 04, 2019 2:28 am
3. Same as 2.
6. Blurry and dark.
Karl
Hello,
OK, thanks for the feedback! I appreciate it! :-)
airkas1
Head Screener
Thu Jul 04, 2019 5:05 pm
1. Hazed at the underside of the aircraft.
2. Very bad glare on the fuselage.
3. Hazed.
1. Flat, chromatic abberation, blurry, quality
2. Marginally passable
3. Blurry, heathaze
4. Passable
5. Blurry, marginal
6. Blurry, underexposed
7. Blurry, quality
8. Underexposed, marginal quality
9. Flat, chromatic abberation, quality.
It seems like the groundshots are just not going to work, as they;re hazed/out of focus/blurry and you're shooting beyond what your lens can handle (hence the chromatic abberation (purple fringing)). Can I also just suggest to post a few photos and then project those results onto the rest (in stead of posting 12 photos for review)?
ABissonnette
Mon Jul 15, 2019 5:56 pm
Today was an interesting day of spotting at CVG... The new United livery ERJ-175 landed, a UPS MD-11 was sitting on the hard stand after being diverted, and a Delta 767-300 took off from CVG going to JFK.. The lighting was not the best, but I tried to make the most of it.
Please pre-screen these 5 photos, please:
Thank you!! :-)
Andrew
