jeepregular
prescreen / editing advice - jeepregular
Thu May 09, 2019 8:53 am
Good afternoon! Kindly prescreen this photo. Does it look blurry especially at the nose of a/c? Thank you!
https://imgproc.airliners.net/photos/ai ... 2fc0795bc4
jeepregular
Re: prescreen / editing advice - jeepregular
Sun Jul 14, 2019 1:38 pm
Good evening! I have got this recent rejection on this photo. This photo (https://imgproc.airliners.net/photos/ai ... 4a19644e06) was rejected after an appeal for underexposed, high contrast and CCW rotation. Although I will agree on the first two reasons, the third one (CCW rotation) makes me confused. Can anybody explain why it needs some rotation? It's because, in my LR, it detected a vertical reference such as the billboard and a lampost. Any suggestions and explanations would be appreciated. Thank you!
airkas1
Sun Jul 14, 2019 1:51 pm
Level looks fine to me, the photo should be alright after fixing the underexposure and using a bit less contrast. The aircraft is bright enough, but the surroundings are dark (check the right side of the histogram).
jeepregular
Sun Jul 14, 2019 11:34 pm
Good morning! The photo (https://imgproc.airliners.net/photos/ai ... 4f9f77f089) was rejected again due to CCW rotation. Can anybody have a piece of advice on where to level on this particular photo? Is it on the billboard or the top side of the runway? Any help would be greatly appreciated Thank you!
jelpee
Head Screener
Mon Jul 15, 2019 1:28 am
Level looks fine to me.
Jehan
jeepregular
Mon Jul 15, 2019 2:24 am
Jehan
Hi! So is it worth it for me to appeal this one?
jelpee
Head Screener
Mon Jul 15, 2019 11:49 am
If level was the only issue, I would.
Jehan
jeepregular
Thu Nov 14, 2019 12:41 am
Hi guys! Can you prescreen this photo? I just want to check if the horizon is ok (my reference is that runway light) and if there are issues that must be rectified (especially its sharpness). Any feedback would be appreciated. Thank you!
airkas1
Thu Nov 14, 2019 10:34 am
Whites are on the bright side, but otherwise nice!
jeepregular
Fri Nov 15, 2019 4:05 am
Good day! May I ask for any editing advice on this photo? (the link is provided below). tI was my first time to capture this type of photo and I want to ask if there must be any adjustments with regards to colour, exposure and horizon (among other potential issues). Any feedback will be appreciated. Thank you!
link: https://imgur.com/axYOXJJ
310815
Fri Nov 15, 2019 8:06 am
Hi,
the airplane in itself looks fine But it seems you used a lot of noise reduction on the foreground which looks really smudgy at any details are lost. I am surprised to see that on a daytime shot and would advise you to use less NR.
Cheers.
Julien
airkas1
Fri Nov 15, 2019 11:10 am
I agree with Julien.
jeepregular
Sun Nov 17, 2019 8:45 pm
Hi guys! Can you prescreen this photo?(the link is provided below) I just want to check if the sharpness is fine, or otherwise blurry/soft. Any feedback will be appreciated. Thank you!
link: https://i.imgur.com/LxvZQig.jpg
jeepregular
Would this be rejected for motive?
Fri Sep 25, 2020 11:35 am
Hello! I would like to ask if the photo below would be rejected for motive (foreground is a distraction)? And, are there any issues in the photo that I need to fix? Any feedback would be appreciated. Thanks!
Photo:
jelpee
Head Screener
Fri Sep 25, 2020 3:06 pm
The foreground object is not distracting enough for me to be a motive rejection. I'm not on my screening monitor, but colors look a bit over-saturated and I'm also seeing a slight cyan tint. If you decided to edit the image further, you might also want to horizontally enter the aircraft in the frame. It looks a little Left in Frame. I know it may be picky, but its one of those things that when you see it, you can't "unsee" it! If that was the only issue with it, I would not reject it. However, since it looks like you'd be editing the image, may as well fix it.
Regard,
Jehan
dutchspotter1
Sat Sep 26, 2020 1:01 pm
A/c looks centered to me, but a little CW rotation may be needed.
NO URLS in signature
