northstardc4m
Prescreening - NorthStarDC4M
Wed Jun 12, 2019 9:50 pm
First Centering...
https://imgur.com/dypYKg2
I'm really pulling hairs... no matter where I try to center this it looks.... well... off? Any tips for centering something like this? And any pre-screening tips for it?
https://imgur.com/a/U5F8FU0
Just general pre-screening?
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
jelpee
Screener
Re: Prescreening - NorthStarDC4M
Wed Jun 12, 2019 10:15 pm
C-GKTA: Centering looks OK. However it needs a closer crop or will be rejected for "Distance". Image is also soft and blurry and has some glare by the cockpit. I would reject it in its present state.
UR-GOA: Aircraft is over-sharpened; A tad low in the frame but passable.
Jehan
northstardc4m
Thu Jun 13, 2019 12:56 pm
Ok trying PR-GOA again...
https://imgur.com/a/VSKAMaT
Done again from raw (.NEF).
airkas1
Head Screener
Thu Jun 13, 2019 2:55 pm
The new edit looks blurry to me, plus the angle of the light is not that good.
Starfuryt
Thu Jun 13, 2019 3:20 pm
Leading edge and wingtip looks very blurry, probably not salvageable tbh.
northstardc4m
Fri Jun 21, 2019 6:56 pm
Ok trying a different angle for C-GKTA, seemed too dark on my first viewing but processed the .NEF file and it was much better...
https://imgur.com/oLCclKL
Still not sure how to get a good center on a plane like a Dash 8?
jelpee
Screener
Fri Jun 21, 2019 7:25 pm
The centering looks acceptable to me. The Dash -8 from this angle is tricky due to the size of the tail. Much of the fuselage (bottom) is underexposed due to the angle of the light. I'm not on my screening monitor, so I cannot comment on soft/blurry characteristics.
Jehan
northstardc4m
Fri Jun 21, 2019 7:31 pm
Ok, so brought up shadows and black level a bit...
https://imgur.com/wHkr1ef
jelpee
Screener
Sat Jun 22, 2019 2:44 pm
Exposure is acceptable for me. However, the image now needs some additional contrast. Anytime you increase the brightness or lighten the shadows, typically you'd need to add some contrast to keep the image looking balanced.
Jehan
northstardc4m
Wed Jul 10, 2019 5:06 pm
Trying something new...
https://imgur.com/uIZOtWJ
Worth trying or? Still trying to get a idea of calibrating colors and sharpness for here.
jelpee
Screener
Wed Jul 10, 2019 9:29 pm
Looks very soft and flat (low contrast). I also see a slight magenta color cast. This one will not make it in it's current form.
Jehan
airkas1
Head Screener
Wed Jul 10, 2019 11:20 pm
Looks blurry and heathazed to me.
northstardc4m
Thu Jul 11, 2019 12:40 am
I'm not up to this... I give up until I have the patience to deal with re-learning.
northstardc4m
Thu Jul 11, 2019 2:00 am
Actually... I'll try one last try for now...
JakTrax
Thu Jul 11, 2019 10:50 am
Bad light making correct exposure tricky (i.e. likely to draw a 'dark' rejection in its current state). Looks soft too (at best — maybe even blurry but impossible to tell at that size).
Karl
airkas1
Head Screener
Thu Jul 11, 2019 11:38 am
The GLF4 looks soft and low contrast. But as Karl mentioned, the light isn't doing you any favors. The sun from your back will get you better results for photos as this.
Users browsing this forum: Crosswindphoto and 6 guests
