r5k
Pre screen - R5K
Sun Jul 14, 2019 8:32 pm
Took a few shots while on holiday in Tenerife. What do you think of this one?
Rich
airkas1
Re: Pre screen - R5K
Mon Jul 15, 2019 12:05 pm
Hi Rich,
Slightly soft and a bit magenta (needing more green) color cast. Otherwise nice.
r5k
Mon Jul 15, 2019 6:21 pm
Thanks airkas1
How about now?
Rich
r5k
Tue Jul 16, 2019 7:49 pm
How about theses two?
Rich
Crosswindphoto
Tue Jul 16, 2019 8:01 pm
Easyjet: a little low in frame
Jet2: back is blown out and A/C is underexposed, no chance.
Easyjet should be ok though.
airkas1
Tue Jul 16, 2019 8:17 pm
The A321 looks better, agree with Tim for the other 2 (the EZY A320 is a little flat as well (needs more contrast)).
r5k
Sat Jul 20, 2019 2:16 pm
How about the easyjet now? I've added a small amount of contrast and changed the crop so its higher in the frame
How about this one?
Rich
Crosswindphoto
Sat Jul 20, 2019 2:41 pm
EZY: Borderline over exposed and a touch flat (low contrast), and A few centimetres higher in frame should do it.
TUI: Low in frame, but otherwise looks ok.
r5k
Sat Jul 20, 2019 3:58 pm
Any better?
Rich
Crosswindphoto
Sat Jul 20, 2019 4:01 pm
TUI is good, EZY is now a touch high.
airkas1
Sat Jul 20, 2019 4:48 pm
The framing of the first TUI is better and not high in frame. Agree on HIF for the EZY.
r5k
Sat Jul 20, 2019 8:48 pm
Is this ok now?
few more
Richard
Crosswindphoto
Sat Jul 20, 2019 9:08 pm
EZY: a touch flat
OO-SNG: kinda purple colour cast, especially in the sky.
White A320: Over-exposed, Unser-exposed,flat, probably not fixable. Over-exposed with the blown out cloud, while the plane it self is under exposed.
Aeroflot: a bit flat, but should be fixable
r5k
Sun Jul 21, 2019 10:12 am
Thanks Crosswindphoto,
I have fixed the dead link to a 737, I will have a look at the colour cast and the aeroflot.
Richard
Crosswindphoto
Sun Jul 21, 2019 10:30 am
TUI 737 looks ok.
r5k
Sun Jul 21, 2019 1:36 pm
How about these now?
Rich
jelpee
Head Screener
Sun Jul 21, 2019 2:35 pm
Looks oversharp0ened to compensate for blurriness. Quality is quite poor.
Jehan
r5k
Mon Jul 29, 2019 8:34 pm
So this got accepted:
But I am seeing strange issues when viewing it either large or medium, the Thumb nail looks ok but as soon as I view it large or medium it has a really strange colour cast on my sony mobile on a samsung mobile and on my PC. See the screen shots below from my phone. Whats causeing this?
Medium View:
Thumb nail:
Richard
airkas1
Mon Jul 29, 2019 9:27 pm
It would appear that you saved your image in an AdobeRGB color profile instead of sRGB. Re-saving and re-uploading should do the trick.
r5k
Tue Jul 30, 2019 7:38 pm
Hi Kas
I am using adobe photoshop, when I do save as it says that the profile is ProPhoto RGB, if I go on edit and convert to profile and choose sRGB IEC61966-2.1 it then says sRGB IEC61966-2.1 as the profile in the save as window. I have saved the file as that option is that correct?
Richard
airkas1
Wed Jul 31, 2019 3:50 pm
Yeah, that should do the trick!
r5k
Fri Aug 02, 2019 8:05 pm
Thoughts on this one?
Richard
jelpee
Head Screener
Fri Aug 02, 2019 9:30 pm
Hi Richard,
The image looks over-sharpened (window line and main titles)and needing more contrast.
Jehan
r5k
Sat Aug 03, 2019 4:34 pm
How about now?
Rich
JakTrax
Mon Aug 05, 2019 2:50 pm
For me the light is just too poor and it's a very common subject. A personal rule of mine is: if the fuselage is darker than the sky behind, forget it.
Karl
r5k
Thu Aug 08, 2019 8:19 pm
Is this one ok?
Richard
spompert
Fri Aug 09, 2019 8:42 am
Hi, the titles look a bit oversharpened on my monitor. Otherwise the windowline looks soft. The light is also not in your favor so a dark or underexposed rejection would be passable I think. I can see also slight heathaze on the right wing, maybe double check in the original.
airkas1
Fri Aug 09, 2019 7:45 pm
Looks a bit blurry/marginal.
r5k
Sun Aug 11, 2019 3:43 pm
Thanks Guys,
How about this 757
Richard
r5k
Sat Aug 17, 2019 6:05 pm
Had this one rejected for
Category
Personal Message:"Category = colorful/special."
High in Frame
Underexposed
I can fix the category and high in Frame easily but is the exposure fixable.
On a positive these two were both accepted
Richard
r5k
Sun Aug 18, 2019 8:31 pm
Is this edit / exposeure better?
Richard
r5k
Sun Aug 25, 2019 7:52 pm
Any thoughts on the 757, 737 above and is this one? any better than the previous versions. I can't work out why OO-SNG looks a lot better at high resolution but the text looks weird when I edit it and resize.
Richard
airkas1
Tue Aug 27, 2019 8:30 am
Jet2: poor light and motive for the lamp post
TUI: still some room for improvement regarding exposure, judging the right side of the histogram
Brussels: passable
r5k
Tue Aug 27, 2019 8:16 pm
Thanks Kas I will scrap the Jet2
Is this better?
Richard
r5k
Mon Sep 16, 2019 8:24 pm
Hi All
Got rejected as oversharpened and overexposed where is it oversharpened? Is the nose too overexposed? I thought this one would be OK?
Brussels: passable
Rich
jelpee
Head Screener
Tue Sep 17, 2019 12:43 pm
Hi Rich,
I see jaggies around the edges of the wings, tail, horizontal stabilizer, etc. The overhead light also drew the overexposed rejection. Can't disagree with the screener's assessment.
Jehan
r5k
Sat Sep 21, 2019 8:46 pm
Thanks Jehan, I can fix the jaggies but not the top lighting.
How about these 3?
Richard
jelpee
Head Screener
Sun Sep 22, 2019 1:57 pm
Hi there Richard,
All three have that "blurry and oversharpened to compensate" look to them, especially the TUI B737.Also, the lighting appears to be quite harsh.
Jehan
r5k
Sun Sep 22, 2019 2:56 pm
Thanks, Jehan
How about these two with less sharpening? (I haven't followed my usual processing steps) I can't do much about the harsh light.
How about these two?
Is this one any good? would the motive be acceptable? how is it for level? I can't seem to get the tower and the buildings level. never submitted a shot from in the plane before.
Thank
Richard
airkas1
Sun Sep 22, 2019 6:49 pm
EZY: marginal but passable
TUI: blurry
Jet2: underexposed
LJ45: blurryish (nose, engine)
Level of the wing photo looks passable as does quality. Bit underexposed though.
r5k
Sun Sep 22, 2019 8:52 pm
Hi Airkas1 thanks for the help,
The EZY: marginal is that the light the sharpness or something else?
Ill bin that TUI
Is the Jet2 better now?
Is this LJ45 better?
Is this exposure better for the wing?
What option does this upload as I am assuming that:
Main Subject:Airliner/Other
Owner:Airline/Other
Paint:Normal/Other
View:Window
Other:N/A
Richard
r5k
Wed Oct 09, 2019 8:45 pm
Any thoughts on the LJ45 and jet2 above?
How about these 2?
and a different frame of the TUI
Rich
HarryLi
Screener
Thu Oct 10, 2019 6:39 pm
Ill bin that TUI
Owner:Airline/Other
Paint:Normal/Other
View:Window
Other:N/A
Richard
Hi Richard,
-Yes, the JET2 does look better than previous one but It seems bit of low contrast after increasing brightness.
-As Kas said befor, LJ45 seems blurry. Blurry is different from soft which can be solved by adding sharpness. Blurry could noy be fixed usually. The latest version you provided still looks blurry toward nose gear, sry about that.
- Wing view looks much better but I would still tend to apply a little bit more contrast on it.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
HarryLi
Screener
Thu Oct 10, 2019 6:45 pm
How about these 2?
Rich
Hi Rich,
For these two here.
TUI: Looks underexposed and soft for me especially windows look very soft IMO.
OK-TVI: Quality looks not so bad for me but I am not a fan of this kind of frame since it looks unbalanced IMO. Bettwe wait more thoughs about that ; )
Hope that help and sorry for the late replies.
Harry
r5k
Sun Oct 13, 2019 8:13 pm
Thanks for the feedback,
how about this edit of the TUI?
Rich
airkas1
Sun Oct 13, 2019 8:28 pm
Quite overexposed.
r5k
Sun Oct 13, 2019 8:41 pm
Hi Kas
Thanks for the fast response
Quite overexposed.
How about now?
and how about this edit with a little more contrast?
Rich
r5k
Tue Oct 15, 2019 7:31 pm
Rejection Help Please
This one got rejected for Banding
I have read the forum https://www.airliners.net/forum/viewtopic.php?f=7&t=1426915#p21509771
I am strugling to see it even when equalized is it vertical at the right side in the sky?
Is it posible to fix it in Photoshop?
Richard
HarryLi
Screener
Tue Oct 15, 2019 8:00 pm
Richard
Yes, it is vertical after checking that. Since the banding is vertical in this case, I would doubt that they come from the window. I don't think it can be fixed easily in PS, but I would say it's not very obvious for me.
Harry
r5k
Tue Oct 15, 2019 8:26 pm
Richard
Harry
Hi Harry
Thanks for the help,
If
is it worth an appealing? or reuploading at 1024 rather than 1200 wide?
Any thoughts on the further edits of the Jet2 and TUI?
Richard
