awgp
Pre-screening: awgp
Sun Oct 27, 2019 7:25 am
I’d be grateful if these could be looked at before I consider submitting to the database..
ImageUntitled by Alan Paterson, on Flickr
Thanks in advance for looking. All feedback gratefully received.
Al.
Crosswindphoto
Re: Pre-screening: awgp
Sun Oct 27, 2019 8:44 am
1: Backlit, nose wheel is cut off,
2: Crop to loose, Noise, soft/blurryish at the nose and tail.
3: light is kinda meh, but it might be ok.
4: Low in frame, and a touch more contrast but otherwise nice.
All would be better at a smaller size IMO
Tim
awgp
Sun Oct 27, 2019 5:33 pm
Tim
Tim,
1. Yeah, I did wonder about the nose wheel. Not so sure about backlit. Could you perhaps expand on that, i.e. bit more contrast, highlights, etc.
2. I’ll take a look at the original again and try a rework.
3. Basically the same light as one I had accepted recently. I guess it’s subjective.
4. Like 2 I’ll try a rework.
Thanks for taking the time to look.
Al.
Crosswindphoto
Mon Oct 28, 2019 6:06 am
For #1, the sun is behind the side of the plane that you shot, so the entire side of the plane is in shadow, it won’t be acceptable at all because of that.
#2 probably won’t be fixable, but try, and see if it can be saved.
#3 & #4 with a few slight touch ups should be good :)
Tim
JKPhotos
Screener
Mon Oct 28, 2019 8:53 am
Please consider that backlit is generally not acceptable, other than on silhouette sunset shots. #1 looks already overprocessd to make up for the backlit "light". Please consider that we don't allow such strong editing neither. The final result has to look natural. The cut wheel is a clear motive rejection. So this shot has no chance of making it, I am sorry to say.
#3 is borderline at its best. It is more or less also backlit, and as well some strong shadow lifting was applied, and it looks flat as a result.
Julien
airkas1
Head Screener
Tue Oct 29, 2019 3:38 pm
There's really no point in judging these photos for quality until they are in uploadable sizes.
#1 is underexposed due to backlit and the nosegear is cut off. Will not make it no matter how much editing.
#2 is distant.
#3 is overedited, with a look of a lot of shadows being lifted (or editing to a similar effect).
#4 either needs a tighter or wider crop on the left (include the background aircraft engine #2 or crop in front of the nose of the middle aircraft.
awgp
Mon Nov 11, 2019 9:49 am
Gents,
Thanks for the feedback provided.
I’ve had a go at editing the original of No 4.
Comments welcome.
