Page 1 of 1
Post -Screening Rejected Photos - Waqas Shah
Posted: Fri Dec 20, 2019 8:04 pm
by WaqasShah
Hello guys,
The following photos are rejected by the respected screener due to few reasons. Can you please help me to overcome these flaws.
Regards!
F-22- https://imgproc.airliners.net/photos/ai ... 806889.jpg
( Overexposed, Low Contrast, Right in Frame )
Rafale- https://imgproc.airliners.net/photos/ai ... 806833.jpg
(Blurry, Compression, Soft, High in Frame)
Rafale- https://imgproc.airliners.net/photos/ai ... 806813.jpg
(Blurry, Grainy)
Alpha Jet- https://imgproc.airliners.net/photos/ai ... 806789.jpg
(Blurry, Underexposed)
F-22- https://imgproc.airliners.net/photos/ai ... 806749.jpg
(Blurry, Overexposed, Noise)
Re: Post -Screening Rejected Photos - Waqas Shah
Posted: Fri Dec 20, 2019 10:56 pm
by jelpee
My thoughts:
1. F-22:Sky is overexposed. Aircraft is as well due to the low contrast. Looks noisy as well Aircraft is a bit right in the frame, but not a show stopper by itself.
2. Rafale: Nose is bluyry. Registration looks soft. Aircraft is HIF and visible if you look at a thumbnail version.
3. Rafale: Nose and probe are a little blurry. Don't see grain.
4. Alpha Jet: Agree with screening result
5. F22: Nose is blurry. Canopy is overexposed.Noise visible on darker areas of fuselage.
Jehan
Posted: Sat Dec 21, 2019 6:34 am
by WaqasShah
Thanks for your detail analysis. I'll try my best to get these images accepted.
Kind regards,
Waqas
jelpee wrote:
My thoughts:
Jehan
Posted: Sat Dec 21, 2019 11:08 am
by WaqasShah
Is there any other respected member or screener can give his/her opinion regrading the above photos?
Posted: Sat Dec 21, 2019 2:02 pm
by Crosswindphoto
Agree with everything Jehan said, all photos might be doable at 1200px max.
Tim
Posted: Sun Dec 22, 2019 8:06 am
by WaqasShah
Thank you!
Tim
Posted: Sun Dec 22, 2019 9:26 am
by Crosswindphoto
For the 2 photos that show the aircraft going vertical, try a portrait crop.
When cropping in Lightroom, press the letter x and it will switch it to a portrait crop, it will look much nicer!
Tim
