TheZ
Pre-screen - is this light workable?
Mon Mar 02, 2020 9:55 pm
A few weekends ago I was out at the airport on kind of a hazy day and didn't get a lot of clear shots, but for whatever reason this one stood out. The light on the fuselage ended up being interesting so I thought it might be worth working with. This is what it looked like after I scaled it down to a reasonable size for uploading, any thoughts on whether it's workable? I realize it was a pretty dark afternoon so understandable if not. Thanks in advance!
https://drive.google.com/file/d/1TeJv3d ... sp=sharing
If you have to say "pun intended," it's not a good enough pun.
HarryLi
Screener
Re: Pre-screen - is this light workable?
Fri Mar 06, 2020 11:47 pm
Hi,
The light is workable IMO. However, the color is bit of strange for me. I adjusted a little bit for the color by my screen, which probably could be helpful for you to refer :
I would recommend to use smaller size because this one looks insufficient to satisfy this current size, some parts look very soft and blurry-ish. Also could move the whole a/c a little bit higher.
Harry
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
Crosswindphoto
Sat Mar 07, 2020 9:56 am
Too me its a touch on the green side (Harry's edit), soft, and theres vignetting in the corners.
I agree with Harry, should be fixable.
Tim
Users browsing this forum: No registered users and 56 guests
