cmandel
Help with rejection - CCW Rotation
Tue Apr 14, 2020 10:18 pm
Hello,
I need some help about the rejection of the #5960627 photo. Reason: CCW Rotation. I appealed at it, but then rejected with the same reason.
Could you help me how can improve that on that picture?
https://imgur.com/a/FJlqEsk
Here is a cropped portion of the original photo, I see no rotation, it is correct?
Christian
Kaphias
Re: Help with rejection - CCW Rotation
Wed Apr 15, 2020 3:12 am
Level is not necessarily judged technically, rather by how the image appears to one's eye. If you'd like our input and help on that, please post the image you uploaded. :)
cmandel
Wed Apr 15, 2020 5:37 am
Kaphias, thanks for your answer, I think you have a point here. The photo seems to be slightly unleveled as first sensation although the building is completely vertical. :)
Christian
jelpee
Head Screener
Wed Apr 15, 2020 11:53 am
Another point is that vertical alignment is most accurate when it is at the center of the frame. If you are aligning based on say, buildings and/or towers on either the right or left sides of the frame, it may or may not be accurate due to lens distortion which tends to make items at the edges lean in. I typically use a distant horizontal. I find it tends to result in a more pleasing appearance to the eye and most times makes the verticals look aligned as well.. Hope this helps.
Jehan
cmandel
Wed Apr 15, 2020 2:51 pm
Jehan
Thanks for the feedback Jehan, will apply that leveling techique from now on photos with high lens distortion.
cmandel
Wed Apr 15, 2020 9:54 pm
Hello,
I edited again the photo with the improvement on the leveling.
https://imgur.com/a/nC6MDZu
Its slightly better than before? Is this photo aceptable?
Thanks for your time
jelpee
Head Screener
Wed Apr 15, 2020 11:44 pm
Looks level to my eyes.
Jehan
Users browsing this forum: No registered users and 53 guests
