aircountry
Pre-screening good or need to fix?
Mon Sep 14, 2020 10:32 am
My first post here and I tried to add photos in attachment and checked the preview before post it and said not downloaded yet but how to to put picture in here?
aircountry
Re: Pre-screening good or need to fix?
Wed Sep 16, 2020 7:14 am
I moved to here from my other forum with my pictures in the link
here are 4 photos of Air India 787-8 with hazy partly cloudy weather and I tried to fix it and I dont know any of are good to submit or need to fix it before I submit in airliners.net here is the link is https://imgur.com/a/0CrIKHl
I followed the acceptance guide on Fuselage crops
Example 22a: regular crop
This example shows a regular crop with the entire aircraft in view and is acceptable at Airliners.net
https://www.airliners.net/graphics/reje ... a_full.jpg
Example 22b: Unmotivated crop
This example is a tighter crop of example 1a and is not acceptable. The shot looks unbalanced with the gear partly cropped out. The next example will show a similar but different crop that would be acceptable
Example 22c: Acceptable fuselage crop
This image looks more balanced with the entire gear cropped out and is acceptable.
https://www.airliners.net/graphics/reje ... c_full.jpg
I use in 22a and c both are acceptable, just look at my link picture and tell me its good or need to fix it I just pick one to submit and I will submit other later ok. Thank you
aircountry
Wed Sep 16, 2020 11:34 am
I'm waiting for anyone to look at the pictures in the link from #2 and tell me its good to go or need to fix it thank you
HarryLi
Screener
Fri Sep 18, 2020 8:52 am
I can't access to the later two links you posted ;D
Could you please check it again ?
Harry
aircountry
Fri Sep 18, 2020 11:18 am
Harry
that is odd both are broken links. I checked and its still there is https://www.airliners.net/graphics/reje ... a_full.jpg
and https://www.airliners.net/graphics/reje ... c_full.jpg
From Photo Acceptance Guide https://www.airliners.net/faq/photo_acceptance_guide/ look up example 22. I hope that help you to find it.
HarryLi
Screener
Sat Sep 19, 2020 8:37 am
Hi Sorry for the late reply.
Firstly, the crop looks really iffy for me as I am not a fan of this kind of crop because it looks not really balanced in genearl although it is close to Example 22c. I won't recommend this crop, IMO.
There are also some other issues as well. Reflections on the body due to cloudy day and sunshine at cloudy day could cause a rejection on Motive as well since it's very strong, and the exposure in termes of the whole picture is very dark. Increasing brightness in this case probably would cause Overexposed at glared areas.
BTW, you can only upload one of them to the queue one time. Just FYI.
Sincerely,
Harry
aircountry
Sat Sep 19, 2020 10:23 am
Thank you for responding. Yes I noticed lots of reflections in front of the plane due the weather with partly cloudy and hazy. I tried to make it better but very hard to make it right. You are right if I increase the exposure and it will overexposed and I had to go down lower exposure with less too much bright. I submitted just one after I picked one in it just to try see what the screener say. Thank you Harry.
aircountry
Sun Sep 27, 2020 11:20 am
I got rejected and said The Screener left a comment regarding this photo:
"poor crop of main landing gear, green"
the screener is right on this, Firstly, the crop looks really iffy for me as I am not a fan of this kind of crop because it looks not really balanced in genearl although it is close to Example 22c. I won't recommend this crop, IMO.
So I suggest you need to update the acceptance guide for 22 all are not acceptable for main landing gear. I guess head screener made decision to change the rule but not update on 22. I have seen few pictures accepted similar like my rejected picture.
this is my pictures are rejected https://www.airliners.net/user/photo-co ... to/6160425
At least I tried my best and I wont fix to submit and it wont accept it just move on.....Thank you
Users browsing this forum: No registered users and 23 guests
