Hi,
from time to time I really get a bit mad about some screening results.
This pic
https://abload.de/img/q33a2424-1grossfilter6hkmr.jpg was first rejected for "underexposed" and "cw-rotation".
After appeal (Pic is level (see right lightpost) , horizon sneaks away due to not 90 degrees. Why shall the pic be underexposed Ifdf exposed more the nose will be burnt out.) I got this:
- Colour
- Noise
- Personal Message
The Screener left a comment regarding this photo:
"Level is OK. Image has a yellow color cast visible in the nose area. Sky could use some noise reduction as well."
First rejetion points no issue anymore but now two other ones!!!
Everybody who knows this location knows that there are lights with differents temperatures and that you never get the colors all over the same due to that. The nose is always a bit yellow by nightshots in that location and I have many similar pics in the db with that.
And suddenly there is noise which was not an issue before and which I cannot see at all.
What do you think?
Rainer
