BWIAirport
Is blurriness the only problem here?
Thu Sep 16, 2021 5:38 pm
I took this in June and really liked the composition on it personally. Unfortunately, I fear it is too blurry to be accepted and I'm not familiar with an effective sharpening tool. Would appreciate any input!
N62NA
Re: Is blurriness the only problem here?
Fri Sep 17, 2021 6:25 pm
Maybe they won't like the smudge on the window in the lower left corner?
HarryLi
Screener
Mon Oct 11, 2021 9:05 am
Sup !
I dont know how it will look like when you use a uploading size because your current size is original size I believe, and you should judge it from our angle which is checking your pic in uploading size since we can't access your original pic.
IMO, the pic is also underexposed and soft. There's also a unknown brown dust spot in the left frame. Agree with "Maybe they won't like the smudge on the window in the lower left corner?" mentioned above. Guessing that's reflection or dirty part of window.
Harry
BWIAirport
Mon Oct 11, 2021 3:35 pm
HarryLi wrote:
Sup !
Harry
Thanks for the response! FlightAware diminishes the quality of the photo a bit; the original is slightly higher quality. I suppose I could always push it through and see how it goes.
