EaglePark
Rejected for Personal Message
Sun May 15, 2022 10:18 pm
It is my first time trying to upload on here. I submitted the below image and was rejected for the following reasons:
Distance, Personal Message, Right in Frame & Soft
https://imgproc.airliners.net/photos/ai ... 8254e9e8da
I would really appreciate some assistance on what these would mean? From what I can see the image is sharp, maybe slightly right in frame. With regards the personal message the exact message I put in when I submitted this photo is as follows :1st time uploading to this website. If rejected really appreciate some constructive feedback so I can improve. Many thanks"
Have I done something wrong here?
Appreciate any assistance
wiggy
Re: Rejected for Personal Message
Tue May 17, 2022 12:04 am
What was the Personal Message?
wiggy
Tue May 17, 2022 12:07 am
It definitely looks right in the frame and also a little low in frame but however the sharpening looks good to me but someone else might know better then me however it does look a bit distant in frame the aircraft does and I know whether this will work but you could try cropping it down a bit more.
I hope this helps
Cheers Hadleigh
EaglePark
Tue May 17, 2022 6:50 am
In the Message to the screeners I wrote the following:
"1st time uploading to this website. If rejected really appreciate some constructive feedback so I can improve. Many thanks"
EaglePark
Tue May 17, 2022 6:55 am
I hope this helps
Cheers Hadleigh
Thanks Hadleigh, I will re crop it and try and re submit and se how we go.
wiggy
Tue May 17, 2022 10:26 pm
No problem good luck with the editing eaglehawk!
wiggy
Sorry eaglepark
wiggy
Tue May 17, 2022 10:28 pm
If it gets rejected for soft try adding a tad more sharpness to it and it should fix it.
EaglePark
Wed May 18, 2022 1:48 am
That is a good idea, will give it a shot and see how it goes.
wiggy
Wed May 18, 2022 6:05 am
sounds good.
jeonggeunwon
Thu May 19, 2022 12:14 pm
hello
personal message means the screener gives you an advice or details regarding your rejected photo, is not your comment to screener.
you can find personal massage from screener at the botton of the email.
PanAm_DC10
Community Manager
Sun May 22, 2022 5:21 am
Hello
The screener suggested a smaller size such as 1024. It is also right in frame which explains distance. Soft is subjective as it may depend on the screener but a little more USM would help.
If you are able to correct please try again and happy to look at it if you'd like
IFlyVeryLittle
Thu Sep 15, 2022 8:29 pm
It should be "right" in frame. the eye wants to see more room in the direction of movement.
