Jalap
Which one to choose (taxiing Concorde)
Wed Nov 02, 2022 8:03 pm
Got a tough choice to make with a series of shots I made the only time I spotted a BA Concorde, was at CDG.
It was a huge surprise to see that one show up and in the excitement I messed up the shots a bit, but still edited they're up to par with the quality standards for old photos here. They're all a bit blurry and the weather had turned overcast.
Problem is, I can't choose which one to take. With the double rule, I probably can only upload 2.
The one right in front perhaps is the most interesting angle, but little Concorde remains in that angle.
And the other two, I like both... .
Which one(s) would you choose?
scbriml
Re: Which one to choose (taxiing Concorde)
Thu Nov 03, 2022 10:25 pm
Personally, I really like the nose-on shot. That said, both the other shots should be acceptable within the current double rules.
beaverhunter
Screener
Sat Nov 05, 2022 8:49 pm
Hi Steve,
I would suggest you go with the first two. The first one is 90 degrees different than the middle one. The third one is less than 90 degrees different than the head on shot, so it would be considered a double. i hope this helps. Nice shots!
John Olafson
beaverhunter
Screener
Sat Nov 05, 2022 11:36 pm
Sorry Steve, I meant to reply to the originator. Jalap
John Olafson
eggohoek
Head Screener
Mon Nov 07, 2022 1:55 pm
With the current double rule you can upload the first and third or only the second.
"The first one is 90 degrees different than the middle one." - this is not true, difference is less than 90 degrees.
I suggest to upload the first and last and then the middle one too, as screener's discretion should be apply for these shots.
