davycam
Prescreen Comments - Still On The 300mm Nikkor
Wed Jul 21, 2010 11:51 pm
Still playing with the 300mm Nikkor as I'm usually restoring 70s-80s pix here, not shooting. Your comments. As always, appreciate the critique since my ego's long past bruising...comes with age, like wisdom.
First up, The Twins (ships 439 & 440):
Big version: Width: 1024 Height: 768 File size: 570kb
0456
Second, a lucky (for me) Early Rotation view of still-extended undercarraige:
Big version: Width: 1024 Height: 768 File size: 393kb
[Edited 2010-07-21 17:29:39]
davycam
RE: Prescreen Comments - Still On The 300mm Nikkor
Wed Jul 21, 2010 11:59 pm
Immediate obvious (to me) concern is centering vis-a-vis what do you do with those vertical fins? Evident in the Twins...center fuselages vertically or entire a/c? In the Rotation pic, go for the nose/fin relationship or the entire fuselage?
Also, your preference for NR/sharpening pre- or post-sizing. I usually work off the original in NN, adding additional sharpening if necessary when I resize. Your experiences on that issue would be a great help.
Dave
[Edited 2010-07-21 17:44:29]
dlowwa
Thu Jul 22, 2010 12:50 am
Hi,
First one is a write-off; quality is quite poor (looks like too much heat haze from shooting at a distance), and motive obviously as the noses of both aircraft are cut off.
Second one is better quality-wise, but again shooting at a distance has taken its toll - it looks like the quality is not quite there (extra sharpening applied to make up for softness, etc...). I'd have to see the original to know if that's where the problem is or if its just your editing, but if I had to guess I'd say the former.
Let me know if you want me to take a look.
Dana
davycam
Thu Jul 22, 2010 12:55 am
One more, since it's the only one of the three that even gets me remotely excited.
0549
davycam
Thu Jul 22, 2010 1:02 am
Per my previous thread, Dana, I think I'm clearly on to three issues:
1. No monopod at full focal length.
2. Not shooting in RAW.
3. My resistance to halos in sharpening....I'll just have to get over it.
Thank you.
dlowwa
Thu Jul 22, 2010 1:13 am
Hi,
The G4 looks better than the DL 752, though there are still a few minor issues with softness/sharpening.
As to your points,
1. I almost always use support (tripod/monopod) when shooting past 300mm effective, and if I'm up in the 500mm+ plus range, then it's a must to combat shake, as I don't like bumping up the ISO. Plus, it can get tiring always having to support all that weight if you're only shooting hand held with a longer lens
2. Shooting RAW is most beneficial for correcting exposure and color problems; it doesn't really help that much when it comes to sharpening, and of course can do nothing about heat haze.
3. Not sure what that means, but if you are trying to avoid oversharpening, I agree - the only place I see it badly is the leading edge of the wings in the G4 shot. The DL 752 has evidence of oversharpening - I think this is what you must mean by halos... adding more sharpening to the DL is not going to help. I was trying to imply that you had already added too much to try and compensate for a soft shot, and it wasn't really working too well. If I've ms-interpreted, let me know.
davycam
Thu Jul 22, 2010 1:52 am
As usual, Dana, you nailed it.
