frankc
Pre/Post-Screening (frankc)
Tue Apr 24, 2012 10:22 pm
Hello
I wonder of the image below would be fine in terms of centering, that is, I centered only the aircraft and not the aircraft plus its partial reflection.
The reflection shows only a limited part of the aircraft (looks like 50% or less) so I ignored it during centering.
Any opinions appreciated!
https://www.airliners.net/addphotos/big/ready/j1335305529.9482omvrd.jpg
PS please ignore other possible issues with the image, this is only a limited edit.
Frank Clautier
vikkyvik
RE: Pre/Post-Screening (frankc)
Tue Apr 24, 2012 11:56 pm
I would probably raise it just a bit in the frame, but it might be OK the way it is.
alevik
Wed Apr 25, 2012 12:03 am
Centering looks passable to me. There are other issues but as you noted not a final edit.
Improvise, adapt, overcome.
frankc
Wed Apr 25, 2012 4:24 pm
Thanks guys!
I eliminated some noise and oversharpened edges, along with a color correction.
Before:
After:
https://www.airliners.net/addphotos/b...y/e1335370416.741frankc_omvrd2.jpg
Frank
frankc
Fri Apr 27, 2012 10:16 pm
I've currently 2 uploads in the queue of the same aircraft:
and
https://www.airliners.net/addphotos/b...335564504.0476frankc_omvrd_day.jpg
Both pictures are taken on a different date.
Would these to be subject to a "Double" rejection?
Frank Clautier
vikkyvik
Fri Apr 27, 2012 11:48 pm
Quoting frankc (Reply 4):
Nope. Even if taken on the same date, they'd be fine, as they're showing opposite sides of the aircraft.
frankc
Sat Apr 28, 2012 10:56 pm
Many thanks Vik!
A separate issue is this rejection which I've got recently.
https://www.airliners.net/addphotos/r...5_u1334594724.9077frankc_hbaff.jpg
Rejected for:
Dark
Level (personal note: needs CW rotation)
I can see the Dark issue, but I've trouble with finding the Level issue.
I used the horizon as a levelling criterium, and the verticals (the lamppost rising behind the aircraft and the little building near the right) appear to be in balance.
Any pointers near the levelling solution are greatly appreciated
Cheers!
Frank Clautier
frankc
Tue May 01, 2012 3:22 pm
Would this one be ok for level?
https://www.airliners.net/addphotos/b...dy/i1335885107.398frankc_dcawu.jpg
I levelled using the verticals on the buildings, but the pole still leans a bit to the left.
However, correcting for this pole, would make the all other background verticals lean to the right.
Frank
dlowwa
Tue May 01, 2012 5:00 pm
Maybe a touch more ccw, based on the buildings. The pole would be misleading, so you are right to ignore it.
frankc
Tue May 01, 2012 5:06 pm
Thank you Dana.
Quoting dlowwa (Reply 8):
Yes I can see it now - it will be like 0.1degrees or the like.
Frank Clautier
frankc
Fri May 04, 2012 4:34 pm
Hello
A friend found this photo,taken somewhere in the seventies, in his archive.
Would it have sufficient quality to in order to get accepted?
https://www.airliners.net/addphotos/b...w1336148914.4958frankc_spantax.jpg
Frank
dlowwa
Fri May 04, 2012 9:33 pm
Quoting frankc (Reply 10):
The color and contrast need to fixed up, but it could be salvageable. If it's your friend's, he will need to be the one who uploads it; you can't upload it from your account if it doesn't belong to you.
frankc
Sat May 05, 2012 2:01 pm
Hi Dana , thank you for your feedback - I will let him know.
Frank Clautier
frankc
Wed May 09, 2012 5:22 pm
Hi Dana
Referring to our conversation about my friend's photo: at present he doesn't has an account.
Therefore, would it be acceptable - in terms of legality - if I put in the comment field a reference to his name?
Thank you for your help!
Frank
Tomskii
Wed May 09, 2012 5:30 pm
Quoting frankc (Reply 13):
Airliners.net policy states that you have to be the person that must have taken the picture Frank   An account is free on here, so I wouldn't see a reason for him not to register.
Nikon D90 + Nikkor f4.5-5.6 18-105mm + Tamron f4-5.6 70-300mm
frankc
Wed May 09, 2012 5:40 pm
Hi Tom
Thank you for your reply - that confirms what I was deducing from the terms of legality.
I will get him to create his own account.
Cheers from Antwerp
Tomskii
Wed May 09, 2012 6:26 pm
Quoting frankc (Reply 15):
Cheers from Leuven back haha ;D
frankc
Thu May 10, 2012 9:35 pm
Hello
I got this image rejected for level ("needs cw rotation")
https://www.airliners.net/addphotos/r...10_c1335909162.276frankc_dcawu.jpg
If I would rotate this further cw, the verticals would begin lean to the right (I assume the screener(s) were using the lightpole in the middle as reference).
Any suggestions welcome
Frank
dlowwa
Fri May 11, 2012 6:02 am
Quoting frankc (Reply 17):
Looks level to me. Maybe try appealing.
frankc
Sun May 13, 2012 6:48 am
Hello
I've got a shot of a Global Express, with quite some issues (overexposed,softness,dirty):
Rejected image
https://www.airliners.net/addphotos/r...8_w1335782804.3278frankc_ecleb.jpg
So I worked on another photo, with different camera settings:
https://www.airliners.net/addphotos/b...y/c1336858600.2948frankc_ecleb.jpg
However, as the photos were taken with the sun quite high in the sky, the exposure and contrast still look somehow problematic to me (especially when compared with existing images of the same aircraft).
I'm not quite sure if it would fit to the A.net standards at all?
Frank
dlowwa
Sun May 13, 2012 7:38 am
Newer one is better, and should have a chance.
frankc
Tue May 15, 2012 3:34 pm
Hello again,
Would the exposure of this Beech 200 be problematic (especially near the nose) ?
https://www.airliners.net/addphotos/b...y/n1337095762.3585frankc_omtaa.jpg
Thank you for your help,
Frank Clautier
Tomskii
Tue May 15, 2012 4:56 pm
Don't think it would be a problem, however I'm giving dana the final call
dlowwa
Tue May 15, 2012 6:00 pm
Maybe a bit bright, but not too bad. It is a bit oversharpened and low in the frame though.
frankc
Tue May 15, 2012 7:52 pm
Thank you for the feedback, Dana and Tom!
Frank
frankc
Sun May 20, 2012 5:40 pm
I find it quite challenging to center this Beaver properly, so any feedback is welcome.
https://www.airliners.net/addphotos/b...y/f1337531473.4934frankc_lnncc.jpg
Thank you!
Frank
dlowwa
Sun May 20, 2012 8:23 pm
Quoting frankc (Reply 25):
Centering looks fine to me.
frankc
Wed May 23, 2012 12:42 pm
Hello
Would this image be passable in terms of level?
I used the horizon as primary reference, but since the pole behind the airplane is not perpendicular with the apron, it may suggest further ccw rotation.
https://www.airliners.net/addphotos/b.../z1337776536.9049frankc_n572ec.jpg
Thank you,
Frank Clautier
frankc
Wed May 23, 2012 5:10 pm
Additionally, I'd like some information regarding the field "Operator" for this one:
https://www.airliners.net/addphotos/b.../p1337790975.3651frankc_n525fd.jpg
At present, I selected: Operator - OTHER, using the title "Buddies".
However as this is a brand rather than an operator, I'm not sure whether this is correct. Alternatively, leaving it as "Untitled" doesn't seem to fit either.
Any thoughts?
Thanks a mil !
Frank Clautier
Tomskii
Wed May 23, 2012 5:24 pm
as far as my intel goes it is privately owned (and I do not know the private owner as he/she is not listed at all)
dlowwa
Wed May 23, 2012 6:16 pm
Quoting frankc (Reply 27):
Seems ok.
Quoting frankc (Reply 28):
Title is not the operator. Title is what it says on the aircraft, which is why most private aircraft are titled 'Untitled' rather than 'Private'. 'Buddies' is prominently visible on the aircraft, so that should be fine as the title. If you wish, you can include the operator in brackets 'Buddies (Operator)'.
frankc
Thu May 24, 2012 12:55 pm
Thanks for the info Dana and Tom!
Frank
frankc
Sat May 26, 2012 8:44 pm
Hi,
Would this photo be suitable in terms of vertical centering and noise/grain?
https://www.airliners.net/addphotos/b...dy/r1338064710.865frankc_fhaav.jpg
Thanks !
Frank Clautier
dlowwa
Sun May 27, 2012 12:59 am
Quoting frankc (Reply 32):
It is too high. There is some slight noise noticeable, but I think it should be ok.
frankc
Tue Jun 05, 2012 4:13 pm
Hello,
I'm not quite sure about this image, in terms of color,exposure and contrast. It was shot in the late evening and I hoped to get a nice lighting, but it looks it turned out rather the opposite.
https://www.airliners.net/addphotos/b...y/s1338912584.2122frankc_vtaat.jpg
Thanks for any feedback!
Frank Clautier
dlowwa
Tue Jun 05, 2012 7:08 pm
Quoting frankc (Reply 33):
Should be ok.
frankc
Fri Jun 08, 2012 9:46 pm
Hello again,
The elevator of this Falcon 50 seems to vanish into the sky - I guess it's caused by the angle of the camera relative to the aircraft :
https://www.airliners.net/addphotos/big/ready/l1339191346.3009fgxtm.jpg
Would it likely trigger a soft rejection?
PS please ignore other issues, since this edit isn't completed yet.
Frank Clautier
[Edited 2012-06-08 15:27:50]
dlowwa
Sat Jun 09, 2012 1:21 am
Quoting frankc (Reply 35):
Seems ok for sharpness.
frankc
Wed Jun 13, 2012 10:55 pm
Hi,
Would it be possible to have a second opinion for this Beech 350 please? Personally I think it's a bit grainy/soft in places.
https://www.airliners.net/addphotos/b...y/e1339594815.4196frankc_fhacj.jpg
Thanks again!
Frank
dlowwa
Thu Jun 14, 2012 12:05 am
A little noisy, but shouldn't be a problem. I don't see it as being soft.
frankc
Fri Jun 22, 2012 9:05 pm
Hello
Does this image feels ok in terms of Saturation and Color (White) Balance?
The original photo was made using an ExpoDisc and hence I didn't touch any color adjustments in Photoshop.
https://www.airliners.net/addphotos/b...y/w1340398763.2716frankc_dcleo.jpg
Frank
dlowwa
Sat Jun 23, 2012 9:37 pm
Quoting frankc (Reply 39):
Color should be fine.
frankc
Sun Jun 24, 2012 9:33 pm
Thanks Dana, could I also ask the same question on this one?
https://www.airliners.net/addphotos/b.../b1340573344.1531frankc_n351cc.jpg
Thanks a mil!
Frank
dlowwa
Sun Jun 24, 2012 10:57 pm
Quoting frankc (Reply 42):
Maybe a touch blue, but should be fine.
frankc
Fri Jun 29, 2012 4:07 pm
Hi,
This image was rejected for both Soft and Dark.
I've difficulties with identifying the area(s) leading to these rejection categories so I'd be grateful for any pointers.
https://www.airliners.net/addphotos/r...9_w1340396910.5766frankc_dbubi.jpg
Frank Clautier
frankc
Sat Jun 30, 2012 2:41 pm
Hi,
Please disregard my previous post - I'll appeal, and, in case of rejection confirmation, trying a make-over.
Frank
Tomskii
Sat Jun 30, 2012 4:06 pm
Well I'll still give you the feedback though. Dark looks a bit weird to me but maybe adding a touch of exposure might help. As for soft: I'm still looking..
frankc
Sat Jun 30, 2012 8:49 pm
Cheers Tom, the head screener confirmed that the image indeed lacks some brightness so I'll take it back to the drawing board
Greetz,
Frank
frankc
Tue Jul 10, 2012 9:39 pm
Hi,
Would this one be acceptable in terms of vertical centering?
https://www.airliners.net/addphotos/b...dy/c1341841164.916frankc_spyve.jpg
Frank Clautier
dlowwa
Tue Jul 10, 2012 10:39 pm
Quoting frankc (Reply 47):
Should be.
